MV Aviation
Fuel tank calibration and dip stick production
Hi Folks,
a friend of mine is about to launch an online shop for fuel tank dip sticks. It is just a hobby-side-endeavor for him, so I'm trying to support him with data. The shop is not yet online, but production will start soon. And he will ship worldwide ;-). The dipsticks will be in the 15-20$ range.
 He has collected Data for some PA28, C172, and Aquila models. I sent him the data of my 65E's fuel tanks. In order to offer more models and confirm the existing data, I'd like to ask you to send me your measurements if you have some. Text files, Excel sheets, ... doesn't matter, as long as you're confident with the data :-)
Your support is much appreciated!
Thanks a lot!
Marco
24993016_1716958348357073_1714857540_o.thumb.png.f77a729cea388ecc9baf27f82bca1a9e.png
Share this post
Link to post
Share on other sites
*Members that donate $10 or more do not see advertisements*
Somebody send this guy a good M20J/64gal tank calibration!   I'd definitely buy one.
Share this post
Link to post
Why not just make your own?  Use a paint stirring stick and a ball-point pen.  Lowes or Home Depot will give you one for free, and you probably have a pen lying around.  I made mine that way 5 years ago and it hasn't yet discolored or faded.
Run a tank empty, then add 2 gallons at a time.  At least then you'll be 100% sure it's correct.
Or look around MooneySpace, someone might have already posted the measurements like they did for the M20C/E.  The M20F with 64 gallon tanks should be identical to the J.
Share this post
Link to post
There is so much variation in fuel tank capacity of same model Mooney's reported by different owners I would never trust anyone else data. The whole point of the exercise that Andy refers to above is to find out what your tank capacity is. Don't you want to know what your tanks really holds?
Share this post
Link to post
29 minutes ago, kortopates said:
...Don't you want to know what your tanks really holds?
Naw, I'd rather worry the the gauges are all wrong and I better be on the ground with at least 15 gallons indicated remaining. :rolleyes:
  • Sad 1
Share this post
Link to post
The variation on make your own.   Free paint stirrer.  The thicker ones from Sherwin Williams are the best.  When refueling Stick the tank draw the line. Fuel it up..   Do the math.  Write the gallons on the line.   Sharpies work well too.   Takes several fuel ups, but will be really accurate.   I use the middle of the filler neck most inner point.
Share this post
Link to post
I suspect the variations are due to how people are taking data rather than actual tank dimensions or capacities.   Or did Mooney actually change the tank shape significantly over production runs for similar models?
If I were to make my own stick I think I'd use the "mark it before you fill it and see what it took" method until I had a decent calibration, but if I could buy one I'd rather save myself the effort.
Share this post
Link to post
There are so many ways to place the stick in the tank its difficult to use someone else's numbers without a video describing how they place the stick.
-Robert
Share this post
Link to post
Yep... I'd not trust anyone's stick but my own.
  1. Too many different ways to place the stick.
  2. Have the tanks been resealed... and what was the quality of the stripping/resealing.
  3. Bladders or no bladders
  4. Between the neck in the filler and the holes between sections of tank in my K, the speed of the fuel filling operation also makes a difference.
  5. etc, etc, etc...
I'll run a tank dry and work it out myself, thanks.
Share this post
Link to post
I bought a FuelHawk gauge and did mine manually. Its accurate to 0.2 +/- gal. Averaging 8.7gph block to block when I dip before and after flights. I've even been down into the mid 7-gph range on some slow <145kt flights
Share this post
Link to post
I made a sick for my C from someone's numbers, I think from here on Mooneyspace.  I verified it's accuracy by always sticking the tank before I topped off.  It was spot on.
If anyone has numbers for a K I would love to try them out.  I'm still waiting for a convenient time to run my tank dry and meter the fill up.
The difference in filling fast vs slow can be up to 3gal a side.  I have been finding if I'm not present or don't personally fuel the plane I'm always 3-6gals short.  Drives me crazy.
Cheers,
Dan
Share this post
Link to post
I've done my K but just used the wing mounted gauges instead of making a stick.  I ran each of the tanks dry on different flights. After landing I filled each tank in 5 gal increments and noted how that was displayed on the wing mounted gauges. I also noted how it was displayed on the EDM-900 digital gauges as well. Between both of those very accurate gauges, I decided I didn't need a stick. I keep the diagram and notes tucked into the front cover of my POH for easy reference.
Share this post
Link to post
Unfortunately I don’t have wing mounted gauges.  If I did I would forgo the stick too.  EDM 900 is going in on the 1st of the year.:)
Cheers,
Dan
Share this post
Link to post
Cheers,
Dan
I'd recommend the CiES senders to go with the EDM-900.
Share this post
Link to post
Are the wing mounted gauges certified for use to fulfill Tomato Flames requirement?
Share this post
Link to post
I love the wing mounted gauges. One of mine has a cloudy lens that I'd like to either replace or figure out how to clean.
Share this post
Link to post
Might get away with headlight polish for that, Paul... But, I think the cracking may go deeper than the surface... get a price from Lasar, they probably aren't measured in AMUs...
Tomato flames is not very specific about what is used for a fuel level... but...
the MEL in the POH is pretty specific on what needs to be working.
Pp thoughts only, not a CFI...
Share this post
Link to post
If you don't mind paying $50 each, they are very easy to change.
Share this post
Link to post
Is it the gauge or the gauge and whole assembly?
I, too, have a cloudy one but not enough that I want to mess up my paint to replace.
Share this post
Link to post
You won't mess up the paint. The gauge is a simple dial with a metal bottom and a clear plastic top. It is fed magnetically from a sender in the wing plate. The gauge is held in with silicone glue. You pry out the old one with a thin screwdriver or some such. Clean out the remaining silicone, then put a glob of silicone in the recess, push the gauge in place and tape it down until the silicone sets up. Done. The gauge even has a little bump on it so it only sits in place one way, so you won't put I in wrong.
Share this post
Link to post
Same thing I did. I did the paint stirrer for awhile but really like the FuelHawk and reading it. Just be sure if you use one that after you put it in let it sit for a couple seconds before putting your finger over the top. If not then the fuel level inside it may not be at the same level as the tank if you don't let it settle.
Share this post
Link to post
just dont run one dry like you did the last time, Dan :)
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
