Porpoising leads to gear collapse accident
kortopates
Almost every CFI I know calls it "the flare". The old guy who taught me to fly said not to "flare". But rather to just pull the power off and don't let it land. It requires gently raising the nose as the speed bleeds off. Just do whatever you have to do to hold it off as long as possible without touching the power. It rolls right on every time.
Link to comment
Share on other sites
You say tomato, and I say tomaato - Let's call the whole thing off!
Link to comment
1 hour ago, Hank said:
Isn't this called the "flare"? Or is it colloquially known as "transitioning from approach attitude to landing attitude"? My CFIs and CFIIs have all called it "flaring". Maybe NJ is a special case?
In your final paragraph, you describe rounding out and say it's different from your TFAATLA, which it is. First, the plane rounds out to level flight, then flares to landing attitude. This is how we were all taught as primary students. With experience, these merge together. In my Mooney, it's a deliberate act to hold off just above the runway and continue raising the nose as speed bleeds off (i.e., I gently flare the plane) until the stall horn chirps followed by the tires.
In the Mooney, the flare is less pronounced than in Cessnas, because the airframe has so much less drag. Pay attention on your next flight, you also flare . . . .
I prefer to describe this concept in Old English:
at which hour landing the airplane i flare t above the runway
But perhaps it is different in New Jersey English?  I see at Rutger's University there are several translating and interpreting programs but none I can find specific to aeronautical issues.  But this one looks nice.  Perhaps we should all enroll in it before we discuss landing an airplane again?
http://translation.rutgers.edu
Link to comment
Do you perform a de-orbiting maneuver to go with your flaring! :D
Link to comment
I can't help but notice that your Saxon is a little rusty. Let me try:
When thou art landing thy airplane, three is the number to which thou shall count. Thou shall not count to four; neither shall thou count to two, unless thou next proceedeth unto three.
Oops, wrong chapter!  :P  Now to try again:
When ðou art landing ðine æroplane, once ðou art in ground effect ðou shūldst pulleð the yōk lightly, flāring gently to māntān thy heiÞt abovst the runwā while spēd sloweð toward stall. Once ðy æroplane doð stall, ðy whēls shūldst gently touch the earth. Ðou hast landed!
Or in more modern vernacular:
When thou art landing thine airplane, once in ground effect thou shouldst pulleth the yoke lightly, flaring gently to maintain thy height abovst the runway while speed sloweth toward stall. Once thy airplane doth stall, thy wheels shouldst gently touch the earth. Thou hast landed!
:D  :lol:  :D  :P
Link to comment
That's not Saxon - that's "Monty-Pythonish".
Ooooh now we are talking!
:D  :lol:  :D  :P
You fine sir are ready.
Link to comment
Yes, I must apologize for starting on the page detailing the operation and use of the Holy Hand Grenade. I needed to flip a few pages for How to Land Thy Aeroplane.
I think you missed a couple of “whilst” in your answer.
Link to comment
...Pay attention on your next flight, you also flare . . . .
No it's not. And no I don’t flare!
May I humbly suggest that if you find yourself needing to flare in order to slow down your airspeed control is slightly off!
  • Sad 1
Link to comment
I generally come over the numbers around 70mph, at idle throttle and descending. When I'm close to the runway, I round out to stop the descent. Stall speed is 64 mph or less.
At this point, I'm still flying, but slowing. To keep flying, I raise the nose a bit, and I slow some more, so I raise the nose a bit more . . . Eventually I reach stall speed for my exact weight and amount of flaps, the horn buzzes and the tires touch. This is called "the flare" by every pilot whom I know. Except by you, but we haven't met, leaving my previous statement true.
Maybe you can come over the numbers in an approach attitude and shift to a landing attitude at flying speed without it affecting your altitude. My Mooney, however, won't do that--if I go to landing attitude even 1mph above stall speed, I begin to gain altitude above the runway, which I don't want to do. So I flare . . .
You may continue to TFAATLA. I will continue to raise the nose of my Mooney above the runway until it stalls and touches down gently.
Link to comment
On 5/19/2018 at 11:37 AM, Mooneymite said:
I believe that every Mooney pilot can profit from the skills acquired flying a tail wheel airplane and becoming proficient at full stall landings.  Not full stall landings where you stall and come crashing down the last foot, but full stall landings timed to gently land on all three wheels.  Those are skills that can transfer directly to landing the Mooney.
And, if you lack access to a real taildragger, I have found that putting in simulated landings in the P51 Mustang for DCS: World always improves my Mooney landings.  Pretty much the same laminar-flow wing on that bird, but much heavier and much more powerful (read: wants to fly much, much faster).  If you can control your energy in that well enough to make 3-point landings to a safe rollout, then the Mooney is a cake walk by comparison.
Link to comment
When wad the last time you practiced slow flight at MCA in landmg configuration? What’s your pitch attitude? Certsinly not as high as when clean. If you lose sight of the runway you’re too fast.
Link to comment
Who said lose sight of the runway? AoA at 70mph is lower than at 64mph. Raise the nose at 70 to where it should be at 64 leads to ballooning.
Link to comment
I’m so glad I sold my Mooney and bought a Piper, it’s so much easier to land with a 600 pound 400 HP engine and simple oleo struts instead of trailing link land O matic gear like a Mooney.
Edited by M20Doc
Link to comment
That's not a flare! That’s transitioning!! Very nicely done!
I would have called that a flare.  The definition given by Hank appears to match what we saw in that video.
What is your definition for "flare"?
Link to comment
According to Peter Garmin, it’s all fake news:
http://www.boldmethod.com/learn-to-fly/maneuvers/how-to-time-your-flare-and-touchdown-for-a-perfect-landing/
http://www.aeroskytech.com/english/flare/flare.html
https://www.skybrary.aero/index.php/Landing_Flare
And if one with FLAIR!
https://www.aopa.org/news-and-media/all-news/2017/june/flight-training-magazine/landing-with-flair
Link to comment
Let's see what Wolfgang Langewiesche had to say:
To finish the discussion:
Edited by Hank
Link to comment
