whiskytango Posted May 9, 2017 Report Share Posted May 9, 2017 Does anyone have any suggestions for a repair shop on the East Coast that works on Century 31 autopilots? I am not interested in sending the box out, I want a shop to be able to look at the wiring, servos, switches etc. If the Autotrim switch is on, mine will randomly go to a full trim pitch up and then "stick" there. It takes a good bit of force (with the autopilot off) to back the trim wheel off to the point that the plane is controllable. Not a pleasant feeling. The self test function on the 31 passes all the tests as long as the Autotrim switch is off. Quote Link to comment Share on other sites More sharing options...
N6758N Posted May 9, 2017 Report Share Posted May 9, 2017 If you are in the Northeast, go to KMQS and see Chris Vinciguerro at SureFlight avionics. As far as troubleshooting autopilots goes without just replacing parts, he is one of the best. You may try contacting @Rmag to set up an appointment. 1 Quote Link to comment Share on other sites More sharing options...
whiskytango Posted May 9, 2017 Author Report Share Posted May 9, 2017 10 hours ago, N6758N said: If you are in the Northeast, go to KMQS and see Chris Vinciguerro at SureFlight avionics. As far as troubleshooting autopilots goes without just replacing parts, he is one of the best. You may try contacting @Rmag to set up an appointment. Thanks for the info. I will get in touch with SureFlight. 1 Quote Link to comment Share on other sites More sharing options...
