markejackson02 Posted November 8, 2017 Report Share Posted November 8, 2017 Has anyone installed a video camera inside their cowl? For some reason, I cannot keep the CHT's for #3 & #4 below 450 with the cowl flaps closed. The baffling looks okay on the ground but would like to see what it does in flight. Quote Link to comment Share on other sites More sharing options...
Raptor05121 Posted November 8, 2017 Report Share Posted November 8, 2017 I get a rise in temps when I fully close mine. I have to have them trail a bit open for the best cooling. I doubt you'll see much with a camera somehow fastened inside there, and not block airflow at the same time. Quote Link to comment Share on other sites More sharing options...
markejackson02 Posted November 8, 2017 Author Report Share Posted November 8, 2017 Just now, Raptor05121 said: I get a rise in temps when I fully close mine. I have to have them trail a bit open for the best cooling. I doubt you'll see much with a camera somehow fastened inside there, and not block airflow at the same time. I was thinking to put it on the firewall as high up as I could. This behavior is new, temps used to climb a little before when the flaps were closed but now they all rocket higher. Just did a bunch of work on the engine so thinking something didn't go back on properly. Quote Link to comment Share on other sites More sharing options...
bradp Posted November 8, 2017 Report Share Posted November 8, 2017 You can usually tell by a flashlight in the accessory compartment- look for light in the front shining from the back. Feel whether your baffles feel sturdy and whether they sit up flush along the top of the cowl cover. Those two things alone should be enough to indicate whether you will have a seal problem in flight. You should need to really push the flaps back with a lot of force with your hand to be able to flip them backwards. Look at the baffle seals along the front of the engine too. They are important to make sure air pressure differential favors flow over the cylinder fins. Also- i don’t see your model year. If manual cowl flaps set the closed position to trail slightly - about a quarter inch or so - not fully closed / sealed in the closed position. This results in much better air flow. Recent work: ensure you don’t have a fuel delivery or spark delivery problem on that side. What did you do to the engine? Do you have an engine monitor with data? Something changed. Go where the doctors have been first. Quote Link to comment Share on other sites More sharing options...
carusoam Posted November 8, 2017 Report Share Posted November 8, 2017 Using a device to observe something, but the device itself, causes a disturbance in what you are measuring... reference to Schrödinger's cat in the trunk... Many people have run into the heat challenge after maintenance... seals get old and flop out of position...or just don't seal properly anymore... We have a seal guy around here, if your seals prove to be less than worthy.... @GEE-BEE PP thoughts only, not a mechanic... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Skates97 Posted November 8, 2017 Report Share Posted November 8, 2017 4 hours ago, bradp said: You can usually tell by a flashlight in the accessory compartment- look for light in the front shining from the back. Feel whether your baffles feel sturdy and whether they sit up flush along the top of the cowl cover. Those two things alone should be enough to indicate whether you will have a seal problem in flight. You should need to really push the flaps back with a lot of force with your hand to be able to flip them backwards. Look at the baffle seals along the front of the engine too. They are important to make sure air pressure differential favors flow over the cylinder fins. Also- i don’t see your model year. If manual cowl flaps set the closed position to trail slightly - about a quarter inch or so - not fully closed / sealed in the closed position. This results in much better air flow. Recent work: ensure you don’t have a fuel delivery or spark delivery problem on that side. What did you do to the engine? Do you have an engine monitor with data? Something changed. Go where the doctors have been first. This is how I found that the seal at the top in the back of my doghouse needed to be replaced. I put a shop light back by the oil filter and looked in from the front. The gaps and holes were easy to see. This is what they looked like before. Quote Link to comment Share on other sites More sharing options...
markejackson02 Posted November 9, 2017 Author Report Share Posted November 9, 2017 I had the mag overhauled, new starter installed. Cooling has always been an issue albeit a manageable one until now. I have never had problems with the #3 cylinder until now. Was always #4 causing issues. I do have an Insight unit and will try to see if the ignition is causing some issues. At first glance on the 15 minute test flight, there was nothing apparent. The baffles are all okay looking while sitting on the ground. Quote Link to comment Share on other sites More sharing options...
Oldguy Posted November 9, 2017 Report Share Posted November 9, 2017 One of the J models at our field was having cooling issues on one side and found the small metal deflector plate between the cylinders had fallen into the bottom cowl. Might be something to check. Looking at the engine monitor data is a good place to start, but contained to a single side sounds as if it is more physical in relation to airflow, IMO. But whatever the problem is, it needs addressing as 450 degree CHTs do not help cylinders last a long time. Quote Link to comment Share on other sites More sharing options...
FloridaMan Posted November 9, 2017 Report Share Posted November 9, 2017 I'm not sure what the legality of this is, but if I were to do something like this, I would get one of those $30 wifi borescopes from Amazon that links to your phone and snake it and cable tie the box far from the heat of the engine as I wouldn't want the battery to get hot and burst into flames. 1 Quote Link to comment Share on other sites More sharing options...
markejackson02 Posted November 9, 2017 Author Report Share Posted November 9, 2017 Come at this from a different angle. There are a couple of minor bends in the baffles up against the top of the cowling. I can see them when the cowling is on. Is there a way to fix these? The material is bent this way. Anything to be done short of replacing all the silicone material? Forgive my crude drawing. Quote Link to comment Share on other sites More sharing options...
buddy Posted November 9, 2017 Report Share Posted November 9, 2017 When I had my 201 I replaced the left side cowl flap with the same one that’s used on the right with the exhaust opening and that seemed to solve the high temp problem. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 9, 2017 Report Share Posted November 9, 2017 29 minutes ago, markejackson02 said: Come at this from a different angle. There are a couple of minor bends in the baffles up against the top of the cowling. I can see them when the cowling is on. Is there a way to fix these? The material is bent this way. Anything to be done short of replacing all the silicone material? Forgive my crude drawing. You could cut a dart (little triangle) out of the material so it will lay flat. Quote Link to comment Share on other sites More sharing options...
markejackson02 Posted November 9, 2017 Author Report Share Posted November 9, 2017 31 minutes ago, N201MKTurbo said: You could cut a dart (little triangle) out of the material so it will lay flat. I tried that on one of the kinks. Cut a slit and stop drilled the end but it didn't affect anything. How often does baffling have to be replaced? Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted November 9, 2017 Report Share Posted November 9, 2017 (edited) 1 hour ago, markejackson02 said: I tried that on one of the kinks. Cut a slit and stop drilled the end but it didn't affect anything. How often does baffling have to be replaced? I don't think there is any set calendar time or number of hours. I have seen plenty of 50 year old planes that still had the factory baffle seals. If it isn't doing its job then replace it. The material isn't expensive and replaceing it it isn't that hard. Edited November 9, 2017 by N201MKTurbo Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted November 10, 2017 Report Share Posted November 10, 2017 After a kink has been in the baffle material for a while, it is tough to get it to flatten back out. I would seriously consider replacing that strip that is bad (if all the others seem OK), or all of them it there is much doubt. In aviation terms, the material is dirt cheap. Even in real life terms it is not too expensive. Quote Link to comment Share on other sites More sharing options...
markejackson02 Posted November 10, 2017 Author Report Share Posted November 10, 2017 Hit me last night. Duct tape. The engineer's solution to everything. Will test fly with the wrinkles duct taped closed and see how it works. If it works, new baffling material. If not, take the cowling off and look for problems. Quote Link to comment Share on other sites More sharing options...
triple8s Posted November 10, 2017 Report Share Posted November 10, 2017 Not sayin this is your problem but this happened to me so i thought id spit it out. When doing maintenance or just watching mechanics or spectators in the shop you will often see folks leaning over the engine and mashing down on the baffle seal with their arms. Not intentionally, just lazing around chatting but leaning over engine and bending the seals down can cause them to become less stiff and not seal against cowling. I have had this happen to mine by my own negligence. Now if i see someone leaning on my baffle seals i kindly tell them to lean on something else. Heck i have to think about not doing it myself, its natural to lean on the things. Anyhow just a little something to be on the look out for. Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted November 10, 2017 Report Share Posted November 10, 2017 My one takeaway after reading through these threads is that of incredulous. I find it incredible that a simple piece of rubber is so critical to the operation of our engines and that the precise installation and placement of that rubber dictates its efficiency, let alone someone leaning on it while the cowl is off resulting in a rise of CHT by 20 degrees. Truly a design from a bygone era. Quote Link to comment Share on other sites More sharing options...
DanM20C Posted November 10, 2017 Report Share Posted November 10, 2017 @GEE-BEE, Do you have a website? My 231 has all original baffles and seals that will need some attending to. Cheers, Dan Quote Link to comment Share on other sites More sharing options...
DanM20C Posted November 10, 2017 Report Share Posted November 10, 2017 Never mind. Google found it for me. I'll be getting in touch in the next few months. Cheers, Dan Quote Link to comment Share on other sites More sharing options...
Guest Posted November 10, 2017 Report Share Posted November 10, 2017 Baffles and the seals are the equivalent the radiator on your car. You would not drive your car with a hole in the radiator, you shouldn’t fly your plane with poor baffle seals. Clarence Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted November 10, 2017 Report Share Posted November 10, 2017 Just now, M20Doc said: Baffles and the seals are the equivalent the radiator on your car. You would not drive your car with a hole in the radiator, you shouldn’t fly your plane with poor baffle seals. Clarence True, but if one or two of the fins on the radiator are bent, the temp doesn't go through the roof. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 10, 2017 Report Share Posted November 10, 2017 Just now, flyboy0681 said: True, but if one or two of the fins on the radiator are bent, the temp doesn't go through the roof. Exactly, liquid cooling is more efficient than air cooling hence the need for closer attention to better fit and proper maintenance of baffles and seal. In the times before modern engine monitors, ignorance was bliss. Clarence Quote Link to comment Share on other sites More sharing options...
bradp Posted November 11, 2017 Report Share Posted November 11, 2017 By contrast I’m pretty happy I don’t have a water pump and thermostat to worry about when I’m flying around. Quote Link to comment Share on other sites More sharing options...
nels Posted November 11, 2017 Report Share Posted November 11, 2017 On 11/8/2017 at 7:53 PM, markejackson02 said: I had the mag overhauled, new starter installed. Are you sure the timing was set correctly after the mag was installed? Timing does have an affect on cylinder temperature. Quote Link to comment Share on other sites More sharing options...
