NewMooney Posted March 6, 2018 Report Share Posted March 6, 2018 Hello All, I am considering purchasing a 1994 Mooney M20M Bravo. I haven't had the aircraft looked at yet but have been doing a good amount of research and reading reading about some of the early versions of this plane and the heat problems leading to top-end work being required in as little as (every)400 hours. It appears that Mooney resolved the issue with its "wet-head" conversion thereby increasing the time between maintenance. Anyone have any direct experience or feedback? The main article I am referencing is from an AOPA article written back in 1998: https://www.aopa.org/go-fly/aircraft-and-ownership/aircraft-fact-sheets/mooney-bravo Look forward to the feedback! Quote Link to comment Share on other sites More sharing options...
Hank Posted March 6, 2018 Report Share Posted March 6, 2018 Check the "Modern" subforum here. Isn't the "wet head" the same as the Bravo conversion? 1 Quote Link to comment Share on other sites More sharing options...
KLRDMD Posted March 6, 2018 Report Share Posted March 6, 2018 2 minutes ago, Hank said: Check the "Modern" subforum here. Isn't the "wet head" the same as the Bravo conversion? Yes Quote Link to comment Share on other sites More sharing options...
NewMooney Posted March 6, 2018 Author Report Share Posted March 6, 2018 Yup... It is... just wanted to see if anyone has any direct experience with it. According to that AOPA article and a few others, the jury was still out on whether the conversion actually resulted in fewer occurring and less expensive maintenance needs. Quote Link to comment Share on other sites More sharing options...
rpcc Posted March 6, 2018 Report Share Posted March 6, 2018 Look at the bravo forum on this site - lots of stuff there. Also use the search function. There's lots of information available. Quote Link to comment Share on other sites More sharing options...
mike_elliott Posted March 6, 2018 Report Share Posted March 6, 2018 3 hours ago, NewMooney said: Yup... It is... just wanted to see if anyone has any direct experience with it. According to that AOPA article and a few others, the jury was still out on whether the conversion actually resulted in fewer occurring and less expensive maintenance needs. That AOPA article is very dated. The TIO540 AF1B is one of the most bullet proof engines Lycoming makes. Like all engines, they have to be operated correctly for the optimum of less expensive maintenance needs. Early TLS's (named before the Bravo mod to the engine) need a few upgrades to make them like "real" bravos, such as bigger brakes. Later Bravos are some of the best buys of the used Mooney market place. Granted they are an expensive engine to OH, as is the Conti 550 turbo and non turbo. Their weakness is the exhaust system IMO and they are stout as long as they are operated properly. You should easily be able to make TBO on the engine and cylinders if operated correctly. The rub is when you buy one used, you really dont know how it has been treated. The Bravo, like the Acclaim it predates, is a personal air liner! Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted March 6, 2018 Report Share Posted March 6, 2018 3 minutes ago, mike_elliott said: The rub is when you buy one used, you really dont know how it has been treated. ...but that is true of ANY used airplane, car, boat, house, .... 1 Quote Link to comment Share on other sites More sharing options...
MIm20c Posted March 6, 2018 Report Share Posted March 6, 2018 There was a really nice one on AAA a few months ago. Had to keep telling myself do not call, do not call, DO NOT CALL. Luckily it sold after a couple weeks. Quote Link to comment Share on other sites More sharing options...
NewMooney Posted March 6, 2018 Author Report Share Posted March 6, 2018 Thanks Mike... I kind of assumed the older date of the article would come into play and I appreciate your feedback. I am heavily leaning towards the purchase of this aircraft (pending a pre-purchase inspection by a mechanic). Thanks again! Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted March 7, 2018 Report Share Posted March 7, 2018 2 hours ago, NewMooney said: Thanks Mike... I kind of assumed the older date of the article would come into play and I appreciate your feedback. I am heavily leaning towards the purchase of this aircraft (pending a pre-purchase inspection by a mechanic). Thanks again! If it ‘s the ‘94 I’m thinking of, type in the N-number on the search function here.and there have been quite a few comments about it. Quote Link to comment Share on other sites More sharing options...
NewMooney Posted March 7, 2018 Author Report Share Posted March 7, 2018 Did a search in all content and did not have anything come up... is there a sort of “car fax” for aircraft? Quote Link to comment Share on other sites More sharing options...
Hank Posted March 7, 2018 Report Share Posted March 7, 2018 1 hour ago, NewMooney said: Did a search in all content and did not have anything come up... is there a sort of “car fax” for aircraft? If you went to the top of this page, you may have only searched this subforum. Try again on the home page, and again verify "all forums" Quote Link to comment Share on other sites More sharing options...
Hank Posted March 7, 2018 Report Share Posted March 7, 2018 1 hour ago, NewMooney said: Did a search in all content and did not have anything come up... is there a sort of “car fax” for aircraft? The FAA can send you a CD with everything they have a record of, for a (really!) small fee. Seems like it's $10, but I'm not sure where on their website to send you. Quote Link to comment Share on other sites More sharing options...
NewMooney Posted March 7, 2018 Author Report Share Posted March 7, 2018 9 hours ago, Hank said: If you went to the top of this page, you may have only searched this subforum. Try again on the home page, and again verify "all forums" Found it... Thank you! Quote Link to comment Share on other sites More sharing options...
