Flymac Posted March 21, 2017 Report Share Posted March 21, 2017 Going though Annual and wanting to address many various areas on the roll cage and control rods/tubes where the original ZC primer has worn off leaving them exposed. It doesnt seem to practical to try and re-spray these with a can of ZC for not only getting on everything packed in the areas, but also seems would only get bottom surface...is there a general approach/trick to how people touch these tubes up? ZC sprayed into a can(or purchased as non aerosol) and then brushed on perhaps? I can see various areas where it looks like someone had touched up with a brush, but is black like an enamel paint or such... Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted March 21, 2017 Report Share Posted March 21, 2017 I'd say anything is better than nothing. Brushing makes more sense in there. Just remove any obvious rust/corrosion by sanding, clean it well, and paint. Then don't worry about it for another decade or two!Sent from my LG-LS997 using Tapatalk Quote Link to comment Share on other sites More sharing options...
rbridges Posted March 22, 2017 Report Share Posted March 22, 2017 I sanded and painted the areas with rustoleum primer and paint. 1 Quote Link to comment Share on other sites More sharing options...
RLCarter Posted March 22, 2017 Report Share Posted March 22, 2017 5 hours ago, KSMooniac said: I'd say anything is better than nothing. Brushing makes more sense in there. Just remove any obvious rust/corrosion by sanding, clean it well, and paint. Then don't worry about it for another decade or two! Sent from my LG-LS997 using Tapatalk An airbrush works really well too, you can pick one up from Harbor Freight for around 20 bucks Quote Link to comment Share on other sites More sharing options...
Shadrach Posted March 22, 2017 Report Share Posted March 22, 2017 I used a two part zinc chromate epoxy primer and a small brush. You can use zinc chromate or zinc phosphate epoxy. Both available from spruce. Seems expensive for paint but this will be the last time it ever needs to be done. Wear a respirator...no seriously, wear a respirator! Quote Link to comment Share on other sites More sharing options...
