Cowl flap torque tube removal
Anybody know a good way to get the cowl flap torque tube out? There appears to be two bushings that need to be pushed out and they're extremely difficult to get to. Just looking to see if anybody has any tricks to get those out.
Sent from my XT1585 using Tapatalk
Link to comment
Share on other sites
Normally the bushing is in the fitting which is part of the mount.  Removing the bolts from the torque tube should allow you to pull the tube from the fittings on the mount.
I've never seen the bushings pass through the fitting and the torque tube.
Link to comment
