M20S Driver Posted February 12, 2017 Report Share Posted February 12, 2017 The oil and fuel lines in my 1999 Mooney Eagle need replacement according my mechanic and Continental Tech Support. I have the rec "C" lines which are rated for 7 years. He is recommending to go to rev "D" which is teflon and is rated for 12+ years. Anyone has done this on io550? if yes, any recommendation on where to get the hoses made for the best quality and price? Driver Quote Link to comment Share on other sites More sharing options...
Yetti Posted February 12, 2017 Report Share Posted February 12, 2017 PHT in Tulsa. get the upgraded integral fire sleeve 2 Quote Link to comment Share on other sites More sharing options...
Guest Posted February 12, 2017 Report Share Posted February 12, 2017 Guy Ginbey a poster here does hose assemblies as well as a bunch of other neat things. www.csobeech.com Clarence Quote Link to comment Share on other sites More sharing options...
jetdriven Posted February 13, 2017 Report Share Posted February 13, 2017 10 hours ago, Yetti said: PHT in Tulsa. get the upgraded integral fire sleeve I have them. They're called 124J hoses. Teflon has an "on condition" service life, which is a very long time. Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted February 13, 2017 Author Report Share Posted February 13, 2017 Thanks for the feedbacks. We are targeting to replace them in March. Quote Link to comment Share on other sites More sharing options...
Yetti Posted February 13, 2017 Report Share Posted February 13, 2017 9 hours ago, jetdriven said: I have them. They're called 124J hoses. Teflon has an "on condition" service life, which is a very long time. The professional mechanic mumbled about them get a set and being hard to handle after awhile....As long as they remain connected to things, they should be good. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted February 13, 2017 Report Share Posted February 13, 2017 If you read ac43.13 it says that teflon hoses take a set and get stiff and it's normal. Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted February 13, 2017 Report Share Posted February 13, 2017 If you read ac43.13 it says that teflon hoses take a set and get stiff and it's normal. Stupid ?, can you tell type of hose by visual inspection, in boating world all quality hoses have detailed description of the hose printed on it, if it doesn't then you know it's junk. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted February 13, 2017 Report Share Posted February 13, 2017 They should have a welded data tag which shows the part number and the date of last pressure test. The lower right corner will say something like PT 04/14. Which is pressure test April 2014. Usually this is date of manufacture as well Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted February 14, 2017 Author Report Share Posted February 14, 2017 My engine has 1200 hours on it. Does it make sense to put a more expensive teflon type hose on it that is rated for 12 years plus? The regular hoses are rated for 7 years but are less expensive. I may have to overhaul it in 5-8 years and the hoses will be replace at overhaul. Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted February 14, 2017 Report Share Posted February 14, 2017 My engine has 1200 hours on it. Does it make sense to put a more expensive teflon type hose on it that is rated for 12 years plus? The regular hoses are rated for 7 years but are less expensive. I may have to overhaul it in 5-8 years and the hoses will be replace at overhaul. Do the hoses have to be replaced? You don't have to do an overhaul at 2000 hours, you may need to do one at 1300 hours or 3000 hours. It's a crapshoot anyway. 1 Quote Link to comment Share on other sites More sharing options...
Yetti Posted February 14, 2017 Report Share Posted February 14, 2017 I think it was only 10% of the price for the upgraded hoses. The upgraded hose are thinner. The mooney engine compartment is pretty cramped. It saves the time of having to install fire sleeve. I say totally worth the price. 1 Quote Link to comment Share on other sites More sharing options...
jetdriven Posted February 14, 2017 Report Share Posted February 14, 2017 9 hours ago, M20S Driver said: My engine has 1200 hours on it. Does it make sense to put a more expensive teflon type hose on it that is rated for 12 years plus? The regular hoses are rated for 7 years but are less expensive. I may have to overhaul it in 5-8 years and the hoses will be replace at overhaul. If you have 5-8 year old hoses, why replace them at the overhaul Period? Inspect and then reinstall them. A friend I know had a rubber oil hose on his plane from 1968. Somehow it got overlooked but it was still holding up.odern hoses are Even better than that 1 Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted February 14, 2017 Author Report Share Posted February 14, 2017 49 minutes ago, jetdriven said: If you have 5-8 year old hoses, why replace them at the overhaul Period? Inspect and then reinstall them. A friend I know had a rubber oil hose on his plane from 1968. Somehow it got overlooked but it was still holding up.odern hoses are Even better than that I assumed they came with an overhauled engine. If not, I agree... Quote Link to comment Share on other sites More sharing options...
kortopates Posted February 22, 2017 Report Share Posted February 22, 2017 On 2/14/2017 at 7:33 AM, jetdriven said: If you have 5-8 year old hoses, why replace them at the overhaul Period? Inspect and then reinstall them. A friend I know had a rubber oil hose on his plane from 1968. Somehow it got overlooked but it was still holding up.odern hoses are Even better than that Don't disagree with how modern hoses can last a long time. But the OEM limits what items can be re-installed on condition when doing an engine overhaul. If the hoses in question are hoses that the engine manufacturer provides with the certified engine (as opposed to hoses provided by the airframe manufacturer) and then secondly the manufacturer specifies the hoses must be replaced as part of a Major Overhaul then any overhaul that doesn't include replacing them can't legally be logged as a Major overhaul - just an IRAN. And legally, then TSMOH doesn't get reset and resale value of the engine takes a major hit. Major overhaul actually has legal meaning in that the engine has been overhauled IAW with the manufacturers (minimum) specifications. This is true also with some appliances like starter and magnetos which the manufacturer list as requiring replacement or overhaul at time of engine overhaul. Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted March 14, 2017 Author Report Share Posted March 14, 2017 On 2/12/2017 at 8:22 PM, jetdriven said: I have them. They're called 124J hoses. Teflon has an "on condition" service life, which is a very long time. On 2/12/2017 at 9:48 AM, Yetti said: PHT in Tulsa. get the upgraded integral fire sleeve we got the 124J hoses from PHT and my mechanic installed them today... He was very impressed with PHT. Thanks for the info... Driver Quote Link to comment Share on other sites More sharing options...
