Need to find replacement plastic thingy at end of wing which shows navs/strobes
I bought one from LASAR. Make sure you 9sitting down when asking the price, made me decide tomnot jjsg rrplace  ithnwhile i was doing it.
Also, drill the bolt holes carefully so it doesn't crack . . . But you'll need to trim it to fit your wing first.
Link to comment
Share on other sites
I always liked these things, but never really got the point.  You preflight the airplane and check the lights.  If one goes out in flight, what are you going to do, land? Or continue?  If it doesn't change my decision to continue, why have them in the first place?
Link to comment
43 minutes ago, Mike Ropers said:
Step drill bits are a good alternative to special plexy drill bits
Regular bits work if they are sharp, but you need support under the drill bit to prevent it from cracking when the tip comes through the back side.
Link to comment
