Raptor05121 Posted February 23, 2017 Report Share Posted February 23, 2017 6 hours ago, MooneyMitch said: Oceano Airport L52 is 2315 feet. So far you're in the lead with shortest runway. My home airport is 4,037 feet. I assume the last 37 feet is so it is eligible for a GPS approach which we just recently got. I do 80 over the fence if I'm lazy, but sometimes I'll try 75 and it makes it easier to plant the plane on my aimpoint. Quote Link to comment Share on other sites More sharing options...
Shadrach Posted February 23, 2017 Report Share Posted February 23, 2017 9 minutes ago, Raptor05121 said: So far you're in the lead with shortest runway. My home airport is 4,037 feet. I assume the last 37 feet is so it is eligible for a GPS approach which we just recently got. I do 80 over the fence if I'm lazy, but sometimes I'll try 75 and it makes it easier to plant the plane on my aimpoint. 80 won't work for places like these! http://www.airnav.com/airport/MD42 http://www.airnav.com/airport/2W2 Quote Link to comment Share on other sites More sharing options...
midlifeflyer Posted February 23, 2017 Report Share Posted February 23, 2017 Does it have to be in a Mooney? If not, my old home base in CT was 1800'. Mostly fixed gear Cessnas but I did fly an Arrow there once. Short field set up, whatever you flew. OTOH, the shortest runway at my next home base was 4800' which felt pretty short since the MSL altitude was 5885'. Flew an M20C out of there. Quote Link to comment Share on other sites More sharing options...
Andy95W Posted February 23, 2017 Report Share Posted February 23, 2017 Due to displaced thresholds at both ends, my airport (Y47) is 2264 x 40 landing west and a whopping 1862 landing east. And the surface is crappy, too. 70 miles per hour on short final, full flaps, retract the flaps to get better braking shortly after touchdown. When I'm by myself I'm doing closer to 65 MPH on short final as I cross the airport boundary. But that's nothing for an M20C. A friend used to fly his Ovation 3 out of my airport. 3 Quote Link to comment Share on other sites More sharing options...
flight2000 Posted February 23, 2017 Report Share Posted February 23, 2017 KRNO: 11001x150 for 16R/34L or 9000x150 for 16L/34R. Runway 25/07 is the shorty at 6102x150, but rarely gets used. Field elevation is 4,420 msl. Brian Quote Link to comment Share on other sites More sharing options...
170driver Posted February 23, 2017 Report Share Posted February 23, 2017 CYNJ - most often use 01/19 which is 2100' long. 80mph on final - maybe 75 over the fence - I don't often look at that point!Field is 34' ASLDaveSent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
AH-1 Cobra Pilot Posted February 23, 2017 Report Share Posted February 23, 2017 Longest runway = 12,901'. Anything under 110kts will do. It is a former B-47 and B-58 SAC Base; now it is was an alternate Shuttle landing site. The short one is 5800'. I plan on 70+/-5. 1 Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted February 23, 2017 Report Share Posted February 23, 2017 O O O O Does landing on a helicopter dolly count? In that case 20' and 6"AGL Quote Link to comment Share on other sites More sharing options...
milotron Posted February 23, 2017 Report Share Posted February 23, 2017 I am CYYJ 7000' and two crosswinds at about 5000'. 61' ASL. 70-80kts over the fence and I am clear of active before the half way mark. 8 hours ago, 170driver said: CYNJ - most often use 01/19 which is 2100' long. 80mph on final - maybe 75 over the fence - I don't often look at that point! Field is 34' ASL Dave Sent from my iPhone using Tapatalk Funny I was just wondering about operations out of Langley as I need to do some work in the area. Glad to see another wet coast canuck on the board, Quote Link to comment Share on other sites More sharing options...
Oldguy Posted February 23, 2017 Report Share Posted February 23, 2017 03/21 at KPLR is 5001' X 80'. Land 03 75-80 kts over the fence and 70 kts landing 21. Hangar is towards the north end of the field. Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted February 23, 2017 Report Share Posted February 23, 2017 I learned to fly and then got checked out in my first Mooney at 5TX0 which is 2600 x 35 and sloped downhill on most days. Quote Link to comment Share on other sites More sharing options...
TWinter Posted February 23, 2017 Report Share Posted February 23, 2017 On 2/22/2017 at 11:42 AM, Hank said: I've moved from 3000' obstructed at both ends, 567 msl, to 3200' mostly open but far from level at 326 msl. 70-75 mph works well on short final. Landing on 31, if I'm on speed, hardly need brakes to make the turnoff to the hangar. Hank, If there continues to be that much activity you guys will need a tower at the field. 1 Quote Link to comment Share on other sites More sharing options...
170driver Posted February 23, 2017 Report Share Posted February 23, 2017 I am CYYJ 7000' and two crosswinds at about 5000'. 61' ASL. 70-80kts over the fence and I am clear of active before the half way mark. Funny I was just wondering about operations out of Langley as I need to do some work in the area. Glad to see another wet coast canuck on the board, I haven't tried departing at gross on a hot day - would opt for 07/25 at 2700'. Did t/o from Okotoks at gross on a 29 deg day a couple of years ago. 3500' rwy and wheels were off a little past the halfway point, so wouldn't try it with 2100'. DaveSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
bonal Posted February 23, 2017 Report Share Posted February 23, 2017 8 hours ago, 1964-M20E said: O O O O Does landing on a helicopter dolly count? In that case 20' and 6"AGL Come in steep 70mph parking brake set hit the dolly dead center and see how far it rolls 3 Quote Link to comment Share on other sites More sharing options...
bonal Posted February 23, 2017 Report Share Posted February 23, 2017 you didn't say you were actually landing a helicopter only that you were landing on a helicopter dolly 1 Quote Link to comment Share on other sites More sharing options...
Hank Posted February 23, 2017 Report Share Posted February 23, 2017 1 hour ago, TWinter said: Hank, If there continues to be that much activity you guys will need a tower at the field. A plane is being rehabbed now, so traffic should soon double! (Hey, two planes should generate twice the traffic of one, right?) 1 Quote Link to comment Share on other sites More sharing options...
Pritch Posted February 23, 2017 Author Report Share Posted February 23, 2017 36 minutes ago, Hank said: A plane is being rehabbed now, so traffic should soon double! (Hey, two planes should generate twice the traffic of one, right?) So right now it a Mooney's only exclusive airport? Quote Link to comment Share on other sites More sharing options...
Hank Posted February 23, 2017 Report Share Posted February 23, 2017 Just now, Pritch said: So right now it a Mooney's only exclusive airport? Quote Link to comment Share on other sites More sharing options...
Guest Posted February 23, 2017 Report Share Posted February 23, 2017 At my home field landing on 08, making the intersection in my Mooneys was easy, as are the RV4 and 400. Clarence Quote Link to comment Share on other sites More sharing options...
Skates97 Posted February 24, 2017 Report Share Posted February 24, 2017 47 minutes ago, Hank said: A plane is being rehabbed now, so traffic should soon double! (Hey, two planes should generate twice the traffic of one, right?) Hank, which hangar is yours? 1 Quote Link to comment Share on other sites More sharing options...
75_M20F Posted February 26, 2017 Report Share Posted February 26, 2017 (edited) KGSO is where my Mooney F model lives..... 3 runways 10,001 foot runway 9,000 foot runway 6,380 foot runway Taking off I am at pattern altitude with runway still under me, kind of comforting in a way. Control tower with radar also Edited February 26, 2017 by Mooney_Mike Quote Link to comment Share on other sites More sharing options...
Mooneymite Posted February 27, 2017 Report Share Posted February 27, 2017 In all these discussions of Mooneys that can land in very short distances, it is interesting to note that for LAHSO operations, the FAA does not think Mooneys can stop very well. While many (most?) common GA aircraft are considered group 1, or 2, the FAA puts all M-20's into group 4.....requiring 4000', or more for LAHSO operations. The notable exception: The M-18 Mite is group 1: 2500'. https://www.faa.gov/documentLibrary/media/Order/7110.118.pdf Quote Link to comment Share on other sites More sharing options...
Hank Posted February 28, 2017 Report Share Posted February 28, 2017 4 hours ago, Mooneymite said: In all these discussions of Mooneys that can land in very short distances, it is interesting to note that for LAHSO operations, the FAA does not think Mooneys can stop very well. While many (most?) common GA aircraft are considered group 1, or 2, the FAA puts all M-20's into group 4.....requiring 4000', or more for LAHSO operations. The notable exception: The M-18 Mite is group 1: 2500'. https://www.faa.gov/documentLibrary/media/Order/7110.118.pdf Yep, there we are in Group 4 along with the Cessna 170 and the Turbo Meridian. Wonder what makes moving the nose wheel to the tail push the 170 so much further along than the 172? Apparently Mooneys flown by superior pilots (as are often found here! ) are in the minority among all Mooneys in the GA fleet. But then again, this is government, so it does not have to make sense. Quote Link to comment Share on other sites More sharing options...
peevee Posted February 28, 2017 Report Share Posted February 28, 2017 12 minutes ago, Hank said: Yep, there we are in Group 4 along with the Cessna 170 and the Turbo Meridian. Wonder what makes moving the nose wheel to the tail push the 170 so much further along than the 172? Apparently Mooneys flown by superior pilots (as are often found here! ) are in the minority among all Mooneys in the GA fleet. But then again, this is government, so it does not have to make sense. I personally find the mooney brakes to be mostly garbage, but ours is a heavy pig. Quote Link to comment Share on other sites More sharing options...
Shadrach Posted February 28, 2017 Report Share Posted February 28, 2017 It's interesting that the same Cleavland brake hardware installed on different makes of aircraft in similar weight catagories so often get maligned in one application yet praised in another. I theorize that most Mooney braking issues come from pilots trying to use brakes to slow an airplane with very little of it's weight on the wheels. 1 Quote Link to comment Share on other sites More sharing options...
