Philip
G5’s installed - pickup tomorrow
Just now, N201MKTurbo said:
It modifies the heading error signal from the DG. You put the radio coupler in heading mode so it doesn't use the nav error.
Cool.  Sounds like I’ll be selling my accutrak then!
Share this post
Link to post
Share on other sites
*Members that donate $10 or more do not see advertisements*
I'm sorry but your autopilot is not on the list.
Share this post
Link to post
I’ve been advised by Brittain and garmin that It is on the new revision that will release any day now.
Share this post
Link to post
Good luck!
Share this post
Link to post
Where did you get that list? The latest Certified Install manual I could find onlinel, Rev. 11, says (for Cessna)
If the 300A is supported, that would make all the difference for me.
Edited by MarcK
spelling correction
Share this post
Link to post
Welcome aboard, Marck.
We have @TrekLawler around here often...
Trek is a Garmin Tech Guy...
He doesn't visit very often.  Is more likely to be found kicking around at BT...
It looks like the 300A has been left off the list for a reason.
Good luck.
Share this post
Link to post
For anyone installing G5's & GAd29b to the beloved Brittain, pm me for advice.
Good luck.
The 300A is the ACV version of the 300.   The 300B is the DCV version.    They are both still in the automated configuration menu of the primary G5 in the current firmware.  There are some different pin assignments on the GAD though.
Share this post
Link to post
The 300A is supported and has an automated config setting in the menu.  I think the above image was an oversight because there is just a 300A (AC) and 300B (DC).
Share this post
Link to post
Go to page 5 of this post and read a post from Trek Lawler from Garmin on November 10. The 300A is not supported - the early manual was wrong.
https://www.beechtalk.com/forums/viewtopic.php?f=21&t=142609&hilit=300A
5a57a23f1c2eb_ScreenShot2018-01-11at11_41_35AM.thumb.png.96dba268b0ef40c454b2fc4a23b8d301.png
Share this post
Link to post
Strange, I didn’t realize they intentionally removed it, as the 300A is one of the config settings in the current g5 firmware and according to a volt meter, it sends AC signals, albeit the pretty low levels.   Perhaps that’s why it got removed.  The g502a that the 300a uses for heading signal puts out levels much higher than what the G5/gad auto config was sending out for the 300a.
Although it was removed from the list, I believe it is technically possible to achieve a working connection at least through the customized output settings, though not legal.  Any avionics tech with a volt meter should be able to figure it out pretty easily by referencing the g502a.
Share this post
Link to post
resurrecting this thread, as I just got an email from Ceci at Brittain... It seems they are trucking along and Brittain will survive one way or another.   She sent me the attached prelim drawings that they are working again on getting Brittain APs added to Garmin's STC.   These drawings are a little more complicated than another way that the system can also operate.   Attached for everyone to keep record.  ;)
Brittain G5 Dwg Rev A.pdf
G5 Hook Up, No Transformers.pdf
Share this post
Link to post
I installed the G5 in my 65 E model .    accuflite and accutrac ,   the heading bug drives the accuflite and the Garmin 400w drives the accutrack ,     Or throw the switch and the old Narco vor drives the accutrac.   Like the manual says it holds,   not intercept but ...  I really wanted my heading bug, and was relieved it worked.
dc
Share this post
Link to post
I just thought I would add my install that was completed over the weekend. 2 G5's and JPI EDM 900 a couple weeks ago.   The left side only needs a new panel to get rid of all the covered holes ( I will do that when I do the GPS ETC )
Share this post
Link to post
I’m a week behind you. When I redo my panel I’m going to move the G5s up a little for better access to the HSI knob, with engine gauges gone there is plenty of room,on my J is too near to the yoke shaft for my tastes.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
