markejackson02 Posted September 25, 2017 Report Share Posted September 25, 2017 I need to replace the hoses on the Brittain system behind the panel (original from 1977). 7/32 ID wiper/vacuum hose is the recommended replacement. It is offered in latex or silicone or "synthetic rubber". What are the pros and cons of each? Quote Link to comment Share on other sites More sharing options...
markejackson02 Posted September 26, 2017 Author Report Share Posted September 26, 2017 FWIW, the lady at Brittain was super nice. Gates 27043 at auto store 8-10 feet. Will give it a shot. 2 Quote Link to comment Share on other sites More sharing options...
tony Posted September 26, 2017 Report Share Posted September 26, 2017 why don't you ask CeCi? she'll tell you what the recommend. Quote Link to comment Share on other sites More sharing options...
markejackson02 Posted September 30, 2017 Author Report Share Posted September 30, 2017 New issue. Removed a couple of the hoses. They were so old that they basically crumbled and left hose on the tee fittings. Is there anything recommended to remove the residue after I peel off the big chunks of rubber. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted September 30, 2017 Report Share Posted September 30, 2017 2 minutes ago, markejackson02 said: New issue. Removed a couple of the hoses. They were so old that they basically crumbled and left hose on the tee fittings. Is there anything recommended to remove the residue after I peel off the big chunks of rubber. If they are that crappy, the fittings should clean up easily Quote Link to comment Share on other sites More sharing options...
