CJpilot316 Posted February 20, 2017 Report Share Posted February 20, 2017 Hey all! i just came out of a very extensive annual with my new-to-me '67 M20C. The last squawk that needs to be addressed is a leak in the fuel pressure gauge line, in front of the firewall. It appears a clamp has chafed it. Does anybody have a part number or a place to get the hose, or is it just a generic cut part? Also, the plane has the positive control system, which I am not familiar with. How exactly does the system work, and how do I disable it? I do have the button on the yoke that I though was the disconnect. Anybody have some insight here? -Cody Quote Link to comment Share on other sites More sharing options...
Lrn2Fly Posted February 20, 2017 Report Share Posted February 20, 2017 The button on your yoke has 2 functions - press it to temporarily disable the PC, or pull the button out about 1/4" or so to keep it disabled. The vacuum pump runs the entire system. There are 4 servos that are vacuum operated - one per wing, and 2 in the back for the rudder. There is the gyro above your left knee that detects turn, just like your turn coordinator. It directs each servo to either pull or release pressure to the airlerons and rudder to keep the plane flying level. You also have the trim wheel on your yoke to make fine adjustments, which merely balances the vacuum to the 4 servos. When it's working, it's a pretty simple system. When it isn't working correctly, it is a real pain and must be fixed. Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted February 20, 2017 Report Share Posted February 20, 2017 3 minutes ago, Lrn2Fly said: The button on your yoke has 2 functions - press it to temporarily disable the PC, or pull the button out about 1/4" or so to keep it disabled. The vacuum pump runs the entire system. There are 4 servos that are vacuum operated - one per wing, and 2 in the back for the rudder. There is the gyro above your left knee that detects turn, just like your turn coordinator. It directs each servo to either pull or release pressure to the airlerons and rudder to keep the plane flying level. You also have the trim wheel on your yoke to make fine adjustments, which merely balances the vacuum to the 4 servos. When it's working, it's a pretty simple system. When it isn't working correctly, it is a real pain and must be fixed. I've owned 2 '66Es. The first one had only the Brittain PC system when I bought it and I liked it a lot. Now that our Vintage planes are 50 years old it should not be a surprise that there might be leaks in servos and the plastic air lines. These are relatively easy to find and fix. And relative to anything aircraft related, cheap. That PC is a life saver. I will permit you to look away for a while without the plane trying to do an aileron roll on you. Mooneys are slick, at least compared to Pipers and Cessnas. The knob to tweak the wings level can also be used for command turns. Play with it. Quote Link to comment Share on other sites More sharing options...
Yetti Posted February 20, 2017 Report Share Posted February 20, 2017 PHT hoses in Tulsa should have the hose. Ask for the upgraded brown hose with integrated fire sleeve. 1 Quote Link to comment Share on other sites More sharing options...
CJpilot316 Posted February 20, 2017 Author Report Share Posted February 20, 2017 6 hours ago, Yetti said: PHT hoses in Tulsa should have the hose. Ask for the upgraded brown hose with integrated fire sleeve. They had it! Thank you! 1 Quote Link to comment Share on other sites More sharing options...
Raptor05121 Posted February 21, 2017 Report Share Posted February 21, 2017 Cody, you need to update your tail number. And tell the ladies and gentlemen who's plane you got to play with over the weekend. 2 Quote Link to comment Share on other sites More sharing options...
cliffy Posted February 21, 2017 Report Share Posted February 21, 2017 The correct PC tubing is color coded for each servo available from Brittain, The hose connectors are actually auto vacuum hose specified by the autopilot manufacturer (Brittain). Check with them and they will be able to help you out. They are real easy to deal with. Quote Link to comment Share on other sites More sharing options...
CJpilot316 Posted February 21, 2017 Author Report Share Posted February 21, 2017 3 hours ago, Raptor05121 said: Cody, you need to update your tail number. And tell the ladies and gentlemen who's plane you got to play with over the weekend. Don't worry brother, I'm gonna post a nice aircraft intro/story when I actually fly mine next week. Very few know the tail number and have seen the pics yet. Quote Link to comment Share on other sites More sharing options...
Hector Posted February 22, 2017 Report Share Posted February 22, 2017 I would definitely try to fix the PC. Once fixed it is very reliable and very nice to have in IMC conditions. Also, at that point you can add a Britain Accutrack autopilot for little money. They show up for sale here once in a while. Additionally, and for added convenience, you can install a separate switch to turn the PC system on and off. I have it on my C and love it. Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
CJpilot316 Posted February 22, 2017 Author Report Share Posted February 22, 2017 52 minutes ago, Hector said: I would definitely try to fix the PC. Once fixed it is very reliable and very nice to have in IMC conditions. Also, at that point you can add a Britain Accutrack autopilot for little money. They show up for sale here once in a while. Additionally, and for added convenience, you can install a separate switch to turn the PC system on and off. I have it on my C and love it. Sent from my iPad using Tapatalk To my knowledge, the system is working properly. What is required for parts to put the accutrak in? Quote Link to comment Share on other sites More sharing options...
Hector Posted February 22, 2017 Report Share Posted February 22, 2017 To my knowledge, the system is working properly. What is required for parts to put the accutrak in? You need a BI-805 servo control valve and an acutrack or accutrack II box. Your plane may already have the servo control valve but not sure. Go to the Brittain website for more details. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
