Piloto Posted January 18, 2017 Report Share Posted January 18, 2017 4 hours ago, teejayevans said: This is the problem with ground connected to negative side of the DC system, I prefer to see a separate ground connecting engine, fuselage, and static wicks. Aluminum cowlings provide an electric shield to anything in the engine area. But composite cowling provides no protection against electrically charged atmosphere. José Quote Link to comment Share on other sites More sharing options...
NotarPilot Posted January 18, 2017 Report Share Posted January 18, 2017 What is the price point of the EIS-41000? Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted January 19, 2017 Report Share Posted January 19, 2017 Street price on the 4 cylinder is just over $3000 plus installation. Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted January 19, 2017 Report Share Posted January 19, 2017 9 hours ago, LANCECASPER said: I checked with emagair back in December and it looks like it will be quite awhile. emag air.pdf HEY EAA here is a good STC program for you. Please!!!! 1 Quote Link to comment Share on other sites More sharing options...
Rustler Posted January 19, 2017 Report Share Posted January 19, 2017 Norm-- Sorry for the delay. The install went easily, but it IS tight in places. We really thought it through while installing, and it turned out very clean. I've had no problems with it. My engine temps are a little cooler, and I probably save in the neighborhood of 0.25-0.5 gph. I haven't flown near lightning. I live at 7100', so I don't see the performance enhancements that a normally aspirated engine sees at sea level, but I do experience smoother ignition and faster starts. 1 Quote Link to comment Share on other sites More sharing options...
kortopates Posted January 19, 2017 Report Share Posted January 19, 2017 (edited) 53 minutes ago, Rustler said: Norm-- Sorry for the delay. The install went easily, but it IS tight in places. We really thought it through while installing, and it turned out very clean. I've had no problems with it. My engine temps are a little cooler, and I probably save in the neighborhood of 0.25-0.5 gph. I haven't flown near lightning. I live at 7100', so I don't see the performance enhancements that a normally aspirated engine sees at sea level, but I do experience smoother ignition and faster starts. Curious if the electronic mag replaced a pressurized magneto (vs unpressurized) and to what altitude you have been able to observe their performance? Also what your original mag setup was, like Bendix or Slick and both impulse or something else? Edited January 19, 2017 by kortopates Quote Link to comment Share on other sites More sharing options...
Rustler Posted January 20, 2017 Report Share Posted January 20, 2017 Paul-- In April 2016, we removed a Bendix pressurized magneto and replaced it with the ElectroAir unit. That mag was sent for inspection, which revealed a cracked case; it was repaired and returned to service at annual in October. I have been to 17,500' with the electronic unit without problem. In fact, while up there, I shut down the Bendix to see what would happen: basically nothing. Quote Link to comment Share on other sites More sharing options...
