Need an east coast tank reseal specialist
I posted about a fuel smell in my cockpit a while back when I bought my M20K and just have been keeping the right tank below full up until now in order to not have to deal with it. It has worked but all of a sudden recently I can only fill the tank to about 18 gallons before getting wet carpet on the right side of the plane. Time to get this fixed.
I did a lot of searching online and in this forum and I see Weep No More in Willmar, MN, WetWingOlogists East in Fort Lauderdale, FL, and Propellorhead Aviation in Winter Haven, FL.
Wondering if anyone knows a reputable shop a little further north on the east coast? The plane is in South Carolina at the moment and I'd like to stop somewhere on the way back to New York (where I live) to get the tank seal dealt with.
I'm open to having it patched vs completely resealed if that's possible.
Link to comment
Share on other sites
Before you start worrying about patching, have someone check the gasket on the sender unit just behind the upholstery on the right side. It may be as easy as tightening 6 screws.
Link to comment
Good call, thanks for the tip. Though if the problem only shows when I'm above 18 gallons in the tank, doesn't this indicate a tank seal issue?
Link to comment
I don't remember for certain, but I think you have 37 gallon tanks, and the sender units may be mounted just above the center of the tank. It may come out about right.
Link to comment
OK fair point. Definitely worth checking out thanks
Link to comment
1 hour ago, DVA said:
We're in Allentown PA at KXLL which is right along your route. I'd be happy to chat if you'd like.
Dave
484-224-0105
I'll have to stop over one of these days and check out your operation, Last time i was over you were just starting to move in.
Brian
Link to comment
Wet carpet is a sign that comes with the aged cork or rubber seals for the Fuel Level indicator.
take the interior panel off and look what's behind it...
This is something you can do or get done.  No need to wait.
Fuel in the cabin is my least favorite type of leak...  make it stop.
Edited by carusoam
Link to comment
Not that I'm suggesting you use a non approved part but, if you need seals, NAPA sells an exact replica of the seal for about $2.  Takes just a few minutes to install once the fuel is drained from the tank to below the sender level.
Link to comment
Check the inboard and outboard sending unit gaskets there are 2 in each wing. I tried patching my leaking tanks a couple of times when I owned my 201 and it never worked out so I ended up bring it to Edison, wet wing in FXE and he did a great job resealing both tanks.
Link to comment
