rogerl Posted March 25, 2017 Report Share Posted March 25, 2017 (edited) who owns it Edited March 14, 2021 by rogerl Quote Link to comment Share on other sites More sharing options...
FoxMike Posted March 25, 2017 Report Share Posted March 25, 2017 I have a 99 Bravo and I had the same sort of problem. Low fuel warning started at 8 gal. The fix is in your maintenance manual. It requires you to fly or drain the tanks down to whatever level you want the warning to start, remove the faceplate off the annunciator find the correct switch and energize it for a moment and the tank is now calibrated. You either need a manual or a Mooney Service Center to do this right. I flew one tank at a time down to the 3 gal level so it took two shots to get it done. Good Luck! Quote Link to comment Share on other sites More sharing options...
Cruiser Posted March 25, 2017 Report Share Posted March 25, 2017 sounds like one of the floats are stuck. Put more fuel in, go fly do some steep turns etc. If it does not clear, you will need maintenance. 1 Quote Link to comment Share on other sites More sharing options...
