par Posted March 27, 2017 Report Share Posted March 27, 2017 I don't know what else to say but to offer every cent I have. You guys decide for yourselves. 2 Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 27, 2017 Report Share Posted March 27, 2017 (edited) I like the LS6 series of engines, it's the gearbox that has always been the weight / strength challenge. Running full out is not the design spec for the LS engine either. 5000rpm for a 1/4 mile yes, continuous jet like performance...? Tell me what you think... Best regards, -a- Edited March 27, 2017 by carusoam Quote Link to comment Share on other sites More sharing options...
HRM Posted March 27, 2017 Report Share Posted March 27, 2017 Prices start at $89,950 (FOB manufacturer) and can be purchased as a complete kit, or as sub-kit deliveries. Retractable landing gear, engine gear box, fan assemblies and engine mount are included in the cost of the kit. Build time is advertised at 2000-2500 hours, and a total flying cost is projected to be as low as $125,000 USD. Quote Link to comment Share on other sites More sharing options...
Hank Posted March 27, 2017 Report Share Posted March 27, 2017 He gave ax speed of 200 mph, stall speed like a 182, but skipped right over cruise speed. No me tonight of fuel burn, either. Hmmm . . . . . Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 27, 2017 Report Share Posted March 27, 2017 (edited) Think corvette engine at full throttle... 5000rpm geared up to 6000rpm at the fans. Somewhere around 400hp 500ft-Lbs of torque (based on old memory) The engine builder said the gear box is 1.4:1 ratio. Doing the math, 6/5, Siri got 1.2:1 The radiators must be gigantic. They brought it from Russia to show at SnF. But, it isn't near complete yet... the retract landing gear is still fixed down. 'They ran out of time' 200 mph top speed 59 mph stall, flaps down 45 hours of flying done in Russia. No idea what happened to the cruise speed, it got garbled by the video. available by the end of the year. they're going to need to polish a few things... Best regards, -a- Edited March 27, 2017 by carusoam Quote Link to comment Share on other sites More sharing options...
par Posted March 27, 2017 Author Report Share Posted March 27, 2017 41 minutes ago, carusoam said: Think corvette engine at full throttle... 5000rpm geared up to 6000rpm at the fans. Somewhere around 400hp 500ft-Lbs of torque (based on old memory) The engine builder said the gear box is 1.4:1 ratio. Doing the math, 6/5, Siri got 1.2:1 The radiators must be gigantic. They brought it from Russia to show at SnF. But, it isn't near complete yet... the retract landing gear is still fixed down. 'They ran out of time' 200 mph top speed 59 mph stall, flaps down 45 hours of flying done in Russia. No idea what happened to the cruise speed, it got garbled by the video. available by the end of the year. they're going to need to polish a few things... Best regards, -a- So if I understand you correctly, I have to wait a little longer to give up all my money? 1 Quote Link to comment Share on other sites More sharing options...
Skates97 Posted March 27, 2017 Report Share Posted March 27, 2017 I can get you the LS6 at or below cost, benefits of working as Parts Director (soon to be Controller) for three GM Dealerships... I'd be happy to do that in exchange for a ride in it after you've built and tested it. 4 Quote Link to comment Share on other sites More sharing options...
par Posted March 27, 2017 Author Report Share Posted March 27, 2017 4 minutes ago, Skates97 said: I can get you the LS6 at or below cost, benefits of working as Parts Director (soon to be Controller) for three GM Dealerships... I'd be happy to do that in exchange for a ride in it after you've built and tested it. Don't tempt me with a good time! I've always to build a fast experimental using an LS motor. Of course, it would be one hell of a project to undertake and the results could be less than ideal. I don't know if I would ever build something like this using a piston engine but I may take you up on that offer for a Lancair someday. Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 27, 2017 Report Share Posted March 27, 2017 (edited) Richard, See if you can liberate an LS7 at cost for your friends. Complete with all the sensors and controllers.... 505 hp and gobs of torque, for the bird (almost aviation related) firebird that is... A 15AMU device... Par, The 2:1 gearbox for an ordinary prop turning 2700 rpm has been the deathknell of using the Corvette engine for aviation applications. from my industrial experience that gear box is quite heavy. To do it in aviation weights, it needs to be extremely strong. Aluminum hasn't been the right stuff... Best regards, -a- Edited March 27, 2017 by carusoam 1 Quote Link to comment Share on other sites More sharing options...
Yooper Rocketman Posted March 27, 2017 Report Share Posted March 27, 2017 8 hours ago, par said: Don't tempt me with a good time! I've always to build a fast experimental using an LS motor. Of course, it would be one hell of a project to undertake and the results could be less than ideal. I don't know if I would ever build something like this using a piston engine but I may take you up on that offer for a Lancair someday. You building a Lancair or planning to build one? Which model? I would stick with an aviation engine when you get to that point. Way too many have gone down the automotive engine path with pretty poor results, the best being a financial disaster and the worst being fatal. I had that same desire, being a muscle car owner and drag racer, but was convinced over time that's a match that just doesn't work. Tom 1 Quote Link to comment Share on other sites More sharing options...
XXX Posted March 27, 2017 Report Share Posted March 27, 2017 Mixing Corvettes and Aircraft, not a good idea... https://www.craigslist.org/about/best/cha/5270430991.html 3 Quote Link to comment Share on other sites More sharing options...
TonyK Posted March 27, 2017 Report Share Posted March 27, 2017 Just my musings but it seems like an awful lot of engine for very modest pay off in speed. 1 Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted March 27, 2017 Report Share Posted March 27, 2017 That plan seems kinda slow given how pointy-fast it looks. it looks like a fighter jet but powered like a bonanza. although it is aerobatic capable. it reminds me of one of those kit car conversions where you can make a Volkswagen bug look like say a Ferrari / so it looks great but won't perform like a Ferrari - but maybe looks good is good enough- as riccardo montelban character on snl years ago said, "it's not how you feel - it's how you look... and look marvelous!" 1 Quote Link to comment Share on other sites More sharing options...
par Posted March 27, 2017 Author Report Share Posted March 27, 2017 2 hours ago, Yooper Rocketman said: You building a Lancair or planning to build one? Which model? I would stick with an aviation engine when you get to that point. Way too many have gone down the automotive engine path with pretty poor results, the best being a financial disaster and the worst being fatal. I had that same desire, being a muscle car owner and drag racer, but was convinced over time that's a match that just doesn't work. Tom At this point, it's just a dream. I haven't through about exactly which model I will go with but I know it will be a lancair. I also agree with you re the engine choice. I have read a lot of negative stuff about car to plane transitions and I def don't want to pick from the two choices you listed. I'm hopeful that we will have a good turbine solution by that point as that would make for the ultimate fast plane. 1 Quote Link to comment Share on other sites More sharing options...
par Posted March 27, 2017 Author Report Share Posted March 27, 2017 11 hours ago, carusoam said: Richard, See if you can liberate an LS7 at cost for your friends. Complete with all the sensors and controllers.... 505 hp and gobs of torque, for the bird (almost aviation related) firebird that is... A 15AMU device... Par, The 2:1 gearbox for an ordinary prop turning 2700 rpm has been the deathknell of using the Corvette engine for aviation applications. from my industrial experience that gear box is quite heavy. To do it in aviation weights, it needs to be extremely strong. Aluminum hasn't been the right stuff... Best regards, -a- What do you think about titanium gears? Is there a reason why this doesn't already exist? Quote Link to comment Share on other sites More sharing options...
DAVIDWH Posted March 27, 2017 Report Share Posted March 27, 2017 Cmon guys....$125,000 for a kit?? You can buy a real plane, MIG 21 on Warbird News for $150,000 negotiable down to that price. Has Mach 2 speed complete with parachutes. Did I forget something?? Oh yeah, operational cost of (conservative) $4,500 per hour. These figures go out the window when afterburner is deployed. Hard to remember everything. Quote Link to comment Share on other sites More sharing options...
carusoam Posted March 27, 2017 Report Share Posted March 27, 2017 (edited) Gears are important, but the box itself has to withstand all the forces. The box is large. Especially compared to an aviation gearbox. We have a constant speed prop for adjusting rpm. Titanium has some quirks. Expensive. Hard to machine, and not as rigid as steal or aluminum.(?) have to look up some of these details... Some of the Migs weren't so high tech. Lots of steal used in place of titanium. So I have read... Best regards, -a- Edited March 27, 2017 by carusoam Quote Link to comment Share on other sites More sharing options...
201er Posted March 27, 2017 Report Share Posted March 27, 2017 15 hours ago, Hank said: He gave ax speed of 200 mph, stall speed like a 182, but skipped right over cruise speed. No me tonight of fuel burn, either. Hmmm . . . . . The data sheet in the video shows 187mph cruise. Then again a 201 is supposed to go 201mph... Quote Link to comment Share on other sites More sharing options...
201er Posted March 27, 2017 Report Share Posted March 27, 2017 Just found their spec sheet on their website: http://dreameravia.com/sky-world SPECIFICATION Fuselage Length 8,435 m(27’8”) Maximum Height 3,015 m(9’9”) Wing Span 8,025 m(26’4”) Wing Area 10 sq. m(106,17 sq. ft.) Wing Loading 130 kg/sq. m(27 lb/sq.ft.) Wing Airfoil LS(1) - 0413 Structural limit loads +4,4/-2,2 Gs Maximum gross weight 1380 kg(3,036 lbs) Empty weight 986 kg(2,169 lbs) Fuel Capacity 280 liters(74 gals) Fuel Consumption 57 lph(15 gph) POWER PLANT Engine GM LS6 V8 388 hp@5000rpm PERFORMANCE Top Speed at S/L 350 km/h(218 mph) Cruise Speed 300 km/h(187 mph) Stall Speed (no flaps) 120 km/h(75 mph) Stall Speed(full flaps) 90 km/h(56 mph) Rate of Climb at S/L 14 m/s(2500 fpm) Range 1200 km(750 mi) Quote Link to comment Share on other sites More sharing options...
Alain B Posted March 27, 2017 Report Share Posted March 27, 2017 I will stick to a Continental , or a Lycoming , or Jacobs , or P&W .......... . Leave the car engine where they belong : on the ground . 2 Quote Link to comment Share on other sites More sharing options...
201er Posted March 27, 2017 Report Share Posted March 27, 2017 Just now, Alain B said: I will stick to a Continental , or a Lycoming , or Jacobs , or P&W .......... . Leave the car engine where they belong : on the ground . I don't know about the short vs long term issues with these engines, but for the price of it, you could put in a factory new LS engine every 500 hours for less than the cost of the upkeep/overhaul of a proper aviation engine. Just a thought. 2 Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted March 27, 2017 Report Share Posted March 27, 2017 I like it always thought about doing something like this. Quote Link to comment Share on other sites More sharing options...
Alain B Posted March 27, 2017 Report Share Posted March 27, 2017 13 minutes ago, 201er said: I don't know about the short vs long term issues with these engines, but for the price of it, you could put in a factory new LS engine every 500 hours for less than the cost of the upkeep/overhaul of a proper aviation engine. Just a thought. A car engine running at high rpm constantly will not make 500 hours without a breakage of some sort . Look at a Nascar engine , they are extensively modified , in many cases cost more then an aircraft engine ( due to the expensive parts and modifications inside ) , have special oiling system , are maintained by top mechanics , and in some case cannot even go 500 miles without blowing up , much less 500 hours . Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted March 27, 2017 Report Share Posted March 27, 2017 23 minutes ago, 201er said: Just found their spec sheet on their website: http://dreameravia.com/sky-world SPECIFICATION Fuselage Length 8,435 m(27’8”) Maximum Height 3,015 m(9’9”) Wing Span 8,025 m(26’4”) Wing Area 10 sq. m(106,17 sq. ft.) Wing Loading 130 kg/sq. m(27 lb/sq.ft.) Wing Airfoil LS(1) - 0413 Structural limit loads +4,4/-2,2 Gs Maximum gross weight 1380 kg(3,036 lbs) Empty weight 986 kg(2,169 lbs) Fuel Capacity 280 liters(74 gals) Fuel Consumption 57 lph(15 gph) POWER PLANT Engine GM LS6 V8 388 hp@5000rpm PERFORMANCE Top Speed at S/L 350 km/h(218 mph) Cruise Speed 300 km/h(187 mph) Stall Speed (no flaps) 120 km/h(75 mph) Stall Speed(full flaps) 90 km/h(56 mph) Rate of Climb at S/L 14 m/s(2500 fpm) Range 1200 km(750 mi) Ironically, I bet that car engine will make that corvette car go about as fast as that airplane. Quote Link to comment Share on other sites More sharing options...
Marauder Posted March 27, 2017 Report Share Posted March 27, 2017 Ironically, I bet that car engine will make that corvette car go about as fast as that airplane. Pretty close. My Corvette with the LS engine had a 175 MPH top speed. Sent from my iPhone using Tapatalk Pro 1 Quote Link to comment Share on other sites More sharing options...
