Mooneymite Posted September 8, 2018 Report Share Posted September 8, 2018 This may be worth a look: AC No: 20-165B https://www.faa.gov/documentLibrary/media/Advisory_Circular/AC_20-165B.pdf Quote Link to comment Share on other sites More sharing options...
Oldguy Posted September 20, 2018 Report Share Posted September 20, 2018 7 minutes ago, Hyett6420 said: ADS-B and all that..... So the Brits have FINALLY decided that ADS-B is the thing of choice, god we don't 'alf take a long time over things sometimes. So I have a GTX330 which gives me ADS-B in I believe (I do not think so, but am often mistaken. See below.) according to the manual, but it is not hooked up to any screen so i cant see it (we will address that). However I'm having a fun time trying to understand how it all works and seeing as how you lot are all now experts i thought i would ask. So there is 1090 and 978 on the frequencies , if I'm correct and the 1090 does the high level traffic stuff and the 978 does the lower level traffic stuff. In the US, 1090 is required for trips into Class A space and, apparently, into other surrounding countries. So even though I do not plan on my J getting into Class A, I have a 1090 ES transponder. 978 UAT is TYPICALLY used by those planes under Class A and for weather transmission (FIS-B i believe). Some programs, like ForeFlight, will take ADS-B In, but without your plane squawking ADS-B Out, will not show all of the traffic around you. But you will need some type of -In receiver (Sentry, Stratus/Stratux, etc.) to receive the -In for TIS-B (traffic) and FIS-B. The Stratus 2S I have is a 1090 ES and 978 UAT receiver. My KT 74 transponder (1090 ES) is my ADS-B out. if i DONT have -out I'm assuming because my transponder is mode S that i can see everything that the local radar station sees as well and this is via 978? Mode S should give you TIS-A, which as you point out, makes you visible to TCAS. ADS-B Out on 1090 is referred to as Extended Squitter (ES) versus Squitter (your Mode S). 978 UAT is Universal Access Transceiver. Note we are not REQUIRED to have ADS-B yet, it would just be nice to activate what i already have on board. Regarding weather, this is transmitted via the ground stations on the 978 frequency and thus as i have -in i should be able to pick it up? FIS-B weather is transmitted on 978 UAT. The key to receiving it is to be in range of a coverage area for FIS-B service. -Out is not required to pick it up. As I have Mode S im already transmitting all my traffic data to anyone with TCAS anyway, so why would i need ads-b out? Easy answer is so you can see them. Unless you have a Skywatch, Lynx NGT9000+, or other active traffic system, an -Out transponder is needed to trigger your receipt of the TIS-B traffic. End of Brit questions, be gentle with me please. Please note all answers given above are pulled out of a brain with minimal coffee this morning, and as such are subject to significant error. 1 Quote Link to comment Share on other sites More sharing options...
PaulM Posted September 20, 2018 Report Share Posted September 20, 2018 Is your GTX330 a GTX330ES?. in the GTX line only the GTX345 is ADSB-out&IN... the GTX330ES and GTX335 are out only and need to be paired with your WAAS position source to be fully compliant with 2020 requirements. Garmin has had an upgrade plan for 1-2AMU to upgrade to the ES version. Any traffic in with your GTX330 will be TIS-A traffic only... which is a mode S service.. not related to ADSB. I will need to read exactly what ADSB in the UK is going to be... looks like some UAT (just for weather and aux services).. but mostly the rest of the world expects 1090ES for traffic only.. The USA did traffic in both 1090ES and UAT with ground repeating so that radar (mode c & mode s) are blended with ADSB (ES and UAT) and retransmitted by ground stations for traffic in an envelope around your plane. the ground can't know what your envelope is without ADSB-out..so you don't get a complete traffic picture on your IN unless you have OUT. If the UK ground stations are not retransmitting ground radar then it doesn't matter. If you want a specific history of UAT, why the US is using it for traffic and why the rest of the world isn't we can discuss at the Summit. So, the quick start is to get an ADSB-IN receiver (dual frequency).. that will give you the UAT weather... and you will see any 1090ES transponders. At this time I would go with a sentry http://flywithsentry.com Dual band, + CO sensor. but your choice of tablet mapping software dictates your portable unit.. Foreflight, garmin, skydemon etc. Then upgrade your GTX330 to the ES model, then other people can see you. If the UK is doing radar rebroadcast you will then also see what they see.. mode C and mode S targets around your current position as well as 1090ES transmitters in line of sight. 1 Quote Link to comment Share on other sites More sharing options...
Oldguy Posted September 21, 2018 Report Share Posted September 21, 2018 7 minutes ago, Hyett6420 said: Hi, thanks for the answers. My class a starts at 2500 so i fly in it regularly. So why do i need ads b out in ordee to see ALL the traffic, why wont it just show me all the ads-b traffic if i have -in. Whats the thing i am missing here in my brain. Here is a snippet from a web page better describing it (FAA/US version). Your implementation may differ: Unfortunately, it’s not that simple–you will only receive this TIS-B information if you are equipped with ADS-B Out. The FAA wants to encourage pilots to equip their airplane with ADS-B Out, so they’re requiring this equipment in order to receive traffic information. Their hope is that this incentive gets more airplanes flying with ADS-B Out, sooner. Many pilots think this is a bad idea, but regardless, it’s the way the system works right now. All is not lost, though. If you do not have ADS-B Out, but you are flying near another airplane that istransmitting ADS-B Out, you can be a parasite. That is, you can listen in on that airplane’s traffic message and display nearby airplanes on your iPad. That’s because each ADS-B Out airplane receives back an ADS-B In traffic package from the ground stations, and it is specifically tailored to their location. In particular, that ADS-B Out airplane will see all traffic within a 15 mile radius and +/-3500 feet: From https://ipadpilotnews.com/2012/08/understanding-ads-b-traffic/ 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted September 21, 2018 Author Report Share Posted September 21, 2018 3 minutes ago, Hyett6420 said: Ooh thats cool. Thanks for the info. I spend quite a lot of time near commerical stuff as it flies quite low around where i am so i should be able to piggy back off them, great news. Love it.. i love the FAAs approach very government logical. They you can fly around like the big planes with tons of targets to look at! 1 Quote Link to comment Share on other sites More sharing options...
PaulM Posted September 21, 2018 Report Share Posted September 21, 2018 4 minutes ago, Hyett6420 said: Ooh thats cool. Thanks for the info. I spend quite a lot of time near commerical stuff as it flies quite low around where i am so i should be able to piggy back off them, great news. Love it.. i love the FAAs approach very government logical. All of the TIS-B data and piggy backing on other aircraft's ADSB systems is FAA specific.. I have seen no information that the CAA will be sending TIS-B. If you have a link to any memo's more recent than Aug 2017 let us know. I read CAP1391.. not much in there. If you get your ADSB-IN on your EFB, you will see all commercial flights since they will be required to match the 2020 mandate. Also anyone else that has upgraded to the 1090ES. You also get the weather that uAvionics is testing in the UAT spectrum. The CAA is not requiring DO 260B for EC devices, so you can start with the GTX330ES and your current GPS source.. Then everyone else with a EFB and ADSB-in can see you. WAAS is needed for DO 260B, which is the US 2020 spec. DO260B is also required by the FAA to trigger the TIS-B and TIS-R envelopes (which doesn't apply to the UK) 1 Quote Link to comment Share on other sites More sharing options...
PaulM Posted September 21, 2018 Report Share Posted September 21, 2018 Get the IN for the weather... anything else is a bonus.. In flight nexrad and metars is a game changer. We have had XM sat weather for years, and the ADSB nexrad isn't really as good, but better than nothing. You will have to evaluate uAvionics data yourself. ES upgrade + some wiring from the GPS will make you show up on other's screens. https://buy.garmin.com/en-US/US/p/596335 Obviously a 345 will do it all.. https://buy.garmin.com/en-US/US/p/140949 the LYNX 9000 has a screen, does it all and can include TCAS which will give you all mode C traffic right away. for $$$ of course. https://www.l-3lynx.com Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted September 21, 2018 Report Share Posted September 21, 2018 It all depends on how GB would implement ADS-B. The FAA has decided that TIS-B (the traffic service) will be limited to the areas around those with ADS-B Out--essentially, they're nerfing the traffic information broadcast so only people with ADS-B out will get the complete traffic picture. Check whether GB will be implementing TIS-B or not, and whether they will be limiting this info or not. FIS-B (the weather service) in the US is limited to the UAT frequency (978Mhz). There is no weather broadcast on 1090Mhz. I assume this is to preserve the bandwidth in 1090Mhz. If your CAA decides not to nerf the TIS-B service, in theory you'd get no practical benefit from installing an ADS-B Out transponder--you'd be able to pick up all the traffic and weather broadcast off the UAT frequency, and that can be had with cheap portable receivers. whether it will be required in any particular airspace I imagine is yet to be decided. Quote Link to comment Share on other sites More sharing options...
Yetti Posted October 7, 2018 Report Share Posted October 7, 2018 Rumors are that the FAA may have another $500 bonus program Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted October 9, 2018 Report Share Posted October 9, 2018 On 10/7/2018 at 12:44 PM, Yetti said: Rumors are that the FAA may have another $500 bonus program I doubt that, since now what's going to determine the number of new installs in the next 448* days is going to be shop space, not rebates. * https://www.tickcounter.com/countdown/8424/ads-b-deadline Quote Link to comment Share on other sites More sharing options...
Yetti Posted October 10, 2018 Report Share Posted October 10, 2018 https://generalaviationnews.com/2018/10/08/lsa-weight-to-increase-to-3600-pounds-another-ads-b-rebate-in-the-works/ Quote Link to comment Share on other sites More sharing options...
wings_level Posted October 20, 2018 Report Share Posted October 20, 2018 (edited) So looks like the rebate is back. Here is what I am struggling with for my 66 C Model: garmin 345: provides gps and allows ads-b to be Bluetooth directly to foreflight on iPad. No additional equipment needed. So don’t have to worry about charging and managing external devices. However, should the unit fail or an electrical failure, I lose everything, gps for foreflight, weather, traffic in. Electrical failure I even lose panel gps. So this makes a single point of failure. garmin 335 + stratus: provides gps and allows ads-b to be Bluetooth directly to foreflight on iPad using only stratus. Would have to purchase another piece of equipment, the stratus. Now I have to worry about charging and managing external devices. However, should the unit fail or an electrical failure, I don’t lose everything, gps for foreflight, weather, traffic in still available with Stratus. Electrical failure I lose panel gps, but stratus still works. So this eliminates the single point of failure. Any other thoughts out there? Decisions, decisions! Edited October 20, 2018 by wings_level Quote Link to comment Share on other sites More sharing options...
jaylw314 Posted October 20, 2018 Report Share Posted October 20, 2018 1 hour ago, wings_level said: So looks like the rebate is back. Here is what I am struggling with for my 66 C Model: garmin 345: provides gps and allows ads-b to be Bluetooth directly to foreflight on iPad. No additional equipment needed. So don’t have to worry about charging and managing external devices. However, should the unit fail or an electrical failure, I lose everything, gps for foreflight, weather, traffic in. Electrical failure I even lose panel gps. So this makes a single point of failure. garmin 335 + stratus: provides gps and allows ads-b to be Bluetooth directly to foreflight on iPad using only stratus. Would have to purchase another piece of equipment, the stratus. Now I have to worry about charging and managing external devices. However, should the unit fail or an electrical failure, I don’t lose everything, gps for foreflight, weather, traffic in still available with Stratus. Electrical failure I lose panel gps, but stratus still works. So this eliminates the single point of failure. Any other thoughts out there? Decisions, decisions! I'm motivated less by the single-point-of-failure issue than the I'm-too-cheap-of-a-bastard-to-spend-money-on-something-I-can-get-for-$200-on-Amazon issue Just get ADS-B Out and you will get everything you need with Stratux (not Stratus). Same functionality, CB approved. Heck, they say they have AHRS for a emergency ADI on Foreflight up and running (I don't use FF so I can't confirm that) Quote Link to comment Share on other sites More sharing options...
Cruiser Posted October 20, 2018 Report Share Posted October 20, 2018 you should add the GDL82 to your list of equipment. This is becoming a popular solution. Curious why a single point failure is a focus since you are flying now without any of these? Quote Link to comment Share on other sites More sharing options...
wings_level Posted October 20, 2018 Report Share Posted October 20, 2018 Well right now I am flying with Foreflight and the SXAR1 so I have xm weather and gps. But if I am gonna upgrade to include ADS-B, redundancy is something I am considering. Would like to ditch xm on Foreflight and just use ads-b for that either with the 345 or stratus. I agree the GDL82 is another viable option. But I believe the install for that is fairly higher than the 335 or 345. Making it a wash between those. At least that is what an avionics shop said. Quote Link to comment Share on other sites More sharing options...
Marauder Posted October 21, 2018 Author Report Share Posted October 21, 2018 Well right now I am flying with Foreflight and the SXAR1 so I have xm weather and gps. But if I am gonna upgrade to include ADS-B, redundancy is something I am considering. Would like to ditch xm on Foreflight and just use ads-b for that either with the 345 or stratus. I agree the GDL82 is another viable option. But I believe the install for that is fairly higher than the 335 or 345. Making it a wash between those. At least that is what an avionics shop said. I have a Lynx 9000+ that handles all of the ADS-B stuff with my Aspen and with its own display. I never sold my GDL-39 and carry it along and use it for a backup. Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
MARZ Posted October 21, 2018 Report Share Posted October 21, 2018 On 10/7/2018 at 12:44 PM, Yetti said: Rumors are that the FAA may have another $500 bonus program true statement I just registered - and if I didn't have this thing called a job I'd be doing my flight this week to get my rebate Quote Link to comment Share on other sites More sharing options...
MARZ Posted October 21, 2018 Report Share Posted October 21, 2018 On 10/20/2018 at 2:32 PM, Cruiser said: you should add the GDL82 to your list of equipment. This is becoming a popular solution. This was my path - no need to upgrade any transponder the unit is put in between the current transponder and the L band antenna - it has an on board waas, comes with the gps antenna. Mine got mounted in the rear battery compartment. The time consumption was running the 4 conductor to the panel to pickup power, ground and wire in the fault light and anonymous switch. I can't believe that would cost more than a transponder swap and rewire. Quote Link to comment Share on other sites More sharing options...
Baker Avionics Posted October 22, 2018 Report Share Posted October 22, 2018 (edited) 22 hours ago, Mike Ropers said: This was my path - no need to upgrade any transponder the unit is put in between the current transponder and the L band antenna - it has an on board waas, comes with the gps antenna. Mine got mounted in the rear battery compartment. The time consumption was running the 4 conductor to the panel to pickup power, ground and wire in the fault light and anonymous switch. I can't believe that would cost more than a transponder swap and rewire. That is correct! The GDL 82 "piggy backs" the existing transponder signal and lets the ADS-B out "ride" on that RF being generated from the existing transponder. It is a real simple install and very very cost effective for ADS-B out ONLY. Generally cost for parts and labor for the GDL is well under 4000.00. Edited October 22, 2018 by The Avionics Specialists Added a thought 1 Quote Link to comment Share on other sites More sharing options...
Mooneymite Posted October 22, 2018 Report Share Posted October 22, 2018 I think that's what uAvionics patent infringement is all about, isn't it? Piggybacking on the transponder. Quote Link to comment Share on other sites More sharing options...
Baker Avionics Posted October 22, 2018 Report Share Posted October 22, 2018 1 minute ago, Mooneymite said: I think that's what uAvionics patent infringement is all about, isn't it? Piggybacking on the transponder. Correct Quote Link to comment Share on other sites More sharing options...
Baker Avionics Posted November 5, 2018 Report Share Posted November 5, 2018 If anyone would like any info as it pertains to install time, tech specs or any other question regarding the ADS-B Mandate, please feel free to contact me at any time. I am here for all of us as we are in this thing together. I would love to educate as many people as possible and possibly give you more insight as to what is the best solution for your situation and budget. Just let me know, I want to help. Here in the Northern California area, I have really helped folks out getting them the info and education they were needing to make sound decisions for their particular situation. Contact info below! 3 Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted November 13, 2018 Report Share Posted November 13, 2018 ADS-B EQUIPPAGE As of the third quarter of 2018 the FAA estimates “that 28 to 45 percent of all GA aircraft are equipped, and 42 to 53 percent of US air carriers are equipped.” About 6,500 of the 55,000 installations “fail to meet 14 CFR 91.277 equipment performance requirements.” Source Avionics News Oct 2018 page 15 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted November 13, 2018 Author Report Share Posted November 13, 2018 ADS-B EQUIPPAGE As of the third quarter of 2018 the FAA estimates “that 28 to 45 percent of all GA aircraft are equipped, and 42 to 53 percent of US air carriers are equipped.” About 6,500 of the 55,000 installations “fail to meet 14 CFR 91.277 equipment performance requirements.” Source Avionics News Oct 2018 page 15 Time to set up that “ADS-B R US” shop Jerry. We could make a killing and I could retire early. Sent from my iPad using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted November 13, 2018 Report Share Posted November 13, 2018 I find it “interesting” that over 10% of the installations are incorrect. It is not that hard to hook up a box and configure it. Apparently it is hard for some minority of installers. As my local avionics shop manager said, “even the bad shops are busy now.” Next fall isn’t going to be pretty on the ADS-B scene. After all, to be compliant as of 1/1/2020 you not only must have equipment installed, it has to work properly. Quote Link to comment Share on other sites More sharing options...
