Brian Scranton Posted August 2, 2017 Report Share Posted August 2, 2017 Dudes. I have a 430 non waas and a GTX 330 transponder. What do I have to do to get to be ADSB compliant? I think I have to add the W to my 430 and add the ES to my 330. Is that all? Is there a less expensive path? Thanks! Quote Link to comment Share on other sites More sharing options...
gsengle Posted August 2, 2017 Report Share Posted August 2, 2017 Yep that's probably the best way for you to go and you get the benefits of upgrading to waas for approachesSent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
N6758N Posted August 2, 2017 Report Share Posted August 2, 2017 Yep, there are less expensive options, but you wont't get any benefit from going another route. If you WAAS the 430 you will get LPV approaches and a much faster processor. The 330 ES upgrade will make you ADS-out compliant plus you will get traffic on the 430. 3 Quote Link to comment Share on other sites More sharing options...
Brian Scranton Posted August 2, 2017 Author Report Share Posted August 2, 2017 Thanks guys! That's what I thought... Quote Link to comment Share on other sites More sharing options...
Hank Posted August 2, 2017 Report Share Posted August 2, 2017 My only incentive to upgrade my G327 is the ATL Bravo, but Approach won't let me in now anyway . . . So I'll see what other places I'm kept away from during 2020, and decide if it's worth the money and hassle to swap out stuff in my panel or not. Good luck with your upgrades! You'll like the 430W, I really do! 1 Quote Link to comment Share on other sites More sharing options...
MIm20c Posted August 2, 2017 Report Share Posted August 2, 2017 2 hours ago, N6758N said: The 330 ES upgrade will make you ADS-out compliant plus you will get traffic on the 430. The traffic will only be displayed when TIS radar coverage is available. Adsb traffic requires the 345, l3, etc. 1 Quote Link to comment Share on other sites More sharing options...
N6758N Posted August 2, 2017 Report Share Posted August 2, 2017 2 minutes ago, MIm20c said: The traffic will only be displayed when TIS radar coverage is available. Adsb traffic requires the 345, l3, etc. Correct, but I have found it to be nearly just as good, especially with a Stratus on board to feed it. 1 Quote Link to comment Share on other sites More sharing options...
201er Posted August 2, 2017 Report Share Posted August 2, 2017 (edited) 1 minute ago, N6758N said: Correct, but I have found it to be nearly just as good, especially with a Stratus on board to feed it. Stratus feeding a 430?? Edited August 2, 2017 by 201er 1 Quote Link to comment Share on other sites More sharing options...
MIm20c Posted August 2, 2017 Report Share Posted August 2, 2017 I only have tis service close to a class C, not sure if there is a map showing coverage in the lower 48. 1 Quote Link to comment Share on other sites More sharing options...
N6758N Posted August 2, 2017 Report Share Posted August 2, 2017 16 minutes ago, 201er said: Stratus feeding a 430?? Mike, Not the 430, but the 330ES. When you program the 330ES after installation, you tell it if you have portable ads-b in coverage. Supposedly the transponder feeds off of the Stratus or vice versa. Not really sure how well it works but I am pleasantly surprised with the amount of Traffic info that shows up on my 430W. It could just be the fact that I've never had on board traffic before too. 1 Quote Link to comment Share on other sites More sharing options...
rbridges Posted August 2, 2017 Report Share Posted August 2, 2017 I know this is going the other way with cost, but the WAAS upgrade isn't exactly cheap. You may want to consider trading the 430 for a 650. More cost but a much newer GPS with (probably) longer support into the future. 1 Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted August 2, 2017 Report Share Posted August 2, 2017 Garmin has a new box out for ADS-B out only and very simple installation. I'd rather have WAAS on the 430 and the transponder upgrade myself, though. You might wait a bit longer to see if the new Dynon kit makes it to us since it includes ADS-B in and out, in addition to engine monitor, autopilot, etc. That might be a lot more bang for the buck. Sent from my LG-US996 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
MIm20c Posted August 2, 2017 Report Share Posted August 2, 2017 1 hour ago, N6758N said: Mike, Not the 430, but the 330ES. When you program the 330ES after installation, you tell it if you have portable ads-b in coverage. Supposedly the transponder feeds off of the Stratus or vice versa. Not really sure how well it works but I am pleasantly surprised with the amount of Traffic info that shows up on my 430W. It could just be the fact that I've never had on board traffic before too. I'd really like some more info on this. 1 Quote Link to comment Share on other sites More sharing options...
Chandler Avionics Posted August 2, 2017 Report Share Posted August 2, 2017 Brian, Getting avionics updated to Waas is the right way and you will get the most current software update. However the other option is going with Garmin's new product GDL82 which will allow you to be ADS-B compliant and cost less. https://buy.garmin.com/en-US/US/p/540911 1 Quote Link to comment Share on other sites More sharing options...
N6758N Posted August 2, 2017 Report Share Posted August 2, 2017 2 minutes ago, MIm20c said: I'd really like some more info on this. It is somewhere in the 330 Installation manual under configuration GTX330_33 With ADS-B Out Installation Manual.pdf 1 Quote Link to comment Share on other sites More sharing options...
tony Posted August 3, 2017 Report Share Posted August 3, 2017 I'd dump the 430 and do something like this: http://sarasotaavionics.com/avionics/gns430-to-ifd440-upgrade 1 Quote Link to comment Share on other sites More sharing options...
rbridges Posted August 3, 2017 Report Share Posted August 3, 2017 4 hours ago, tony said: I'd dump the 430 and do something like this: http://sarasotaavionics.com/avionics/gns430-to-ifd440-upgrade that's actually what I meant to say when I suggested the 650. Quote Link to comment Share on other sites More sharing options...
Oldguy Posted August 3, 2017 Report Share Posted August 3, 2017 Couple of questions With the TN on your F, do you get into the flight levels at any time? If so, you will need to get the 1090ES version of ADS-B Out which eliminates the GDL 82. Are you planning any additional avionics upgrades or just get ADS-B Out compliant? If you are truly looking for lowest cost path to compliance, and fly over 18,000', the WAAS upgrade to the 430 and the ES upgrade to the GTX looks like it. Otherwise, the GDL 82, as currently priced would be even less but restrict altitude and, I believe, foreign flights when they implement ADS-B requirements. Swapping out the 430 for the 650 or 440 sounds good, but your costs would be higher. But if this is part of an upgrade to the panel, it still might be a fit. Quote Link to comment Share on other sites More sharing options...
Brian Scranton Posted August 3, 2017 Author Report Share Posted August 3, 2017 Yeah, I plan to be in the FL18 to FL25 world so I hear ya on the GDL82. Quote Link to comment Share on other sites More sharing options...
