cctsurf Posted December 25, 2017 Report Share Posted December 25, 2017 1 hour ago, Captnmack said: OR....You can buy a new set up from Electro Air in Mi. and get rid of the switch. Just looked at their documentation... It doesn't get rid of key switch as far as I can tell... http://www.electroair.net/pdfs/EIS_41000_Installation_Manual.pdf Quote Link to comment Share on other sites More sharing options...
Captnmack Posted December 26, 2017 Report Share Posted December 26, 2017 20 hours ago, cctsurf said: Just looked at their documentation... It doesn't get rid of key switch as far as I can tell... http://www.electroair.net/pdfs/EIS_41000_Installation_Manual.pdf Quote Link to comment Share on other sites More sharing options...
cctsurf Posted December 26, 2017 Report Share Posted December 26, 2017 10 minutes ago, Captnmack said: So, a $269 plus a $3,570 ignition module is an adequate replacement for even a $542 ignition switch? "Installation of this STC requires the installation of either STC#SA02987CH or STC#SA03286CH (the Electroair Electronic Ignition System)" (Which I would never pay that for the switch..., equivalent switches can be signed off by an IA or A&P any day of the week http://www.aircraftspruce.com/catalog/elpages/igswitches.php?clickkey=5735) The OP has brand new magnetos last year. I'd love the Electroair ignition, but not to help with an ignition switch problem. Actually I'd prefer the E-Mag or P-mag system, but I don't think that they are Approved yet. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 27, 2017 Report Share Posted December 27, 2017 1 hour ago, Skmoore63 said: I wish I could remember which switch I have. One is the Bendix and the other type is a ?????. My mechanic bought a rebuild kit and replaced all the worn components within the switch. I think the kit was $150 and his labor was around $150. Memory fading (it was a whole year and half ago), it has worked perfectly since. The rebuild could be an option depending on the brand of the switch? ACS Gerdes, no Mooney’s are on the approved list for this series of switch. Clarence Quote Link to comment Share on other sites More sharing options...
Dream to fly Posted January 3, 2018 Author Report Share Posted January 3, 2018 Thank you @M20Doc! Found the problem. AP found a wire not making contact with the retard points set. Prop swings maybe 1 whole revolution and we have instant RPM. Thank you for the Diagnostics. I am assuming the P lead was not grounding is what he is talking about. Your instructions zeroed in on the problem in no time flat. Thanks again. 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted January 3, 2018 Report Share Posted January 3, 2018 2 hours ago, Dream to fly said: Thank you @M20Doc! Found the problem. AP found a wire not making contact with the retard points set. Prop swings maybe 1 whole revolution and we have instant RPM. Thank you for the Diagnostics. I am assuming the P lead was not grounding is what he is talking about. Your instructions zeroed in on the problem in no time flat. Thanks again. I’m glad you found and fixed the problem. Clarence Quote Link to comment Share on other sites More sharing options...
carusoam Posted January 4, 2018 Report Share Posted January 4, 2018 Always good to have the Doc on board! I learn something new or interesting at least weekly. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
