MooneyPTG Posted July 12, 2017 Report Share Posted July 12, 2017 (edited) 1974 Mooney M20E $54,900.00 or Best OFFER!!! Take a test flight when your in Oshkosh at the EAA !!! Location: Green Bay WI Kevin Kuehn 920 621 3473 kuehnprinting@gmail.com Description: 1974 MOONEY M20E CHAPARRAL N7120V ENGINE PROPELLER AIRFRAME Airframe: 3415 TT S/N 21-0043 Engine: 1610 SMOH, Lyc. IO-360 A1A, S/N L-12801-51A compression #1 74, #2 78, #3 74,#4 76 Prop: 394 TTSNEW, 3-Bladed C/S, Hartzell HC-C3YR-1FTR/F7282, S/N DY5631B New Tires, New Brakes, New Rubber suspension donuts, Rebuilt Fuel Pump, Rebuilt Both Mags, Rebuilt Flap motor. New Interior 2014 New Paint 2014 AVIONICS Avionics Master Switch KLN 89B GPS,Annunciator, KI 202 indicator Terra TMA-230 Audio Panel Narco Mk 12E Nav/Com Narco ID-825 VOR/LOC/GS Indicator (Rectilinear Movement) Narco 890 DME tied to Narco King KX175B Nav/Com King KI-201C VOR/LOC Indicator Compass Card Rebuilt Turn Coordinator. Electric And Vacuum driven Voice Annunciator “stall stall” “Check Landing Gear, Check Landing Gear” King KT78 Transponder Transcal SSD120 Encoder BFGoodrich WX-900 Storm Scope Precision Engineering PM3000 Intercom New Heading indicator with bug, new Vertical Speed indicator EQUIPMENT Electric Gear & Flaps Ram Air Pitot Heat Precise Flight Standby Vacuum System M-20 Oil Separator Anti-Collision Light Brittain P.C. System Wing Leveler Insight G1 engine analyzer Tinted Sun Visors Pointer ELT Alternate Air Source External Power Plug Shoulder Harness 3 Bladed STC Prop Whelen landing light Brackett Air Filter Pilot & Copilot Push-to-Talk Sw. Complete logs, Great compression, oil analysis on changes, flown regularly Gear up 1996 Edited August 7, 2017 by MooneyPTG Typo Quote Link to comment Share on other sites More sharing options...
Mcstealth Posted July 12, 2017 Report Share Posted July 12, 2017 What year was the overhaul? Same as gear up? Quote Link to comment Share on other sites More sharing options...
kpaul Posted July 12, 2017 Report Share Posted July 12, 2017 Your title says M20F, but everything else says M20E which matches your photos. 2 Quote Link to comment Share on other sites More sharing options...
MooneyPTG Posted July 13, 2017 Author Report Share Posted July 13, 2017 (edited) It is an E, sorry Edited July 13, 2017 by MooneyPTG Info Quote Link to comment Share on other sites More sharing options...
MooneyPTG Posted July 13, 2017 Author Report Share Posted July 13, 2017 3 hours ago, Mcstealth said: What year was the overhaul? Same as gear up? Will find out Quote Link to comment Share on other sites More sharing options...
MooneyPTG Posted July 14, 2017 Author Report Share Posted July 14, 2017 On 7/12/2017 at 9:14 PM, MooneyPTG said: Will find out 1994 overhauled Jewell Aviation 1996 prop strike... Popular Grove Belvidere Airmotive 1 Quote Link to comment Share on other sites More sharing options...
