RobertE Posted July 19, 2017 Report Share Posted July 19, 2017 Anyone know what might have caused this to cease to function? My avionics shop said the problem was a defective antenna (my system is set up to display on a garmin 696 that I've mounted in the panel so the antenna plugs directly into that device) but a new antenna didn't fix it. Any ideas? Quote Link to comment Share on other sites More sharing options...
aggiepilot04 Posted July 19, 2017 Report Share Posted July 19, 2017 When I owned a 696, I had the XM antenna crap out on me as well. This was several years ago, but they sent me a new one under warranty. I want to say the radio ID on the account is tied to the antenna itself, so it's not as simple as trying a different antenna...you'll have to change the radio ID on the account. To confirm (because I could be wrong), check the radio ID in your 696 settings with the antenna plugged in and make sure that it matches your Sirius account. Once you've confirmed, have Sirius resend the activation signal while the antenna is in clear view of the sky and the 696 is powered on. Quote Link to comment Share on other sites More sharing options...
kortopates Posted July 19, 2017 Report Share Posted July 19, 2017 If your receiver hasn't connected to Sirius in awhile you'll have to go to their website and "refresh" your Sirius radio ID. But you need to have your unit on when you do and it can take up to an hour till your receiver gets the signal and is essentially re-activated. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
kpaul Posted July 19, 2017 Report Share Posted July 19, 2017 1 hour ago, aggiepilot04 said: I want to say the radio ID on the account is tied to the antenna itself, so it's not as simple as trying a different antenna...you'll have to change the radio ID on the account. The antenna does not have a ID. The ID is coded into the radio or receiver. I have replaced the antenna on the radio in my motorhome with no contact with the company needed via computer or phone. Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted July 19, 2017 Report Share Posted July 19, 2017 The XM "antenna" for your 696 is in fact the evtire XM system including antenna and receiver/processor. So the XM hardware identity is associated with the GXM40. That ID is physically marked on the unit, or can be displayed on the 696. 1 Quote Link to comment Share on other sites More sharing options...
aggiepilot04 Posted July 19, 2017 Report Share Posted July 19, 2017 14 minutes ago, kpaul said: The antenna does not have a ID. The ID is coded into the radio or receiver. I have replaced the antenna on the radio in my motorhome with no contact with the company needed via computer or phone. An XM radio antenna is different from an XM weather receiver. The weather receivers look like this: http://www.sportys.com/pilotshop/gxm-42-antenna-for-garmin-796.html I believe the weather receivers have radio IDs on the back and must be activated. Quote Link to comment Share on other sites More sharing options...
MB65E Posted July 19, 2017 Report Share Posted July 19, 2017 Ours went TU on a flight yesterday. RWC PL21, said "No subscription" not true, it's due in January and it's paid. I refreshed the signal, had pilot reset the CB and it worked normally the rest of the flight. We only have XM weather with no audio. -Matt Quote Link to comment Share on other sites More sharing options...
RobertE Posted July 20, 2017 Author Report Share Posted July 20, 2017 Thanks everyone but I probably should have made clear in my question that I already provided SiriusXM with the new antenna serial number and got a refreshed signal - still no go. Any other thoughts as to what might be my problem? Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted July 20, 2017 Report Share Posted July 20, 2017 Check to see that you have the most current Garmin 696 software version which will also transfer the most current GXM40 software to the antenna. Quote Link to comment Share on other sites More sharing options...
Stanton R Posted July 21, 2017 Report Share Posted July 21, 2017 check the xm music page. You should have at least the preview channel. Also make sure that the 696 sees the gxm Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 22, 2017 Report Share Posted July 22, 2017 Welcome aboard, Stanton. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Piloto Posted July 22, 2017 Report Share Posted July 22, 2017 On 7/20/2017 at 10:49 AM, RobertE said: Thanks everyone but I probably should have made clear in my question that I already provided SiriusXM with the new antenna serial number and got a refreshed signal - still no go. Any other thoughts as to what might be my problem? Did you check the weather outside? Sometimes is clear and sunny José Quote Link to comment Share on other sites More sharing options...
RobertE Posted August 2, 2017 Author Report Share Posted August 2, 2017 To completely close the loop on this, it turns out the unit itself was the problem. Antenna fine but for some reason the unit couldn't recognize that the antenna was attached. Gamrin tech reps say this isn't all that unusual. Price for "overhaul" (they seem to have simply sent me a new unit) is 1/2 the cost of new. My original one lasted 5 years. anyone want to buy a used antenna (GXM40) and battery (they mistakenly sent me an extra)?? No offer will be refused. Quote Link to comment Share on other sites More sharing options...
