BDPetersen Posted February 27, 2018 Report Share Posted February 27, 2018 My 40 hour Plane Power alternator is making whining noises in radio and erratic amp readings. Without going into all the symptoms and background, I thought it was of interest my discovery in talking to Plane Power (Hartzell) tech that the alternator is actually NOT maintainable/repairable. They were more than willing to be accommodating with a warranty replacement, however, even if it was outside the warranty period. (He seemed pretty sure it sounded like a diode). So, unless I discover another gremlin, loose wire, or whatever, off it comes. But I was amazed to learn repair was not an option. Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 27, 2018 Report Share Posted February 27, 2018 Sounds like a diode or two... Diodes usually fail in pretty obvious ways, visibly or measurably. Can you find or see the diodes? Might save you some hassle, before sending the whole thing out... PP ideas only, not a mechanic. -a- Quote Link to comment Share on other sites More sharing options...
BDPetersen Posted February 27, 2018 Author Report Share Posted February 27, 2018 To answer myself, turns out a loose lug on the field c/b was the culprit. Tightened and stability returns to the electrical department. Who knew. Maybe Plane Power alternators never need to be fixed. 5 Quote Link to comment Share on other sites More sharing options...
carusoam Posted February 28, 2018 Report Share Posted February 28, 2018 Great follow-up BDP! Best regards, -a- Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted February 28, 2018 Report Share Posted February 28, 2018 You can get them for $50 at Auto Zone 1 Quote Link to comment Share on other sites More sharing options...
jetdriven Posted February 28, 2018 Report Share Posted February 28, 2018 (edited) I haven’t been able to find an alternator off the shelf that has the same rectifier packs since this is externally regulated. But I did get the part number of the rectifier off here and they are available for about 45$ shipped. INR720P https://www.aspwholesale.com/rectifier-nd-p1359.html Edited February 28, 2018 by jetdriven 2 Quote Link to comment Share on other sites More sharing options...
Sisk Rifles Posted February 28, 2018 Report Share Posted February 28, 2018 Do you have the part number that will replace the plane power ? Quote Link to comment Share on other sites More sharing options...
mooniac15u Posted February 28, 2018 Report Share Posted February 28, 2018 18 hours ago, BDPetersen said: My 40 hour Plane Power alternator is making whining noises in radio and erratic amp readings. Without going into all the symptoms and background, I thought it was of interest my discovery in talking to Plane Power (Hartzell) tech that the alternator is actually NOT maintainable/repairable. They were more than willing to be accommodating with a warranty replacement, however, even if it was outside the warranty period. (He seemed pretty sure it sounded like a diode). So, unless I discover another gremlin, loose wire, or whatever, off it comes. But I was amazed to learn repair was not an option. That probably just means that it's not cost effective for them to offer a repair service. A new PP alternator is about $400 which seems to already be cheaper than other brands. What price differential would you want on a repair to make it worthwhile over buying a new one? Would you get it repaired for $300? I don't think I would. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted February 28, 2018 Report Share Posted February 28, 2018 1 hour ago, Sisk Rifles said: Do you have the part number that will replace the plane power ? INR720P. Link above. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted February 28, 2018 Report Share Posted February 28, 2018 They weee repairable when Plane Power owned them. We had one installed when we bought our plane. The mechanic didn’t tighten the output nut and the arcing melted the output post off. They repaired it for 120$. Quote Link to comment Share on other sites More sharing options...
mooniac15u Posted February 28, 2018 Report Share Posted February 28, 2018 6 minutes ago, jetdriven said: They weee repairable when Plane Power owned them. We had one installed when we bought our plane. The mechanic didn’t tighten the output nut and the arcing melted the output post off. They repaired it for 120$. Exactly! They are repairable. PP (Hartzell) just doesn't want to. The repair department was probably too expensive to keep. Quote Link to comment Share on other sites More sharing options...
Sisk Rifles Posted February 28, 2018 Report Share Posted February 28, 2018 If you wanted to buy a complete alternator from this company, what part number would that be ? Quote Link to comment Share on other sites More sharing options...
mooniac15u Posted February 28, 2018 Report Share Posted February 28, 2018 11 minutes ago, Sisk Rifles said: If you wanted to buy a complete alternator from this company, what part number would that be ? The part number depends on the aircraft. Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted February 28, 2018 Report Share Posted February 28, 2018 4 hours ago, Sisk Rifles said: If you wanted to buy a complete alternator from this company, what part number would that be ? plane-power-pma2013.pdf Quote Link to comment Share on other sites More sharing options...
jetdriven Posted February 28, 2018 Report Share Posted February 28, 2018 (edited) 4 hours ago, mooniac15u said: Exactly! They are repairable. PP (Hartzell) just doesn't want to. The repair department was probably too expensive to keep. Or maybe there is more money in selling you a new one for $1,000 than repairing yours for 295$. I just looked mine up again. That’s what they overhauled it for 2 years ago when the bearings wend bad. Remember this is Kelly, they’re not known for quality or caring about the customer to begin with Edited February 28, 2018 by jetdriven Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted February 28, 2018 Report Share Posted February 28, 2018 23 hours ago, BDPetersen said: To answer myself, turns out a loose lug on the field c/b was the culprit. Tightened and stability returns to the electrical department. Who knew. Maybe Plane Power alternators never need to be fixed. Dang, I was going to suggest checking that. Ask your A&P to clean the lug terminals at the next annual, too. Quote Link to comment Share on other sites More sharing options...
mooniac15u Posted February 28, 2018 Report Share Posted February 28, 2018 42 minutes ago, jetdriven said: Or maybe there is more money in selling you a new one for $1,000 than repairing yours for 295$. I just looked mine up again. That’s what they overhauled it for 2 years ago when the bearings wend bad. Remember this is Kelly, they’re not known for quality or caring about the customer to begin with The Plane Power AL12-P70 is currently listed for $453 at Aircraft Spruce. I believe that's the correct model for a 14V M20J. 2 Quote Link to comment Share on other sites More sharing options...
jetdriven Posted February 28, 2018 Report Share Posted February 28, 2018 522 Quote Link to comment Share on other sites More sharing options...
mooniac15u Posted February 28, 2018 Report Share Posted February 28, 2018 5 minutes ago, jetdriven said: 522 That's for the whole kit with mounting hardware. Since we were talking repair vs replace I just quoted the price for a replacement unit assuming you already had the hardware. Quote Link to comment Share on other sites More sharing options...
Andy95W Posted March 1, 2018 Report Share Posted March 1, 2018 Makes me glad I kept my InterAv alternator and only swapped out the regulator for the PlanePower. Best of both worlds. Quote Link to comment Share on other sites More sharing options...
cliffy Posted March 1, 2018 Report Share Posted March 1, 2018 I have one too but Inter Av is now dead isn't it? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 1, 2018 Report Share Posted March 1, 2018 11 minutes ago, cliffy said: I have one too but Inter Av is now dead isn't it? Isn’t Inter Av owned by QAA? Clarence Quote Link to comment Share on other sites More sharing options...
cliffy Posted March 1, 2018 Report Share Posted March 1, 2018 I thought it was dead so I'd have to change it out the next time. Quote Link to comment Share on other sites More sharing options...
Andy95W Posted March 2, 2018 Report Share Posted March 2, 2018 The InterAv can still be overhauled, quite possibly by QAA, like Clarence said. I most recently heard this at a forum recently at OSH. It seemed like it was fairly common and definitely worth checking on when the time comes. Quote Link to comment Share on other sites More sharing options...
