aajones5 Posted April 24, 2017 Report Share Posted April 24, 2017 So I noticed I've got this black valve that you can push and pull but always returns to the original position, it's definitely connected to something I just can't tell what and it's not labeled anywhere Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
aajones5 Posted April 24, 2017 Author Report Share Posted April 24, 2017 It's that black button right in front of the red wires at the top of the pictureSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Guitarmaster Posted April 24, 2017 Report Share Posted April 24, 2017 I think that's the ejection handle.Sent from my XT1585 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted April 24, 2017 Report Share Posted April 24, 2017 Cowl flaps? could be an alternate vacuum source from the intake manifold. I think it was precise flight that offered this STC? Or alternate static source? Follow the cable and find out what it activates. send photos when you find the other end. Quote Link to comment Share on other sites More sharing options...
bradp Posted April 24, 2017 Report Share Posted April 24, 2017 It's the flush mechanism for pilotos relief tube? Do you know where your alternate static valve is located? What year model are you?Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
aajones5 Posted April 24, 2017 Author Report Share Posted April 24, 2017 I've got a 1968 m20c, its not my alternate static source because I know where that is. I'll try to follow it but it'll be hard because it goes way back behind all my gps stuff and I can't see it anymore, I'll open the cowl later and see if I see its cable going through the firewall anywhere Quote Link to comment Share on other sites More sharing options...
aajones5 Posted April 24, 2017 Author Report Share Posted April 24, 2017 Not cowl flaps either mine should be fixed Quote Link to comment Share on other sites More sharing options...
rbridges Posted April 24, 2017 Report Share Posted April 24, 2017 I've got cowl flaps and carb heat under the panel on the pilot's side Quote Link to comment Share on other sites More sharing options...
mike20papa Posted April 24, 2017 Report Share Posted April 24, 2017 You look to have an unusual heater duct set up. Are you sure this doesn't control a butterfly valve associated with that duct set up? You other C model owners have pilot side heater duct that looks like this? Looks like the round duct in the background is going up to the windshield defroster outlets. 2 Quote Link to comment Share on other sites More sharing options...
Yetti Posted April 24, 2017 Report Share Posted April 24, 2017 It's a standard choke cable off a car. Who knows where it goes. Quote Link to comment Share on other sites More sharing options...
Shadrach Posted April 24, 2017 Report Share Posted April 24, 2017 Check to see if there is a diverter flap at the defroster. Does it move freely? Quote Link to comment Share on other sites More sharing options...
aajones5 Posted April 24, 2017 Author Report Share Posted April 24, 2017 i'll see if its for the defroster, it doesn't click into place you can pull it and push with some effort but it always returns to its original position Quote Link to comment Share on other sites More sharing options...
Yetti Posted April 24, 2017 Report Share Posted April 24, 2017 Engages the supercharger drive belt? 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted April 24, 2017 Report Share Posted April 24, 2017 i'll see if its for the defroster, it doesn't click into place you can pull it and push with some effort but it always returns to its original position You might be able to get your cell phone under there to snap some pictures. I wonder if it is to activate the wastegate on a turbocharger at one point.Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
aajones5 Posted April 24, 2017 Author Report Share Posted April 24, 2017 turbocharger on a C? Quote Link to comment Share on other sites More sharing options...
Marauder Posted April 24, 2017 Report Share Posted April 24, 2017 turbocharger on a C? They are rare but they exist. Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Hank Posted April 24, 2017 Report Share Posted April 24, 2017 It's about where my Alt Static is, but it's convex, aluminum and says "ALT STATIC" on it. Thanks, Precise Flight! Quote Link to comment Share on other sites More sharing options...
aajones5 Posted April 24, 2017 Author Report Share Posted April 24, 2017 What could I do to test if it is the alt static or not Quote Link to comment Share on other sites More sharing options...
bradp Posted April 24, 2017 Report Share Posted April 24, 2017 Tape off one static port. To the other cut a hole in a suction cup and stick a small (10cc) slip tip syringe. Create a suction on the port using your little syringe tool. Pull until the altimeter just moves. Like no more than 20-40 ft as not to damage the instrument by "dropping it" when you pull the alternate static. Have a buddy pull the handle when you are 20 ft higher or so. if it's the alternate static your altimeter will drop back down. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
takair Posted April 24, 2017 Report Share Posted April 24, 2017 It's where my cowl flaps are. Is it possible someone tried to modify the fixed cowl flaps to make them movable, and they are not working right? Perhaps the spring back is because whatever it is trying to move is stuck? Quote Link to comment Share on other sites More sharing options...
Yetti Posted April 24, 2017 Report Share Posted April 24, 2017 The cable being frozen from rust will also cause what you are experiencing. Quote Link to comment Share on other sites More sharing options...
Guest Posted April 24, 2017 Report Share Posted April 24, 2017 I'd guess that it's the control for an SVS valve. Do you have a red warning light for low vacuum on the panel? Clarence Quote Link to comment Share on other sites More sharing options...
PTK Posted April 24, 2017 Report Share Posted April 24, 2017 I agree with Clarence. It looks like control for SVS (stanby vac source) valve. Quote Link to comment Share on other sites More sharing options...
aajones5 Posted April 24, 2017 Author Report Share Posted April 24, 2017 I don't have a low vac light on but I did see this Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
aajones5 Posted April 24, 2017 Author Report Share Posted April 24, 2017 I always thought that switch next to it was the alt static source but that's the valve behind the vsi in the bottom pic so I guess that's my alt static source, I took the top part of the panel off so I could see better behind it but I still couldn't see there that black valve connected to. Also my cowl flaps are pretty fixed they definitely wouldn't be connected to that Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
