Geoff Posted December 27, 2017 Report Share Posted December 27, 2017 Removed from 1982 M20K (intercooled) for JPI upgrade for sale: Factory cluster gauges Manifold gauge (intercooled) RPM gauge Hoskins FT101 fuel flow CDT/TIT gauge Quote Link to comment Share on other sites More sharing options...
charlesual Posted December 29, 2017 Report Share Posted December 29, 2017 Hi,What are you asking for the instrument cluster gauges? Are they all working?Thanks,Charlie Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Geoff Posted December 29, 2017 Author Report Share Posted December 29, 2017 10 hours ago, charlesual said: Hi, What are you asking for the instrument cluster gauges? Are they all working? Thanks, Charlie Sent from my iPhone using Tapatalk PM sent Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted December 29, 2017 Report Share Posted December 29, 2017 Make sure you know if you need the 14v gauge cluster or the 28v cluster. Quote Link to comment Share on other sites More sharing options...
Geoff Posted December 29, 2017 Author Report Share Posted December 29, 2017 1 hour ago, gsxrpilot said: Make sure you know if you need the 14v gauge cluster or the 28v cluster. The unit for sale is a 14v and is spoken for at this time. Quote Link to comment Share on other sites More sharing options...
Geoff Posted March 4, 2018 Author Report Share Posted March 4, 2018 Cluster gauge is sold all else is available. Quote Link to comment Share on other sites More sharing options...
TargetDriver Posted March 8, 2018 Report Share Posted March 8, 2018 (edited) Just checking on the CDT/TIT gauge. Are the sensors available for them too? My CDT side failed, before I bought the plane and just "INOP'd" that side. The previous owner said they were expensive and he didn't want to replace. I've got an annual starting in several weeks, will be time to get one one way or the other. Edited March 8, 2018 by TargetDriver Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 9, 2018 Report Share Posted March 9, 2018 Compressor side should last nearly forever... it is in clean air, at not so high temps, a couple of hundred degrees... not like the TIT, that suffers from chemical erosion in the fire... Might want to check the wiring to see where it broke... PP thoughts only, a CB at heart... best regards, -a- Quote Link to comment Share on other sites More sharing options...
Marcopolo Posted March 12, 2018 Report Share Posted March 12, 2018 TD, You might want to check your Type Cert for the ship's CDT/TIT gauge. If I'm not mistaken (and I was once) both sides are required equipment for airworthiness. Placarding inop is not an option due to both gauges having red-line limits in the POH, be careful. I have played with an intermittent issue on the CDT side of my ship's gauge for quite a while now, finally found a connection issue that seams to have solved it. Good Luck, +1 for Lasar and their ability to refurbish the gauge and supply a new probe. Ron 1 Quote Link to comment Share on other sites More sharing options...
CaptRJM Posted March 12, 2018 Report Share Posted March 12, 2018 There are at least 3 versions of the TIT/CDT gauge. Two versions have a 6 pin connector but with different internal wiring and there is a version with a 5 pin connector. They are all 14 volt and are not interchangeable. My IA went round and round on what he thought was a gauge problem a while back. That’s how we discovered the different gauges. The entire situation was painful but he finally prevailed! Quote Link to comment Share on other sites More sharing options...
TargetDriver Posted April 23, 2018 Report Share Posted April 23, 2018 A, Marco and Capt R, Sorry for the late reply. Finally finished that 1 year deployment in Afganland ... was back home just long enough to pull the cowlings off and swap 12 bright new shiny Fine wire plugs in the beginning stage of an annual, then had to leave again for a month. Will be reunited with my Mooney Mistress in 2 weeks to continue. Thanks for the heads up on the CDT gauge. I'll definitely be checking the type cert. I bought the plane 3 years ago now and its been through my prebuy and annual by a very reputable shop and had my 1 annual...no idea how many annuals the previous owner (he passed away at 84 yrs old and owned it for 26 yrs) had with it Inop. All they told me was that he never replaced the sensor becasue it cost about 1G they thought. I will definitely start chasing wires in this annual though. Thanks guys ! ...Just realized I get to change my location in my profile !!! Ha No Mo' war zone ! Quote Link to comment Share on other sites More sharing options...
carusoam Posted April 23, 2018 Report Share Posted April 23, 2018 Welcome back again TD! Hopefully good news... a CDT doesn’t sit in a terrible environment like TIT. It should be pretty easy to pull, inspect, test, look for bad connection or broken wire. A 1amu thermocouple? CB PP thoughts only, not a CB mechanic... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
willerjim273 Posted June 17, 2019 Report Share Posted June 17, 2019 Were you able to sell all your items? Looking for a TIT/CDT Tks Quote Link to comment Share on other sites More sharing options...
dan nephin Posted June 17, 2019 Report Share Posted June 17, 2019 Willerjim, I have atit/cdt gauge from a 231 for sale as well if this one is gone. Check in avionics for sale under misc Dan Quote Link to comment Share on other sites More sharing options...
