Bkaufmann Posted December 30, 2016 Report Share Posted December 30, 2016 Curious if anyone on this forum has experience upgrading a C-model to an E motor (200hp IO-360-A1A). Preferably someone who has experience with the LASAR STC and would be willing to share a copy for information purposes. Looking for detailed information about the work required for the installation. Thanks in advance! Ben Kaufman N5693Q (1200 hrs in past 10 yrs) Quote Link to comment Share on other sites More sharing options...
bonal Posted December 30, 2016 Report Share Posted December 30, 2016 Welcome Kaufmann, I was going to recommend that LASAR has an STC for just such a thing but then you already know that. Quote Link to comment Share on other sites More sharing options...
TTaylor Posted December 30, 2016 Report Share Posted December 30, 2016 Bkaufmann, there are several threads on the subject. MS seach is not very good, better to use Google and just include Mooneyspace in the search. Quote Link to comment Share on other sites More sharing options...
Bkaufmann Posted December 31, 2016 Author Report Share Posted December 31, 2016 Thanks crew. I have access to a donor E model with a strong engine and an RV6 in need of a parallel valve, so this swap kills two birds with one stone. Just need to understand the extent of the work needed to make the conversion. LASAR estimates 80hrs of labor on their website but no details around how much of that would be avoided by using donor E components (airbox, baffles, etc) Jake35 here appears to have a copy of the STC and have sent him a PM. Anyone else out there? 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted December 31, 2016 Report Share Posted December 31, 2016 It takes a few things to align. Each of those things costs AMUs. It looks like you might have this covered. usually the cost of the conversion and STC outweighs the cost of swapping planes. Most people trade the C in to buy an E. this just becomes difficult when your C is finally the way you like it, and starting over doesn't sound very enticing. Check in with Lasar and see what it will take for you to make it happen. It is going to be a pile of parts to acquire and the labor to put it all together. The more of the right parts you have, the better off you will be. Two people working for a week doesn't sound like too much labor. see if that includes pulling the old engines off their current planes. There can be a lot of work involved in preparing the C that might not be obvious... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Guest Posted December 31, 2016 Report Share Posted December 31, 2016 Having a donor would be a big help. You'll need the fuel boost pump, fuel pressure gauge, baffles, engine controls etc. Your propeller will likely require adjustment to the fine pitch stops. On a Hartzell it can be done in the field, a McCauley needs to go to a prop shop. I would make sure that the engine mount has the gussets installed per the AD and SB if not already done. Clarence Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted December 31, 2016 Report Share Posted December 31, 2016 Call LASAR and talk to them. I forget the guys name, but we talked for about 20 minutes about everything involved... of course he talked me out of it in the process. Quote Link to comment Share on other sites More sharing options...
bonal Posted December 31, 2016 Report Share Posted December 31, 2016 4 hours ago, gsxrpilot said: Call LASAR and talk to them. I forget the guys name, but we talked for about 20 minutes about everything involved... of course he talked me out of it in the process. And apparently right into a 252 3 Quote Link to comment Share on other sites More sharing options...
rbridges Posted December 31, 2016 Report Share Posted December 31, 2016 1 hour ago, bonal said: And apparently right into a 252 that's what I was thinking 2 Quote Link to comment Share on other sites More sharing options...
carusoam Posted December 31, 2016 Report Share Posted December 31, 2016 Once you've gone Mooney... The only question is what will the next Mooney will be? 1) High performance fire breathing Mooney with all of the instruments... -or- 2) Dreamy retirement Mooney with all of the instruments! I'm waiting for George with guidance on how he is handling this question.... M20F, F18, M20S... what could possibly fit At the end of this series..? Thinking out loud, -a- Quote Link to comment Share on other sites More sharing options...
Guest Posted December 31, 2016 Report Share Posted December 31, 2016 1 hour ago, carusoam said: Once you've gone Mooney... The only question is what will the next Mooney will be? 1) High performance fire breathing Mooney with all of the instruments... -or- 2) Dreamy retirement Mooney with all of the instruments! I'm waiting for George with guidance on how he is handling this question.... M20F, F18, M20S... what could possibly fit At the end of this series..? Thinking out loud, -a- You know how I would answer that! Clarence Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted December 31, 2016 Report Share Posted December 31, 2016 5 hours ago, bonal said: And apparently right into a 252 Actually my wife was the reason for the 252. She decided that a Mooney isn't such a bad way to travel. Two weeks of travel by Mooney around the western US with visits to several Nat. Parks, with our dog, changed her mind on travel by Mooney. With funds available and now the Secretary of the Treasury on board, the C was sold and the 252 acquired. I showed her how the "Weekend Circle" would be larger with a 252. 5 Quote Link to comment Share on other sites More sharing options...
Jake35 Posted January 6, 2017 Report Share Posted January 6, 2017 Been there, done that with an IO-360 A3B6D then subsequently another change to an IO-360 A3B6 which wasn't quite as complicated but which came with it's own set of problems. I replied directly to Ben. Quote Link to comment Share on other sites More sharing options...
