jwoolard Posted September 3, 2017 Report Share Posted September 3, 2017 Hi all, We've just bought a 1982 M20K which we're keeping at Oban and Biggin Hill in the UK. In the baggage compartment was the red device in the picture below. What is it, and how do we use it? Thanks, Johannes and Emily Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted September 3, 2017 Report Share Posted September 3, 2017 It sure is a nice one! I'll have to get one. Quote Link to comment Share on other sites More sharing options...
kpaul Posted September 3, 2017 Report Share Posted September 3, 2017 Must be a control lock, the horse shoed ends on the rudder peddals. Not entirely sure how the yoke portion would be placed. Quote Link to comment Share on other sites More sharing options...
Jerry Pressley Posted September 3, 2017 Report Share Posted September 3, 2017 Biggen Hill brings back some great memories. I delivered a single engine Meyers 200D to John Hull there from Knoxville, Tn. There Was an old antique twin engine used for sightseeing then. For extra fuel I tried lots of things including PT boat tanks which were manufactured by Meyers during the war. inch too wide. Ended up with a 55 gal drum in the back seat strapped in. Frobisher YFK to Godthab NUUK to Rejevic KEF to biggen hill. this was before GPS or Loran C small enough to fit in a small cockpit. I thought I knew how to fly ADF until 800 miles from Frobisher at midnight in a snowstorm. jerryP Quote Link to comment Share on other sites More sharing options...
jwoolard Posted September 3, 2017 Author Report Share Posted September 3, 2017 2 hours ago, kpaul said: Must be a control lock, the horse shoed ends on the rudder peddals. Not entirely sure how the yoke portion would be placed. I thought so too - but with those ends on the pedals, the other end is about 6 inches short of the yoke at its forward position. 1 hour ago, acpartswhse said: Biggen Hill brings back some great memories. I delivered a single engine Meyers 200D to John Hull there from Knoxville, Tn. There Was an old antique twin engine used for sightseeing then. For extra fuel I tried lots of things including PT boat tanks which were manufactured by Meyers during the war. inch too wide. Ended up with a 55 gal drum in the back seat strapped in. Frobisher YFK to Godthab NUUK to Rejevic KEF to biggen hill. this was before GPS or Loran C small enough to fit in a small cockpit. I thought I knew how to fly ADF until 800 miles from Frobisher at midnight in a snowstorm. jerryP Wow, must have been a while back! I'd love to fly transatlantic some day - but with a GPS and every other possible aid! Quote Link to comment Share on other sites More sharing options...
carusoam Posted September 3, 2017 Report Share Posted September 3, 2017 Welcome aboard, JW (Johannesburg and Emily) Got a picture of the other end that you can share? I haven't seen anything like it before. Most likely, not a Mooney specific part. If it isn't a flight control lock... it is looking like a tow bar. If it is a tow bar, it must have a method of connecting to the nose wheel. Did your plane come with a tow bar? Are you able to maintain contact with the previous owner? Take a moment to add some detail to your avatar. It will help people, to help you... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
wrench Posted September 3, 2017 Report Share Posted September 3, 2017 Does the male ends plug into the bottom of the Control yoke holes then you just would slide the bar on the floor the vertical position to lock the wheel? Just a guess but it looks like the width is about right. Quote Link to comment Share on other sites More sharing options...
RLCarter Posted September 3, 2017 Report Share Posted September 3, 2017 1 hour ago, wrench said: Does the male ends plug into the bottom of the Control yoke holes then you just would slide the bar on the floor the vertical position to lock the wheel? Just a guess but it looks like the width is about right. My guess as well, seatbelt to hold the yoke back Quote Link to comment Share on other sites More sharing options...
Hank Posted September 4, 2017 Report Share Posted September 4, 2017 I find using the seatbelt to be awkward. So I put a bungee to hold the two yokes together, and use a long one from the seat bar to the yoke on the right side. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 4, 2017 Report Share Posted September 4, 2017 Here's my guess, the curved end toward us in the picture goes curved end down on the carpet, the horizontal bar presses on the rudder pedals as shown by the scratches, the other end engages the control wheel by pulling it aft and slipping the "U" shaped ends on to the wheel. Setting the trim will add a bit of tension to hold it in place. Clarence Quote Link to comment Share on other sites More sharing options...
takair Posted September 4, 2017 Report Share Posted September 4, 2017 Looks too well built to be one off, yet you have stumped the panel so far. Can you get a close up photo of the far end? I have three guesses. 1. Not intended for Mooney 2. U shaped end pushes agains seat back, seatbelt holds it in place, other end goes agains yoke in full forward while adjusting seat to hold it there. 3. Some sort of auxiliary jack stand when using tail weight....although I can't quite picture where it would capture the engine mounts on a K. Once we figure out what it is, I might want one too. Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted September 4, 2017 Report Share Posted September 4, 2017 I think my next project may be to design and build a device with no actual purpose, just to post and drive everyone crazy. 5 Quote Link to comment Share on other sites More sharing options...
Mooneymite Posted September 4, 2017 Report Share Posted September 4, 2017 My guess is a rudder lock. "Feet" go against rudder pedals, the other end goes against the seat which you slide forward until snug. Or it is an antenna for receiving subliminal messages from your wife. Quote Link to comment Share on other sites More sharing options...
milotron Posted September 4, 2017 Report Share Posted September 4, 2017 I think Clarence has it, but with the big weights on the yoke pulling the yokes forward anyways, this will hold the lock in place against the carpet and the rudder pedals. ...or it is an escape ladder. iain Quote Link to comment Share on other sites More sharing options...
Hank Posted September 5, 2017 Report Share Posted September 5, 2017 6 hours ago, milotron said: ...or it is an escape ladder. Winner! It's for climbing out the baggage door after using the Emergency Open latch. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted September 5, 2017 Report Share Posted September 5, 2017 4 minutes ago, Hank said: Winner! It's for climbing out the baggage door after using the Emergency Open latch. I want to see the YouTube... 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted September 5, 2017 Report Share Posted September 5, 2017 I'd like to see someone climb out the baggage door, with or without a ladder. Clarence Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted September 5, 2017 Report Share Posted September 5, 2017 37 minutes ago, M20Doc said: I'd like to see someone climb out the baggage door, with or without a ladder. Clarence Unfortunately, I recently did just that a few times. I had all the upholstery out of the baggage compartment for antenna removal and installation. I climbed into the baggage compartment to put it back together and had to climb out. A lot of folding and unfolding a 6 ft tall 60 year old body. Quote Link to comment Share on other sites More sharing options...
steingar Posted September 5, 2017 Report Share Posted September 5, 2017 I've got problems with my door seals and can't open the door form the outside. If I wasn't to open it I have to crawl thought the luggage door, reach forward and open it from the inside. I'll ave to have that looked at one of these days... Quote Link to comment Share on other sites More sharing options...
Piloto Posted September 11, 2017 Report Share Posted September 11, 2017 On 9/4/2017 at 10:17 PM, Hank said: Winner! It's for climbing out the baggage door after using the Emergency Open latch. Wouldn't a rope ladder be more practical. After all the airlines just use a rope. José Quote Link to comment Share on other sites More sharing options...
