aajones5 Posted May 20, 2017 Report Share Posted May 20, 2017 Me and my CFI can't figure out which one I need to write that in Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gsengle Posted May 20, 2017 Report Share Posted May 20, 2017 Just ask yourself, if you took the engine and swapped it to another airframe, does the part stay or go...Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
StevenL757 Posted May 20, 2017 Report Share Posted May 20, 2017 52 minutes ago, aajones5 said: Me and my CFI can't figure out which one I need to write that in Sent from my iPhone using Tapatalk It goes in the airframe log. Steve Quote Link to comment Share on other sites More sharing options...
thinwing Posted May 21, 2017 Report Share Posted May 21, 2017 Airframe Quote Link to comment Share on other sites More sharing options...
M20F Posted May 21, 2017 Report Share Posted May 21, 2017 17 hours ago, gsengle said: Just ask yourself, if you took the engine and swapped it to another airframe, does the part stay or go... Sent from my iPhone using Tapatalk The best logic. Almost nothing goes in the engine/prop log books it is all airframe. 1 Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted May 21, 2017 Report Share Posted May 21, 2017 I was told even accessories like alternator vacuum pump go in air frame. 1 Quote Link to comment Share on other sites More sharing options...
Andy95W Posted May 21, 2017 Report Share Posted May 21, 2017 And believe it or not, even the muffler is technically part of the airframe. Quote Link to comment Share on other sites More sharing options...
Raptor05121 Posted May 21, 2017 Report Share Posted May 21, 2017 42 minutes ago, Andy95W said: And believe it or not, even the muffler is technically part of the airframe. I was thinking this to myself last night and it makes sense. The exhaust isn't technically part of the "internal combustion engine" so yeah. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 21, 2017 Report Share Posted May 21, 2017 1 hour ago, 1964-M20E said: I was told even accessories like alternator vacuum pump go in air frame. While accessories are technically supplied as part of the airframe, my feeling is that if it took tools to remove or install it on the engine, the engine log book should have a record of the maintenance action. Clarence Quote Link to comment Share on other sites More sharing options...
RLCarter Posted May 21, 2017 Report Share Posted May 21, 2017 1 hour ago, M20Doc said: While accessories are technically supplied as part of the airframe, my feeling is that if it took tools to remove or install it on the engine, the engine log book should have a record of the maintenance action. Clarence Is there really any problem if it's in question to add it to both logs? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 21, 2017 Report Share Posted May 21, 2017 1 hour ago, RLCarter said: Is there really any problem if it's in question to add it to both logs? In both logs if it effects the engine, more details can't hurt. Clarence Quote Link to comment Share on other sites More sharing options...
gsengle Posted May 21, 2017 Report Share Posted May 21, 2017 In both logs if it effects the engine, more details can't hurt. Clarence Clarance, do you do like my A&P and sign off both engine and airframe logbooks separately at annual?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Guest Posted May 21, 2017 Report Share Posted May 21, 2017 17 minutes ago, gsengle said: Clarance, do you do like my A&P and sign off both engine and airframe logbooks separately at annual? Sent from my iPhone using Tapatalk Yes I do. Details of the annual as it relates to airframe, engine and propeller should be recorded in the appropriate log book. Most annual inspection checklists have a sections each of these components. In Canada we have 5 log books to deal with. They are, Journey, airframe, installations mods and AD's, engine and propeller. Journey and airframe entries are identical and detail everything done to the entire airplane (tags go in airframe section) Mod's log records AD, SB, SI, STC as related to the airframe, engine log records engine related work and has its own AD section relating to the engine, propeller records propeller related work and has its own AD section relating to the propeller. Clarence Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted May 22, 2017 Report Share Posted May 22, 2017 Rule I've always seen is "What does Lycoming ship". Lycoming doesn't ship the exhaust because that is an airframe specific part. But if you replace an injector or fuel servo its something different than Lycoming shipped the engine to you with. -Robert Quote Link to comment Share on other sites More sharing options...
jlunseth Posted May 23, 2017 Report Share Posted May 23, 2017 The better question is why do we have three logs to begin with? Why not just one? My prop log has about three entries in it over 15 years. What's the point? I don't think the regs require three logs, they just require that maintenance be logged. Quote Link to comment Share on other sites More sharing options...
DonMuncy Posted May 23, 2017 Report Share Posted May 23, 2017 53 minutes ago, jlunseth said: The better question is why do we have three logs to begin with? Why not just one? I think the 3 logs, although not required, arose by tradition because it is likely an engine or prop my be replaced, and the log book for that unit can be disposed of. The goal being to reduce the amount of paperwork an owner has to keep. 2 Quote Link to comment Share on other sites More sharing options...
DXB Posted May 23, 2017 Report Share Posted May 23, 2017 Dang I logged my battery replacement in the wrong place. I would be a hot mess as an owner without Mooneyspace. Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted May 23, 2017 Report Share Posted May 23, 2017 1 hour ago, jlunseth said: The better question is why do we have three logs to begin with? Why not just one? My prop log has about three entries in it over 15 years. What's the point? I don't think the regs require three logs, they just require that maintenance be logged. When I returned my engine to Lycoming as a core they kept that log book and sent me a new zero time book(new engine arrived before I sent the core). I don't think they'd accept the old engine without a log. same with prop. It would be hard to sell the old prop if the logs were integrated. My friend who teaches IAs signs the annual only in the airframe and says "this AIRCRAFT has been" instead of "this airframe"," this engine", etc. just logs repairs in each. -Robert Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted May 23, 2017 Report Share Posted May 23, 2017 Just now, DXB said: Dang I logged my battery replacement in the wrong place. I would be a hot mess as an owner without Mooneyspace. Only if you replace the engine so you'd lose that entry. -Robert Quote Link to comment Share on other sites More sharing options...
N6758N Posted May 23, 2017 Report Share Posted May 23, 2017 2 minutes ago, RobertGary1 said: My friend who teaches IAs signs the annual only in the airframe and says "this AIRCRAFT has been" instead of "this airframe"," this engine", etc. just logs repairs in each. So he doesn't make a return to service statement after the annual in the engine or prop logs? I don't think that is legal. Per FAR 43.11 (a) Maintenance record entries. The person approving or disapproving for return to service an aircraft, airframe, aircraft engine, propeller, appliance, or component part after any inspection performed in accordance with part 91, 125, §135.411(a)(1), or §135.419 shall make an entry in the maintenance record of that equipment containing the following information: (1) The type of inspection and a brief description of the extent of the inspection. (2) The date of the inspection and aircraft total time in service. (3) The signature, the certificate number, and kind of certificate held by the person approving or disapproving for return to service the aircraft, airframe, aircraft engine, propeller, appliance, component part, or portions thereof. Quote Link to comment Share on other sites More sharing options...
gsengle Posted May 23, 2017 Report Share Posted May 23, 2017 The better question is why do we have three logs to begin with? Why not just one? My prop log has about three entries in it over 15 years. What's the point? I don't think the regs require three logs, they just require that maintenance be logged. Because the three items can go their separate ways. Log books need to follow...Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted May 23, 2017 Report Share Posted May 23, 2017 40 minutes ago, N6758N said: So he doesn't make a return to service statement after the annual in the engine or prop logs? I don't think that is legal. Per FAR 43.11 Doesn't make an annual statement. Can either log inspection for each or annual the "aircraft". Because he's the dean of the A&P school he's always working with the fsdo. -Robert Quote Link to comment Share on other sites More sharing options...
Andy95W Posted May 23, 2017 Report Share Posted May 23, 2017 5 hours ago, RobertGary1 said: My friend who teaches IAs signs the annual only in the airframe and says "this AIRCRAFT has been" instead of "this airframe"," this engine", etc. just logs repairs in each. This is also the way that I was taught. An Aircraft gets an Annual inspection, engines and propellers get 100 hour inspections. BTW, this ends up causing weird questions at flight schools and for owners and future owners. Therefore, I log annual inspections for the engine and propeller too. Quote Link to comment Share on other sites More sharing options...
RobertGary1 Posted May 23, 2017 Report Share Posted May 23, 2017 1 minute ago, Andy95W said: This is also the way that I was taught. An Aircraft gets an Annual inspection, engines and propellers get 100 hour inspections. BTW, this ends up causing weird questions at flight schools and for owners and future owners. Therefore, I log annual inspections for the engine and propeller too. Yea, I've heard some FSDO's get upset if you sign an annual for an engine and prop since there is no manufacture guidance for an annual, only 100 hour. But as you stated, it causes confusion. But you can avoid that by only logging "this AIRCRAFT" and just only note repairs and no inspections on the prop, engine book and that covers all. -Robert Quote Link to comment Share on other sites More sharing options...
Andy95W Posted May 23, 2017 Report Share Posted May 23, 2017 When I was working at a flight school, some of the examiners would check the logbooks and question why the engine wasn't signed off for an Annual inspection. At some point ya gotta pick yer battles... Quote Link to comment Share on other sites More sharing options...
