N201MKTurbo Posted August 22, 2017 Report Share Posted August 22, 2017 17 minutes ago, LANCECASPER said: Again, not according to the link - no mention of experimental - this is for certified airplanes: I stand corrected. I'm getting more than I bargained for when it arrives. 1 Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted August 22, 2017 Report Share Posted August 22, 2017 Or you go to the source:https://buy.garmin.com/en-US/US/p/570665They don't use the GPSS abbreviation, they use phrase "GPS course guidance" Quote Link to comment Share on other sites More sharing options...
autopatch Posted August 22, 2017 Report Share Posted August 22, 2017 Does anyone have experience with Commander Aero near Dayton, OH for work on an existing Century 2000 installation? If the NSD 360 has failed the I'd likely consider the G5/GAD29B with my 430W as a replacement option. Quote Link to comment Share on other sites More sharing options...
Philip Posted August 23, 2017 Report Share Posted August 23, 2017 I have two G5's on order. One will replace my AH and the other my DG and one CDI. My avionics guy says the G5 HSI will work with my 430w and stec30. My stec dg goes away as does the gpss box. Garmin shows it all shipping on Oct 14. http://newsroom.garmin.com/press-release/featured-releases/garmin-announces-third-party-autopilot-support-g5-electronic-flight- this link shows the heading mode and gpss should work like my current setup. I'm looking forward to the upgrade. 3 Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted August 23, 2017 Report Share Posted August 23, 2017 I have two G5's on order. One will replace my AH and the other my DG and one CDI. My avionics guy says the G5 HSI will work with my 430w and stec30. My stec dg goes away as does the gpss box. Garmin shows it all shipping on Oct 14.http://newsroom.garmin.com/press-release/featured-releases/garmin-announces-third-party-autopilot-support-g5-electronic-flight- this link shows the heading mode and gpss should work like my current setup. I'm looking forward to the upgrade. Looking forward to a PIREP since I have almost the same setup. Would love to add an HSI, remove a CDI and the GPSS module so long as the G5 can provide GPSSQ natively with a GNS box.Sent from my LG-US996 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted August 23, 2017 Report Share Posted August 23, 2017 I have two G5's on order. One will replace my AH and the other my DG and one CDI. My avionics guy says the G5 HSI will work with my 430w and stec30. My stec dg goes away as does the gpss box. Garmin shows it all shipping on Oct 14.http://newsroom.garmin.com/press-release/featured-releases/garmin-announces-third-party-autopilot-support-g5-electronic-flight- this link shows the heading mode and gpss should work like my current setup. I'm looking forward to the upgrade. Did you get an estimate? I'm still waiting for a response. Quote Link to comment Share on other sites More sharing options...
MooneyBob Posted August 23, 2017 Report Share Posted August 23, 2017 2 hours ago, teejayevans said: Did you get an estimate? I'm still waiting for a response. I've got estimate from my guy. I have existing GTN750 and Century IIB AP. 2 x G5 GMU 11 magnetometer GAD 29B $ 10k installed once available. Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted August 23, 2017 Report Share Posted August 23, 2017 I've got estimate from my guy. I have existing GTN750 and Century IIB AP. 2 x G5 GMU 11 magnetometer GAD 29B $ 10k installed once available. I was afraid of that, the hardware is only $5200, assuming a shop rate of $100, thats 48 hours of labor?! Quote Link to comment Share on other sites More sharing options...
Philip Posted August 23, 2017 Report Share Posted August 23, 2017 2 G5's GMU 11 GAD 29B $9100 installed Quote Link to comment Share on other sites More sharing options...
kpaul Posted August 23, 2017 Report Share Posted August 23, 2017 2 hours ago, Philip said: 2 G5's GMU 11 GAD 29B $9100 installed What shop? Quote Link to comment Share on other sites More sharing options...
Seth Posted August 23, 2017 Author Report Share Posted August 23, 2017 My only worry is where the Mooney will fit into Garmin's trajectory: GFC 500 STCed for 172, with 182, and PA-28 to follow soon. GFC 600 STCed for Bonanza A36 and Baron B55 with B58 to follow soon. Mooney M20C and M20E's sound like they'd be similar to the 500 Mooney M20M, M20R, M20S, M20TN, M20U, and M20V's sound like they may end up in the GFC 600 range which is 3X the price. I'm curious where the mid body would fit? Or will they consider a four place airplane GFC 500 territory even though the performance is better than certain 6 seat aircraft? No reason to waste any more brain function on this potential dilemma, as we'll find out when we find out - but it may change pricing and make me continue to repair or replace King Components, like roll servos (just had to purchase a replacement unit) as they are removed from aircraft moving up to the GFC 500. -Seth 1 Quote Link to comment Share on other sites More sharing options...
N6758N Posted August 23, 2017 Report Share Posted August 23, 2017 8 minutes ago, Seth said: My only worry is where the Mooney will fit into Garmin's trajectory: GFC 500 STCed for 172, with 182, and PA-28 to follow soon. GFC 600 STCed for Bonanza A36 and Baron B55 with B58 to follow soon. Mooney M20C and M20E's sound like they'd be similar to the 500 Mooney M20M, M20R, M20S, M20TN, M20U, and M20V's sound like they may end up in the GFC 600 range which is 3X the price. I'm curious where the mid body would fit? Or will they consider a four place airplane GFC 500 territory even though the performance is better than certain 6 seat aircraft? I am thinking Garmin will certify the same autopilot for all Mooneys, in other words but the lowly C and the mighty R will both have the same type of autopilot approved for them, and I would lean towards the GFC500 if I had to guess. The wing and flight controls are way too similar between all Mooneys to make it worth the effort on Garmins part to change the STC mid-way through the M20 models. 2 Quote Link to comment Share on other sites More sharing options...
Seth Posted August 23, 2017 Author Report Share Posted August 23, 2017 Just now, N6758N said: I am thinking Garmin will certify the same autopilot for all Mooneys, in other words but the lowly C and the mighty R will both have the same type of autopilot approved for them, and I would lean towards the GFC500 if I had to guess. The wing and flight controls are way too similar between all Mooneys to make it worth the effort on Garmins part to change the STC mid-way through the M20 models. I agree with you there. I'm hoping its the GFC 500 as well from a cost persepcitve. That being said, the GFC 600 is more robust, but I'm fine with the hardware in the G500. 1 Quote Link to comment Share on other sites More sharing options...
mike_elliott Posted August 23, 2017 Report Share Posted August 23, 2017 12 minutes ago, Seth said: My only worry is where the Mooney will fit into Garmin's trajectory: GFC 500 STCed for 172, with 182, and PA-28 to follow soon. GFC 600 STCed for Bonanza A36 and Baron B55 with B58 to follow soon. Mooney M20C and M20E's sound like they'd be similar to the 500 Mooney M20M, M20R, M20S, M20TN, M20U, and M20V's sound like they may end up in the GFC 600 range which is 3X the price. I'm curious where the mid body would fit? Or will they consider a four place airplane GFC 500 territory even though the performance is better than certain 6 seat aircraft? No reason to waste any more brain function on this potential dilemma, as we'll find out when we find out - but it may change pricing and make me continue to repair or replace King Components, like roll servos (just had to purchase a replacement unit) as they are removed from aircraft moving up to the GFC 500. -Seth Ok, Ill take a guess.... The Bo's all need a yaw damper, where all Mooney's this isn't needed. I believe the 600 has this capability. The mid body G model surely wont need a 600, and your airframe is the same, just with a few more ponies and larger feed trough. 1 Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted August 23, 2017 Report Share Posted August 23, 2017 We'll get the GFC 500. It has been flying higher performance planes in the experimental world for years already.Sent from my LG-US996 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
gsengle Posted August 23, 2017 Report Share Posted August 23, 2017 We'll get the GFC 500. It has been flying higher performance planes in the experimental world for years already.Sent from my LG-US996 using Tapatalk I wouldn't count on it, at least for the long bodies, in fact I'm expecting the 600 to be required for our fiki airplanes....Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
MooneyBob Posted August 23, 2017 Report Share Posted August 23, 2017 4 hours ago, teejayevans said: I was afraid of that, the hardware is only $5200, assuming a shop rate of $100, thats 48 hours of labor?! I know. It seems a lot. It's time for some negotiations. Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted August 23, 2017 Report Share Posted August 23, 2017 I wouldn't count on it, at least for the long bodies, in fact I'm expecting the 600 to be required for our fiki airplanes....Sent from my iPhone using Tapatalk What difference does it make, FIKI or long body? This system has been flying in planes like the Lancair Evolution and others for years now. There is no reason really for the 600 to be required for any Mooney.Sent from my LG-US996 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted August 23, 2017 Report Share Posted August 23, 2017 What difference does it make, FIKI or long body? This system has been flying in planes like the Lancair Evolution and others for years now. There is no reason really for the 600 to be required for any Mooney.Sent from my LG-US996 using Tapatalk I believe the 600 servos are waterproof, 500s are not....now imagine you autopilot servos locking up because they're frozen.I saw a one liner somewhere that called out both FIKI and pressurize planes require the 600. 2 Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted August 23, 2017 Report Share Posted August 23, 2017 Legacy servos aren't waterproof, and they're not exposed to rain unless you have something wrong with your plane!Sent from my LG-US996 using Tapatalk Quote Link to comment Share on other sites More sharing options...
MIm20c Posted August 23, 2017 Report Share Posted August 23, 2017 1 hour ago, KSMooniac said: What difference does it make, FIKI or long body? This system has been flying in planes like the Lancair Evolution and others for years now. There is no reason really for the 600 to be required for any Mooney. Sent from my LG-US996 using Tapatalk I don't think the G5 is legal to install into a FIKI plane at all and the 500 needs the G5 to function. Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted August 23, 2017 Report Share Posted August 23, 2017 I just looked at the G5 AML and all M20 aircraft through the M20S are included, with no limitations. I'm guessing the TN (and new U & V models) weren't included for now since Garmin likely didn't have access to those when developing the AML. They have their own R and J and likely made similarity arguments for all of the other models. If FIKI were an issue, it would certainly show up in the limitations section.Sent from my LG-US996 using Tapatalk Quote Link to comment Share on other sites More sharing options...
gsengle Posted August 23, 2017 Report Share Posted August 23, 2017 Legacy servos aren't waterproof, and they're not exposed to rain unless you have something wrong with your plane!Sent from my LG-US996 using Tapatalk Garmin has every right to say that certain Mooneys only get the more expensive model. And they could do it just based on airframe price and perceived owners ability to pay. So I fully expect that the stc at a minimum will require the 600 for fiki. It's their choice.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
N6758N Posted August 23, 2017 Report Share Posted August 23, 2017 1 minute ago, gsengle said: Garmin has every right to say that certain Mooneys only get the more expensive model. And they could do it just based on airframe price and perceived owners ability to pay. So I fully expect that the stc at a minimum will require the 600 for fiki. It's their choice. Sent from my iPhone using Tapatalk I don't see them wasting money on the certification process for 2 different AP systems when the hardware, brackets, etc is virtually identical for all Mooneys. Quote Link to comment Share on other sites More sharing options...
gsengle Posted August 23, 2017 Report Share Posted August 23, 2017 I don't see them wasting money on the certification process for 2 different AP systems when the hardware, brackets, etc is virtually identical for all Mooneys. And the danger there is we all get pushed to the 600. Or they do the 500 first figuring that the market is more limited for fiki/hp airframes and we get left until much later.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
