ziggysanchez Posted December 14, 2017 Report Share Posted December 14, 2017 (edited) Recently my right fuel quantity gauge will show accurately until I'm below 25 gallons. Any amount of fuel below 25 gallons shows as 25 gallons. I had the JPI 900 installed in my 231 last October. The fuel senders were sent out for overhaul at that time and have given me fairly accurate readings til now. The JPI was a replacement for all my primary gauges. Any suggestions or recommendations? Edited December 14, 2017 by ziggysanchez Quote Link to comment Share on other sites More sharing options...
M20JFlyer Posted December 14, 2017 Report Share Posted December 14, 2017 Xziggy I have a JPI830 soo my comments may be mute..but I was not aware the JPI products used a volume in the tank sensor With the JPI 830 your fuel is dependent on a value you program less that USED as provided by a very accurate flow meter . Bring me up to speed on features of the 900 series . Does JPI compute fuel remaining from tank senders or flow meters for each tank?! Quote Link to comment Share on other sites More sharing options...
ziggysanchez Posted December 14, 2017 Author Report Share Posted December 14, 2017 The EDM 900 has a totalizer but also serves as a replacement for my old analog primary gauges including my fuel gauges. The JPI displays fuel remaining in both tanks in gallons (see pic below). Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted December 14, 2017 Report Share Posted December 14, 2017 If you have 2 fuel senders for each tank in you system the inboard fuel sensor may not be working correctly. Just a guess. Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted December 14, 2017 Report Share Posted December 14, 2017 Check the voltage on the inboard when the tank is low. The maintenance manual shows the process. -Robert 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted December 14, 2017 Report Share Posted December 14, 2017 11 hours ago, ziggysanchez said: Recently my right fuel quantity gauge will show accurately until I'm below 25 gallons. Any amount of fuel below 25 gallons shows as 25 gallons. I had the JPI 900 installed in my 231 last October. The fuel senders were sent out for overhaul at that time and have given me fairly accurate readings til now. The JPI was a replacement for all my primary gauges. Any suggestions or recommendations? Hi Ziggy. I got so frustrated with the JPI error messages (fuel mismatch) that I pulled my resistive senders and installed the CiES solution. As noted above, I think you have 4 senders in your fuel system. The older Mooneys had 2. The outer sender allows for measurement until the inner sender provides readings. It is needed for the larger capacity fuel systems (64 gallons) because of the wing shape. It really sounds like the inner sender isn't working. The outer sender would hit the bottom of the tank and show 25 gallons and the inner sender isn't providing any input. Quote Link to comment Share on other sites More sharing options...
Mooneymite Posted December 14, 2017 Report Share Posted December 14, 2017 When I have fuel quantity indication accuracy problems, it is usually cleared up by cleaning the grounding. 1 Quote Link to comment Share on other sites More sharing options...
ziggysanchez Posted December 14, 2017 Author Report Share Posted December 14, 2017 1 hour ago, Mooneymite said: When I have fuel quantity indication accuracy problems, it is usually cleared up by cleaning the grounding. Yeah...that was the first thing I did. I was hoping that’s all it was. No cigar. Next step I guess is sending this fuel sender out for repair. I’m not yet ready to invest the time for replacing all of them. Maybe when I have the tanks resealed I’ll upgrade. Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted December 14, 2017 Report Share Posted December 14, 2017 2 hours ago, Mooneymite said: When I have fuel quantity indication accuracy problems, it is usually cleared up by cleaning the grounding. Are you referring to the mounting screws at the sender or grounding at the gauge? -Robert Quote Link to comment Share on other sites More sharing options...
Mooneymite Posted December 14, 2017 Report Share Posted December 14, 2017 4 hours ago, RobertGary1 said: Are you referring to the mounting screws at the sender or grounding at the gauge? -Robert Yes. Both. I have the old analog gauges. I have no clue about the digital displays. Quote Link to comment Share on other sites More sharing options...
Guest Posted December 14, 2017 Report Share Posted December 14, 2017 You could remove the interior enough to expose the two inner transmitters, remove the wires then using a pair of jumpers crisscross them to determine which unit is at fault. Clarence Quote Link to comment Share on other sites More sharing options...
carusoam Posted December 15, 2017 Report Share Posted December 15, 2017 Rebuilding the old technology... Or make the jump to lightspeed... You have gone digital on the front end, it may make sense to go digital on the back end... Marauder already showed the way forward... PP thoughts only, I still have the analog things... would love some Cies floats and a JPI 900... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
