peevee Posted January 11, 2017 Report Share Posted January 11, 2017 Ours isn't functional. I'd like to check the various linkages, tubing etc. Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted January 11, 2017 Report Share Posted January 11, 2017 Ours isn't functional. I'd like to check the various linkages, tubing etc. There is this from the POH..I'm guessing you want more detail. 1 Quote Link to comment Share on other sites More sharing options...
mooniac15u Posted January 11, 2017 Report Share Posted January 11, 2017 Here are the diagrams from the J parts catalog. 1 Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted January 11, 2017 Report Share Posted January 11, 2017 Time to limber-up and dig behind the panel to check the air duct tubing. You likely have deteriorated ducts, or they're not attached somewhere. It is very simple, but difficult to access.Sent from my VS985 4G using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
peevee Posted January 11, 2017 Author Report Share Posted January 11, 2017 19 minutes ago, KSMooniac said: Time to limber-up and dig behind the panel to check the air duct tubing. You likely have deteriorated ducts, or they're not attached somewhere. It is very simple, but difficult to access. Sent from my VS985 4G using Tapatalk Yeah, sounds "fun" Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted January 11, 2017 Report Share Posted January 11, 2017 Do yourself a favor and take the front seats out - takes just a few minutes but saves a lot of frustration whenever you are digging around behind the panel. 2 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted January 11, 2017 Report Share Posted January 11, 2017 I have found if the ducts are not routed properly the yoke shafts can smash them and tear holes. Correctly routed depends on what you have installed. 1 Quote Link to comment Share on other sites More sharing options...
jlunseth Posted January 17, 2017 Report Share Posted January 17, 2017 If you have had some panel upgrades from the original equipment it may be that the outlet hoses were not reconnected, and it may be that there is not enough space back behind the electronics stacks to run and connect the hoses at all. Quote Link to comment Share on other sites More sharing options...
peevee Posted January 17, 2017 Author Report Share Posted January 17, 2017 does the K have an electric blower motor? Quote Link to comment Share on other sites More sharing options...
Yooper Rocketman Posted January 17, 2017 Report Share Posted January 17, 2017 Just now, peevee said: does the K have an electric blower motor? No. Just gets airflow from ram air effect. Quote Link to comment Share on other sites More sharing options...
peevee Posted January 17, 2017 Author Report Share Posted January 17, 2017 (edited) 11 minutes ago, Yooper Rocketman said: No. Just gets airflow from ram air effect. Thanks- the diagram confused me. (item 44) Edited January 17, 2017 by peevee Quote Link to comment Share on other sites More sharing options...
mooniac15u Posted January 17, 2017 Report Share Posted January 17, 2017 19 minutes ago, peevee said: does the K have an electric blower motor? Item 80 on the second page is an optional blower. I don't know if it was an option for the K model as well. Quote Link to comment Share on other sites More sharing options...
