Browncbr1 Posted December 4, 2017 Report Share Posted December 4, 2017 Just now, N201MKTurbo said: It modifies the heading error signal from the DG. You put the radio coupler in heading mode so it doesn't use the nav error. Cool. Sounds like I’ll be selling my accutrak then! Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted December 4, 2017 Report Share Posted December 4, 2017 1 minute ago, Browncbr1 said: Cool. Sounds like I’ll be selling my accutrak then! I'm sorry but your autopilot is not on the list. Quote Link to comment Share on other sites More sharing options...
Browncbr1 Posted December 4, 2017 Report Share Posted December 4, 2017 Just now, N201MKTurbo said: I'm sorry but your autopilot is not on the list. I’ve been advised by Brittain and garmin that It is on the new revision that will release any day now. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted December 4, 2017 Report Share Posted December 4, 2017 Just now, Browncbr1 said: I’ve been advised by Brittain and garmin that It is on the new revision that will release any day now. Good luck! Quote Link to comment Share on other sites More sharing options...
OR75 Posted December 31, 2017 Report Share Posted December 31, 2017 any chance you could take a picture of the G11 mount ? thanks Quote Link to comment Share on other sites More sharing options...
MarcK Posted December 31, 2017 Report Share Posted December 31, 2017 (edited) On 12/4/2017 at 5:18 AM, N201MKTurbo said: I'm sorry but your autopilot is not on the list. Where did you get that list? The latest Certified Install manual I could find onlinel, Rev. 11, says (for Cessna) If the 300A is supported, that would make all the difference for me. Edited December 31, 2017 by MarcK spelling correction Quote Link to comment Share on other sites More sharing options...
carusoam Posted December 31, 2017 Report Share Posted December 31, 2017 Welcome aboard, Marck. We have @TrekLawler around here often... Trek is a Garmin Tech Guy... He doesn't visit very often. Is more likely to be found kicking around at BT... It looks like the 300A has been left off the list for a reason. Good luck. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Browncbr1 Posted January 11, 2018 Report Share Posted January 11, 2018 For anyone installing G5's & GAd29b to the beloved Brittain, pm me for advice. On 12/31/2017 at 4:42 PM, carusoam said: Welcome aboard, Marck. We have @TrekLawler around here often... Trek is a Garmin Tech Guy... He doesn't visit very often. Is more likely to be found kicking around at BT... It looks like the 300A has been left off the list for a reason. Good luck. Best regards, -a- The 300A is the ACV version of the 300. The 300B is the DCV version. They are both still in the automated configuration menu of the primary G5 in the current firmware. There are some different pin assignments on the GAD though. 1 Quote Link to comment Share on other sites More sharing options...
Browncbr1 Posted January 11, 2018 Report Share Posted January 11, 2018 On 12/31/2017 at 3:13 PM, MarcK said: Where did you get that list? The latest Certified Install manual I could find onlinel, Rev. 11, says (for Cessna) If the 300A is supported, that would make all the difference for me. The 300A is supported and has an automated config setting in the menu. I think the above image was an oversight because there is just a 300A (AC) and 300B (DC). Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted January 11, 2018 Report Share Posted January 11, 2018 1 hour ago, Browncbr1 said: The 300A is supported and has an automated config setting in the menu. I think the above image was an oversight because there is just a 300A (AC) and 300B (DC). Go to page 5 of this post and read a post from Trek Lawler from Garmin on November 10. The 300A is not supported - the early manual was wrong. https://www.beechtalk.com/forums/viewtopic.php?f=21&t=142609&hilit=300A Quote Link to comment Share on other sites More sharing options...
Browncbr1 Posted January 11, 2018 Report Share Posted January 11, 2018 11 minutes ago, LANCECASPER said: Go to page 5 of this post and read a post from Trek Lawler from Garmin on November 10. The 300A is not supported - the early manual was wrong. https://www.beechtalk.com/forums/viewtopic.php?f=21&t=142609&hilit=300A Strange, I didn’t realize they intentionally removed it, as the 300A is one of the config settings in the current g5 firmware and according to a volt meter, it sends AC signals, albeit the pretty low levels. Perhaps that’s why it got removed. The g502a that the 300a uses for heading signal puts out levels much higher than what the G5/gad auto config was sending out for the 300a. Although it was removed from the list, I believe it is technically possible to achieve a working connection at least through the customized output settings, though not legal. Any avionics tech with a volt meter should be able to figure it out pretty easily by referencing the g502a. Quote Link to comment Share on other sites More sharing options...
Browncbr1 Posted February 13, 2018 Report Share Posted February 13, 2018 resurrecting this thread, as I just got an email from Ceci at Brittain... It seems they are trucking along and Brittain will survive one way or another. She sent me the attached prelim drawings that they are working again on getting Brittain APs added to Garmin's STC. These drawings are a little more complicated than another way that the system can also operate. Attached for everyone to keep record. Brittain G5 Dwg Rev A.pdf G5 Hook Up, No Transformers.pdf 1 Quote Link to comment Share on other sites More sharing options...
DOCCOUNTRY Posted April 1, 2018 Report Share Posted April 1, 2018 I installed the G5 in my 65 E model . accuflite and accutrac , the heading bug drives the accuflite and the Garmin 400w drives the accutrack , Or throw the switch and the old Narco vor drives the accutrac. Like the manual says it holds, not intercept but ... I really wanted my heading bug, and was relieved it worked. dc Quote Link to comment Share on other sites More sharing options...
wcb Posted April 2, 2018 Report Share Posted April 2, 2018 I just thought I would add my install that was completed over the weekend. 2 G5's and JPI EDM 900 a couple weeks ago. The left side only needs a new panel to get rid of all the covered holes ( I will do that when I do the GPS ETC ) 3 Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted April 2, 2018 Report Share Posted April 2, 2018 I just thought I would add my install that was completed over the weekend. 2 G5's and JPI EDM 900 a couple weeks ago. The left side only needs a new panel to get rid of all the covered holes ( I will do that when I do the GPS ETC ) I’m a week behind you. When I redo my panel I’m going to move the G5s up a little for better access to the HSI knob, with engine gauges gone there is plenty of room,on my J is too near to the yoke shaft for my tastes. 1 Quote Link to comment Share on other sites More sharing options...
kris_adams Posted April 2, 2018 Report Share Posted April 2, 2018 Good idea! One day soon hopefully! Quote Link to comment Share on other sites More sharing options...
