scott poms Posted January 17, 2017 Report Share Posted January 17, 2017 (edited) I am finally removing the GE landing lights in my cowl - do I install one landing light and 1 taxi light? or 2 landing lights? I am going with Whelen Prometheus Plus thanks Edited January 17, 2017 by scott poms want relies Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted January 18, 2017 Report Share Posted January 18, 2017 One of each is correct if you are using the Whelen Parmetheus Plus. Having used both if you are going to spend over $200 my preference is the Teledyne Alphabeam - more useful light. I have a business account with Aircraft Spruce and can get 10% off of the Whelen and 14.5% off of the Teledyne lights. PM me if I can help. 1 Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted January 18, 2017 Report Share Posted January 18, 2017 Or better yet, buy some cheap lights directly from Lance and put the old ones on the shelf for when it's annual time ;-) Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted January 18, 2017 Report Share Posted January 18, 2017 I sell the cheaper (Non STC) version which beats the GE incandescent to pieces for $60 each including shipping for the taxi or landing light. They are amazing for the price. But I would be happy to pass on my discount if you want the others. 1 Quote Link to comment Share on other sites More sharing options...
Zwaustin Posted January 18, 2017 Report Share Posted January 18, 2017 I used the Alphabeam in my 231K and had two, one in each spot. They worked well and were very bright. http://www.teledynelighting.com/products/alphabeam.asp Quote Link to comment Share on other sites More sharing options...
Guitarmaster Posted January 23, 2017 Report Share Posted January 23, 2017 $900 for the Alphabeam?? . Yikes! I usually close my eyes for landing anyway. Quote Link to comment Share on other sites More sharing options...
Zwaustin Posted January 23, 2017 Report Share Posted January 23, 2017 One's I had weren't 900...bought two for 550 or so from Aircraft Spruce http://www.aircraftspruce.com/catalog/elpages/teledynelandinglight.php Quote Link to comment Share on other sites More sharing options...
scott poms Posted February 6, 2017 Author Report Share Posted February 6, 2017 A fellow pilot put these on his bonanza: http://www.rigidindustries.com/led-lighting?f[0]=field_product_family%3a5036 Specifically the 40 watt spot and the Flood for taxi, extremely impressed with the build quality of this light, heavy metal housing and very solid construction. The Alphabeams just from the picture look like all plastic. Anyways may go this route and swap back the GE bulbs during annual, if the mechanic even cares. Also talked to an installer that installs Whelens and other LED'S on law enforcement vehicles and he said the RIGID are hands down the finest quality light he installs. Worth looking into as the Bonanza lights up the runway Very well. They have Par 36 and 46 1 Quote Link to comment Share on other sites More sharing options...
kortopates Posted February 6, 2017 Report Share Posted February 6, 2017 If you want the brightest lights, you'll want HID's rather than LED's, but more $ Quote Link to comment Share on other sites More sharing options...
scott poms Posted February 6, 2017 Author Report Share Posted February 6, 2017 55 minutes ago, kortopates said: If you want the brightest lights, you'll want HID's rather than LED's, but more $ Yes I did see that, spending a lot of $$ on avionics this year though, need to cut back somewhere, the LED's will be a huge improvement over my GE 4509's. I know my alternator will like them too ;-) 2 Quote Link to comment Share on other sites More sharing options...
scott poms Posted February 10, 2017 Author Report Share Posted February 10, 2017 Here is a pic 2 Quote Link to comment Share on other sites More sharing options...
NotarPilot Posted February 11, 2017 Report Share Posted February 11, 2017 On 2/6/2017 at 10:35 AM, kortopates said: If you want the brightest lights, you'll want HID's rather than LED's, but more $ I would consider this but don't HIDs get fairly hot? I like my Parmetheus because I turn it on before take off and turn it off right before I pull the mixture. Is this something you can leave on all the time? What's the power draw like? Quote Link to comment Share on other sites More sharing options...
Hank Posted February 11, 2017 Report Share Posted February 11, 2017 (edited) I turned on my Parmetheus to test it after install in Spring '14. Turned it off the first time halfway through my pitot static check Sept. '16. Don't think I've touched the switch since then, it's just On. Edited February 11, 2017 by Hank 1 Quote Link to comment Share on other sites More sharing options...
Jsavage3 Posted February 23, 2017 Report Share Posted February 23, 2017 (edited) I have to say a big plus 1 for the Sunspot 36LX landing lights by AeroLEDs. Two landing lights was recommended to me over the one landing and one taxi light. That is what I did and I've been VERY happy with this setup. These babies turn night into day with essentially no heat and next to zero amperage draw. Easy to install. They last forever...some folks recommend running them for the whole flight...I don't. Can try aiming them, but they're so bright you almost don't need too. I just set these at the same aimpoints as the old GE bulbs. The first picture is of a Sunspot 36LX burning next to a standard GE bulb. The third picture is of two Sunspots burning -- one aimed up a bit and the other down a bit. Sorry, they are obnoxiously bright...and don't stare at the picture because I believe the picture will hurt your eyes...it about blew up my camera... Edited February 23, 2017 by Jsavage3 1 Quote Link to comment Share on other sites More sharing options...
Vlakvark Posted March 14, 2017 Report Share Posted March 14, 2017 Where did you order these ones. I woul like to order them to for my M20K 231 Quote Link to comment Share on other sites More sharing options...
Raptor05121 Posted March 14, 2017 Report Share Posted March 14, 2017 On 2/11/2017 at 3:51 AM, NotarPilot said: I would consider this but don't HIDs get fairly hot? I like my Parmetheus because I turn it on before take off and turn it off right before I pull the mixture. Is this something you can leave on all the time? What's the power draw like? HIDs are cooler than Halogen but generally hotter than LED (depending). 6 hours ago, Vlakvark said: Where did you order these ones. I woul like to order them to for my M20K 231 AircraftSpruce has them Quote Link to comment Share on other sites More sharing options...
Raptor05121 Posted March 14, 2017 Report Share Posted March 14, 2017 On 1/17/2017 at 7:56 PM, LANCECASPER said: I sell the cheaper (Non STC) version which beats the GE incandescent to pieces for $60 each including shipping for the taxi or landing light. They are amazing for the price. But I would be happy to pass on my discount if you want the others. Pics of these $60 wonders??? I just spent $25 for another 4522 that a local mechanic had in hand. I needed something to get into SnF Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted March 14, 2017 Report Share Posted March 14, 2017 6 minutes ago, Raptor05121 said: Pics of these $60 wonders??? I just spent $25 for another 4522 that a local mechanic had in hand. I needed something to get into SnF These might or might not be installed in my 252... depending on hangar fairy activity and backlog Quote Link to comment Share on other sites More sharing options...
Raptor05121 Posted March 14, 2017 Report Share Posted March 14, 2017 On 2/6/2017 at 1:17 PM, scott poms said: A fellow pilot put these on his bonanza: http://www.rigidindustries.com/led-lighting?f[0]=field_product_family%3a5036 Specifically the 40 watt spot and the Flood for taxi, extremely impressed with the build quality of this light, heavy metal housing and very solid construction. The Alphabeams just from the picture look like all plastic. Anyways may go this route and swap back the GE bulbs during annual, if the mechanic even cares. Also talked to an installer that installs Whelens and other LED'S on law enforcement vehicles and he said the RIGID are hands down the finest quality light he installs. Worth looking into as the Bonanza lights up the runway Very well. They have Par 36 and 46 Does he have any pics? I'm very familiar with Rigid Industry's LED lights. They are high dollar, but high quality. Looking at the specs for the PAR46s, I am impressed! They are quoting 4200lumens at 55.8 watts. The Prometheus is only 35W and I think 1800lm or 2,000lm. I found the Rigids for $330 new, or a few open box models for $265. Whats the legality for installing one of these? Quote Link to comment Share on other sites More sharing options...
PTK Posted March 14, 2017 Report Share Posted March 14, 2017 I came across this... https://www.preciseflight.com/news/article/precise-flight-inc-markets-advanced-led-aviation-l/ Quote Link to comment Share on other sites More sharing options...
topsun1 Posted March 16, 2017 Report Share Posted March 16, 2017 I recently installed two AeroLEDs Sunspot 36LX (landing lights only) on my 231 and concur with Jsavage3 . They are great! 1 Quote Link to comment Share on other sites More sharing options...
Brian_tii Posted March 16, 2017 Report Share Posted March 16, 2017 We got the aeroleds Sun Spot 36-4596 going in. Just came out 6 months ago or so, and 100w led that should be brighter than the 4596s that keep burning out that we use now. Supposedly about the brightest par36 you can find (for now). Airplane is in annual now but will try it once it gets out. Its pricey but the Cirrus only has one light, might as well get as bright as possible... http://www.aircraftspruce.com/catalog/elpages/aeroledssunspot11-14580.php?clickkey=1329947 Quote Link to comment Share on other sites More sharing options...
Bryan Posted April 19, 2017 Report Share Posted April 19, 2017 On 3/14/2017 at 6:13 AM, gsxrpilot said: These might or might not be installed in my 252... depending on hangar fairy activity and backlog @LANCECASPER, are yours LED? Looking to upgrade my M20K 231 landing/taxi lights. Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted April 19, 2017 Report Share Posted April 19, 2017 9 minutes ago, Bryan said: @LANCECASPER, are yours LED? Looking to upgrade my M20K 231 landing/taxi lights. Yes they are LED. 1 Quote Link to comment Share on other sites More sharing options...
