Htwjr Posted April 3, 2018 Report Posted April 3, 2018 I am just curious but how is 24 squared only 59% power? Is it because it is leaned so much? I thought 24 squared was in the red box where we were not supposed to be. Quote
jaylw314 Posted April 3, 2018 Report Posted April 3, 2018 On 4/2/2018 at 8:41 AM, 201er said: I didn't choose those. I chose the altitude for winds/clouds and the altitude chose the power settings. When you're up higher, you have less MP available so you can compensate to a degree with higher RPM to get the same power/FF. However, you do get slightly faster TAS up higher but the wind is the real advantage. Studying the J POH, as you climb: TAS at full throttle decreases at any given RPM, since you have less MP available with altitude fuel burn increases at any power setting, since you have to increase RPM (which increases frictional loss) Generally, you will go slower and burn more fuel high up in a NA engine, but the tail wind makes it all worth it! Quote
