82Mike Posted October 16, 2017 Report Share Posted October 16, 2017 What is this missing switch? Quote Link to comment Share on other sites More sharing options...
Brandontwalker Posted October 16, 2017 Report Share Posted October 16, 2017 40 minutes ago, 82Mike said: What is this missing switch? Not sure what it is for, but it is certainly not missing and, if it were, you found it. Quote Link to comment Share on other sites More sharing options...
Marauder Posted October 17, 2017 Report Share Posted October 17, 2017 6 hours ago, 82Mike said: What is this missing switch? What's attached on the other side? Quote Link to comment Share on other sites More sharing options...
Guest Posted October 17, 2017 Report Share Posted October 17, 2017 Is it a vane to trigger the Hobbs meter? Clarence Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 17, 2017 Report Share Posted October 17, 2017 That would not be a Mooney standard switch. Looks like you may endure some humor to go with that. Based on its location, one might assume it’s a... Automatic Gear up landing alert sensor? A security switch I have no external switches on my aircraft. They would be susceptible to water intrusion. If it is connected to something important, I would really want to know what it is... what is the extra hole pattern dimpled into the access panel for? The usual screw holes seem to be riveted and not so nicely painted over. I suspect that Clarence has seen this thing before and security is in place to keep time theft from easily occurring.... I'm really curious.... why is there a piece of tape left there? Best regards, -a- Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted October 17, 2017 Report Share Posted October 17, 2017 From the looks of the cutout it certainly isn't Mooney factory. what happens when you turn it on? Quote Link to comment Share on other sites More sharing options...
Mark89114 Posted October 17, 2017 Report Share Posted October 17, 2017 7 hours ago, N201MKTurbo said: From the looks of the cutout it certainly isn't Mooney factory. what happens when you turn it on? Or is it already turned OFF? Quote Link to comment Share on other sites More sharing options...
TWinter Posted October 17, 2017 Report Share Posted October 17, 2017 Stealth Mode. Makes you invisible to radar, ground attacks, angry controllers and FAA big brother when cruising class Bravo when you just have to get there and don't have time to re-route. -Tom 1 Quote Link to comment Share on other sites More sharing options...
ShuRugal Posted October 20, 2017 Report Share Posted October 20, 2017 That switch supplies power to the radio receiver. You should turn it on prior to starting the engine, or your controller will be unable to command the aircraft control servos. Quote Link to comment Share on other sites More sharing options...
MooneyBob Posted October 20, 2017 Report Share Posted October 20, 2017 The wings pyro-detaching device. You flip the switch and you have 10 seconds to leave you hangar. Quote Link to comment Share on other sites More sharing options...
Jeff H. Posted October 20, 2017 Report Share Posted October 20, 2017 I'm just going to pile on . . . Gremlin entry point - flip the switch to open the access port. Quote Link to comment Share on other sites More sharing options...
