Baker Avionics Posted December 4, 2018 Report Share Posted December 4, 2018 On 11/29/2018 at 8:43 PM, Bob - S50 said: We have a bid of $10,400 to remove the KFC200 and install dual G5's flush mounted in the panel. Waiting to see what the installation kit will cost for the GFC500 but planning on about $10,000 for autopilot with 4 servos plus installation kit plus installation. I can give you the retail for the units if you would like for the system with 4 servos. basically each servo is $1500.00, Controller is $2900, install kits are about 700 for each servo. Quote Link to comment Share on other sites More sharing options...
Bob - S50 Posted December 4, 2018 Report Share Posted December 4, 2018 1 hour ago, The Avionics Specialists said: I can give you the retail for the units if you would like for the system with 4 servos. basically each servo is $1500.00, Controller is $2900, install kits are about 700 for each servo. That sounds like about $12,800 for parts. $7000 (basic autopilot including two servos) + 2 x $1500 (trim and yaw servos) + 4 x $700 (4 install kits). Thanks for the info. Quote Link to comment Share on other sites More sharing options...
carqwik Posted December 4, 2018 Report Share Posted December 4, 2018 If you don't have a yaw damper in your plane...you can reduce that cost by $2200 (1 servo + 1 install kit). Quote Link to comment Share on other sites More sharing options...
Bob - S50 Posted December 4, 2018 Report Share Posted December 4, 2018 3 hours ago, carqwik said: If you don't have a yaw damper in your plane...you can reduce that cost by $2200 (1 servo + 1 install kit). True, but I'd like the yaw damper. It's only money right? Quote Link to comment Share on other sites More sharing options...
Jesse Saint Posted December 7, 2018 Report Share Posted December 7, 2018 In our shop that job would cost $6,500 for the dual G5’s installed plus about $1,750 to remove the vacuum system and KFC200. Note that your electric trim may no longer work if you remove the KFC200. Quote Link to comment Share on other sites More sharing options...
carusoam Posted December 7, 2018 Report Share Posted December 7, 2018 Welcome aboard Jesse. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Baker Avionics Posted December 8, 2018 Report Share Posted December 8, 2018 22 hours ago, Jesse Saint said: In our shop that job would cost $6,500 for the dual G5’s installed plus about $1,750 to remove the vacuum system and KFC200. Note that your electric trim may no longer work if you remove the KFC200. Welcome aboard Jesse! What all are you doing to remove the Vacuum System? Also, the electric trim should work with a "Pitch Trim" servo from the GFC500, correct? Quote Link to comment Share on other sites More sharing options...
Jesse Saint Posted December 8, 2018 Report Share Posted December 8, 2018 21 hours ago, The Avionics Specialists said: Welcome aboard Jesse! What all are you doing to remove the Vacuum System? Also, the electric trim should work with a "Pitch Trim" servo from the GFC500, correct? Remove vacuum pump and cap the hole. Remove regulator and cap the hole. Remove all vacuum instruments and lines. The electric trim from the GFC500, if offered, should work for pitch trim. Quote Link to comment Share on other sites More sharing options...
Bob R Posted May 12, 2019 Report Share Posted May 12, 2019 On 12/31/2016 at 10:39 PM, MB65E said: I'm all electric in my 65e, and compliant with the TCDS. I would NOT talk to the FSDO. It's legal with the paperwork on the table already. Also, I can't wait for my RC Allen gyro to go TU!! A G5 is on the short list of things I want to do in 2017. shoot me a PM if you need anything. -Matt Funny, I would not ask FSDO for the time of day. 1 Quote Link to comment Share on other sites More sharing options...
