Stephen Posted June 22, 2017 Report Share Posted June 22, 2017 Hi fellow MS'ers. My KY 197 is kaput. The display is wonky with digit segments dropping or persisting so it is difficult/impossible to validate that the correct channel is selected. The swap button only works after a few tries and then much of the time it won't bring in a channel. ..basically it is toast. I have called and can have it overhauled for around .5AMU but wanted to see if anyone had one sitting around a shelf ornament that works that would like to git rid of it cheaply so I can just plug in a replacement. Basically the goal is to get a working com to provide a working COM2 to my current COM1 (530W). PM me if you have something that might fit the bill. Thanks, Stephen Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted June 22, 2017 Report Share Posted June 22, 2017 I have a KY 196 that you could have cheap. Unfortunately it looks like the 196 is 28v only. Sorry. Quote Link to comment Share on other sites More sharing options...
Stephen Posted June 22, 2017 Author Report Share Posted June 22, 2017 Thanks Paul, at least appreciate the thought! I may just sent the dumb thing in; but wanted to shake the MS tree to see if anyone had a 197 gathering dust. Quote Link to comment Share on other sites More sharing options...
N601RX Posted June 22, 2017 Report Share Posted June 22, 2017 The display just plugs into a socket. Often reseating it will fix the missing segments. Just remove the front to access it. 1 Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted June 22, 2017 Report Share Posted June 22, 2017 1 hour ago, N601RX said: The display just plugs into a socket. Often reseating it will fix the missing segments. Just remove the front to access it. Yeah, I've done that with my KX155 but that won't help the swap issue. I sold a 197 out of my old panel 5 years ago on EBAY for $625. Bennett Avionics bought it! Quote Link to comment Share on other sites More sharing options...
Stephen Posted June 22, 2017 Author Report Share Posted June 22, 2017 3 hours ago, N601RX said: The display just plugs into a socket. Often reseating it will fix the missing segments. Just remove the front to access it. I'll give that a try; maybe it will at least help the display portion. Quote Link to comment Share on other sites More sharing options...
jerryg324 Posted June 23, 2017 Report Share Posted June 23, 2017 I just happen to have one available... Just pm me... 1 Quote Link to comment Share on other sites More sharing options...
Stephen Posted June 23, 2017 Author Report Share Posted June 23, 2017 20 hours ago, jerryg324 said: I just happen to have one available... Just pm me... Purchased; thanks Jerry! Quote Link to comment Share on other sites More sharing options...
carusoam Posted June 24, 2017 Report Share Posted June 24, 2017 Go MS! -a- 1 Quote Link to comment Share on other sites More sharing options...
Stephen Posted June 28, 2017 Author Report Share Posted June 28, 2017 On 6/23/2017 at 9:59 PM, carusoam said: Go MS! -a- Boooyah! Go MS is right! 1 Quote Link to comment Share on other sites More sharing options...
