HawkDriver Posted January 2, 2018 Report Share Posted January 2, 2018 Anyone have a KLN 94 maybe laying around that they would be willing to get rid of? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 3, 2018 Report Share Posted January 3, 2018 There had been one in The for sale section a while ago. They are not very popular since the advent of WAAS approaches. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
SantosDumont Posted January 3, 2018 Report Share Posted January 3, 2018 I have a 89B in my plane, it only does GPS approaches. If I could get a 94 for like $500 I’d do it since the 94 has the VOR and ILS overlays and is a plug and play replacement. More than $500 tho I might as well upgrade to a Garmin 650. 1 Quote Link to comment Share on other sites More sharing options...
Wayne Cease Posted January 3, 2018 Report Share Posted January 3, 2018 The 650 is going to be quite a bit more than $500. You will get LPV approaches and the ability to put Victor airways into the flight plan, and another nav/com radio. If you have the money I'd go for the 650.Sent from my SM-G950U using Tapatalk Quote Link to comment Share on other sites More sharing options...
MIm20c Posted January 3, 2018 Report Share Posted January 3, 2018 6 hours ago, SantosDumont said: I have a 89B in my plane, it only does GPS approaches. If I could get a 94 for like $500 I’d do it since the 94 has the VOR and ILS overlays and is a plug and play replacement. More than $500 tho I might as well upgrade to a Garmin 650. The 89b sells for $400 ish are you looking for a free upgrade? For a $700 delta you could upgrade to a 94. A healthy savings from a $12k 650. Quote Link to comment Share on other sites More sharing options...
SantosDumont Posted January 3, 2018 Report Share Posted January 3, 2018 Yeah but the 94 is just a bandaid... going to have to upgrade to the 650 or equivalent anyway to get a WAAS source for ADS-B compliance. So if I was going to spend more than $500 might as well put it into a more permanent solution. Quote Link to comment Share on other sites More sharing options...
cctsurf Posted January 3, 2018 Report Share Posted January 3, 2018 2 minutes ago, SantosDumont said: going to have to upgrade to the 650 or equivalent anyway to get a WAAS source for ADS-B compliance. So if I was going to spend more than $500 might as well put it into a more permanent solution. Yes, you can use a 650 for ads-b, however, it's a really expensive way to get there. It also makes your ads-b compliance rely on an extra, really expensive piece of equipment (you also have 2 points of failure). All of the solutions that have been suggested to me have an internal waas source and can accept a gps source input from something like a 650. This gives you a cheaper path to ads-b and makes your gps source redundant when (and if, in my case) you install the 650. Quote Link to comment Share on other sites More sharing options...
SantosDumont Posted January 3, 2018 Report Share Posted January 3, 2018 Hmm. So if I do a Garmin 345 with internal WAAS and a 650 then it will failover to the internal source automatically? Quote Link to comment Share on other sites More sharing options...
cctsurf Posted January 3, 2018 Report Share Posted January 3, 2018 3 hours ago, SantosDumont said: Hmm. So if I do a Garmin 345 with internal WAAS and a 650 then it will failover to the internal source automatically? I can't say that, I'm really not up on the Garmin stuff, however, the ones I have been told about can accept position sources from internal as well as external. At that point it should be just software. 'course that doesn't mean it would work automagically. Quote Link to comment Share on other sites More sharing options...
HawkDriver Posted January 3, 2018 Author Report Share Posted January 3, 2018 So does anyone have any leads on a KLN 94? I’m not worried about the ADS-B requirements yet. I’ll worry about that next yearSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 4, 2018 Report Share Posted January 4, 2018 The Garmin website has some really interesting explanations for how their stuff works including how to add a WAAS source for ADSB out to their existing equipment that may not have a WAAS source.... a box and antenna for under an amu... I was just reading to see if I could get a touch screen update to my all analog display O. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Davarron Posted May 13, 2018 Report Share Posted May 13, 2018 @HawkDriver If you are still looking for a KLN 94 GPS, I may have one coming available end of June. It works perfectly. Doing some avionics upgrades and was thinking about pulling that out as well. Not sure on a price but it would include everything. Database current as of this cycle. Quote Link to comment Share on other sites More sharing options...
cliffy Posted May 13, 2018 Report Share Posted May 13, 2018 Each ADSB solution has its own WAAS unit specifically required to have a matching system for latency requirements. Not all WAAS motors can be used with just any ADSB solution. Each one is individually certified. One must pick and choose wisely. Quote Link to comment Share on other sites More sharing options...
steingar Posted May 14, 2018 Report Share Posted May 14, 2018 I do know a fellow trying to sell one in the environs of BJJ if the OP is still looking. Quote Link to comment Share on other sites More sharing options...
MBDiagMan Posted May 14, 2018 Report Share Posted May 14, 2018 I am going to the avionics shop for ADS-B upgrade on Monday. If the transponder they take out is that one, I will let you know and see if you want it for shipping cost. 8 know it is a King. Quote Link to comment Share on other sites More sharing options...
HawkDriver Posted May 15, 2018 Author Report Share Posted May 15, 2018 [mention=16193]HawkDriver[/mention] If you are still looking for a KLN 94 GPS, I may have one coming available end of June. It works perfectly. Doing some avionics upgrades and was thinking about pulling that out as well. Not sure on a price but it would include everything. Database current as of this cycle. How much are you wanting for it?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Davarron Posted May 15, 2018 Report Share Posted May 15, 2018 5 minutes ago, HawkDriver said: How much are you wanting for it? Sent from my iPhone using Tapatalk I would do $1750 including shipping. I also have the database updater Quote Link to comment Share on other sites More sharing options...
Davarron Posted September 22, 2018 Report Share Posted September 22, 2018 @HawkDriver My KLN94 is still available and at a great price as I've heard. Not sure if you were still looking but it's still available. Quote Link to comment Share on other sites More sharing options...
HawkDriver Posted September 22, 2018 Author Report Share Posted September 22, 2018 Still for $1750?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Davarron Posted September 22, 2018 Report Share Posted September 22, 2018 1 hour ago, HawkDriver said: Still for $1750? Sent from my iPhone using Tapatalk @HawkDriver Yeah I’ll honor $1,750 Quote Link to comment Share on other sites More sharing options...
HawkDriver Posted September 22, 2018 Author Report Share Posted September 22, 2018 Thanks for the offer, I’ll probably just hold off for a garmin if I’m going to be spending that much.Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
