Hedge Posted November 23, 2016 Report Posted November 23, 2016 My engine has 2033 hours with great compressions (all in the mid 70s). The problem is it has a lot of small oil leaks and a possible crack in the block between #2 and #4. They have already taken off the exhaust to inspect the engine, but to make sure it is actually cracked they will have to reinstall the exhaust and run the engine to reinspect. I am pretty sure, I am resigned to just installing a factory engine. Any thoughts would be appreciated. Ok - with my new exhaust, I am thinking about the powerflow exhaust. What is everyone's experience. My A&P said that if I install it, it will have to be taken apart every year to inspect. So my question is does everyone else do this and if you do, does the trouble worth the gain in speed? What else do you guys recommend while I am putting in a new engine - It has new teflon hoses (two year old), new starter (two years old), new alternator (one year old). I don't have any speed mods, so the windshield, cowling, etc are all open game. I would like to do this right and not have regrets. Mark Quote
RangerJim Posted November 24, 2016 Report Posted November 24, 2016 Many case cracks can be repaired saving you funds for other improvements. I have no experience with the Power Flow exhaust but seem to recall that the manufacturer recommends lubricating the slip joints annually. No doubt there is a good reason. If your mags need a 500 hour IRAN and your prop could benefit from a reseal then this would be the time. Likewise the prop governor. Then see where you stand. The airframe goodies can wait till all your planes critical systems are in shape. From a former C owner with some sellers remorse. 2 Quote
Hedge Posted November 24, 2016 Author Report Posted November 24, 2016 (edited) But putting $6K into an engine with 2033 hours would be saving money in the long run? I put 150-200 hours on the engine per year. Edited November 26, 2016 by Hedge Quote
aaronk25 Posted November 24, 2016 Report Posted November 24, 2016 Search powerflow there has been lots of recent discussions Sent from my iPhone using Tapatalk 1 Quote
pirate Posted November 24, 2016 Report Posted November 24, 2016 I believe ALL exhaust systems should disassembled and inspected at every annual, anyway my Powerflow takes no more than a half hour to unbolt and inspect. Never a problem yet. 1 Quote
Hedge Posted November 24, 2016 Author Report Posted November 24, 2016 2 minutes ago, Pirate said: I believe ALL exhaust systems should disassembled and inspected at every annual, anyway my Powerflow takes no more than a half hour to unbolt and inspect. Never a problem yet. How much speed does it get you? Quote
pirate Posted November 24, 2016 Report Posted November 24, 2016 I did pick up 4-5 knots in cruise but I also did the air filter conversion along with it. Nothing scientific to prove the speed gain but after a few thousand hours in the same plane you get to know her pretty well. The main reasons I converted to Powerflow was actually not for the speed but the increased climb performance and dramatically reducing the possibility of carbon monoxide poisoning. Quote
carusoam Posted November 24, 2016 Report Posted November 24, 2016 You are in a good spot. You know the plane fits your mission... Plan for it to last the Marauder millennium... (approximately 25 years of ownership) Upgrade with the top quality method that will last as long as you intend to own her. I went factory reman. It is one part convenience, and the other part resale value... (in the event I had to sell) an OH of your existing engine might take a step to send the block out for welding.... it probably doesn't make a lot of sense testing it for cracks, then sending it out... How many OHs has the engine seen already? Best regards, -a- Quote
Bob_Belville Posted November 24, 2016 Report Posted November 24, 2016 I've had a PFS on my '66E for over 4 years. I do owner assist annuals in my hangar and the PFS is disassembled enough to apply anti-seize to the slip joints. I doubt that it takes any more time than it takes for proper inspection and servicing of a conventional exhaust. I am a fan of the PFS, it might provide better performance - I think it does, it sounds better, and I believe it is stouter and will outlast original equipment. 1 Quote
N9201A Posted November 24, 2016 Report Posted November 24, 2016 +1 on PF. Agree with all written. Quote
Two Oh One Posted November 25, 2016 Report Posted November 25, 2016 On November 23, 2016 at 3:44 PM, Hedge said: What else do you guys recommend while I am putting in a new engine Usually a good time for the engine mount to come out for inspection/overhaul. There are differing opinions on powder coating vs painting the mount. Without igniting that battle, I took my IA's advice and powder coated mine. I chose bright white to more easily show damage and leaks, plus I think it looks sharp. New engine shock mounts when it goes back in... 1 Quote
rbridges Posted November 25, 2016 Report Posted November 25, 2016 Powerflow looks good sticking out of the cowl! Quote
Yetti Posted November 25, 2016 Report Posted November 25, 2016 Had a mechanic install one on his E. Did not increase anything and sold it. Rebuild the mags and prop governor. new vacuum pump Quote
Hedge Posted November 26, 2016 Author Report Posted November 26, 2016 On 11/23/2016 at 10:12 PM, carusoam said: You are in a good spot. You know the plane fits your mission... Plan for it to last the Marauder millennium... (approximately 25 years of ownership) Upgrade with the top quality method that will last as long as you intend to own her. I went factory reman. It is one part convenience, and the other part resale value... (in the event I had to sell) an OH of your existing engine might take a step to send the block out for welding.... it probably doesn't make a lot of sense testing it for cracks, then sending it out... How many OHs has the engine seen already? Best regards, -a- It has seen two. I am pretty sure I am going with the reman. What else would you guys do at the same time. Filter, Powerflow, windscreen, etc...? Quote
Hedge Posted November 26, 2016 Author Report Posted November 26, 2016 On 11/25/2016 at 9:02 AM, Yetti said: Had a mechanic install one on his E. Did not increase anything and sold it. Rebuild the mags and prop governor. new vacuum pump I thought new mags came with the new engine. OK on the prop governor and vacuum pump. Quote
Hedge Posted November 26, 2016 Author Report Posted November 26, 2016 Anyone have any idea of the gross cost for the following. New Engine - Lycoming built - 31K Install - Powerflow with Install - New Mags (one is only 3 years old and the other is only 1 year old) if they don't come with the new engine- Engine Mount Overhall - New Vacuum Pump and Install Rebuild the Prop Governor (but wouldn't this be just as easy in the future?) - Quote
amillet Posted November 26, 2016 Report Posted November 26, 2016 I posted my costs on 12/3/15 in "time for new engine" topic" Quote
MyNameIsNobody Posted November 26, 2016 Report Posted November 26, 2016 On 11/23/2016 at 9:14 PM, Bob_Belville said: I've had a PFS on my '66E for over 4 years. I do owner assist annuals in my hangar and the PFS is disassembled enough to apply anti-seize to the slip joints. I doubt that it takes any more time than it takes for proper inspection and servicing of a conventional exhaust. I am a fan of the PFS, it might provide better performance - I think it does, it sounds better, and I believe it is stouter and will outlast original equipment. Man, for that amount of money you better KNOW... Quote
Andy95W Posted November 26, 2016 Report Posted November 26, 2016 2 hours ago, Hedge said: It has seen two. I am pretty sure I am going with the reman. What else would you guys do at the same time. Filter, Powerflow, windscreen, etc...? I would go reputable field overhaul and with the money saved: -201 windshield -LASAR lower cowl closure -flap gap seals 2 Quote
Bob_Belville Posted November 26, 2016 Report Posted November 26, 2016 On 11/23/2016 at 10:14 PM, Bob_Belville said: I've had a PFS on my '66E for over 4 years. I do owner assist annuals in my hangar and the PFS is disassembled enough to apply anti-seize to the slip joints. I doubt that it takes any more time than it takes for proper inspection and servicing of a conventional exhaust. I am a fan of the PFS, it might provide better performance - I think it does, it sounds better, and I believe it is stouter and will outlast original equipment. 3 hours ago, MyNameIsNobody said: Man, for that amount of money you better KNOW... Know what, Man? I reported that I have had a PFS for several years and like it for several subjective reasons satisfactory to me and my wallet. Not sure that you have standing in this exchange. 2 Quote
Bob_Belville Posted November 26, 2016 Report Posted November 26, 2016 20 hours ago, daver328 said: We installed PF with Challenger Intake. Big improvement on our C. They have specials ... which served as an incentive for me to drop the $$ when we caught a reduced price. I'm very satisfied... word is, the more inefficient the stock exhaust the more improvement noticed, thus a very noticeable improvement on our 65C. I grounded my plane when about 3 months into ownership I returned from KPDK missing a big chunk of the tailpipe and further inspection indicated the guts of the muffler was shot. While I could not wait for a deal, I was able to justify that I was going to be spending over half the cost of the PFS to get what I had rebuilt. I was not tough to go with both newer technology and all new metal. (I too took advantage of a deal on the Challenger air filter conversion from PFS.) Quote
aaronk25 Posted November 27, 2016 Report Posted November 27, 2016 Man, for that amount of money you better KNOW... Hey and you were wondering on another thread how we were laying down such impressive cruise speeds.......well........Sent from my iPhone using Tapatalk Quote
MyNameIsNobody Posted November 27, 2016 Report Posted November 27, 2016 1 hour ago, aaronk25 said: Hey and you were wondering on another thread how we were laying down such impressive cruise speeds.......well........ Sent from my iPhone using Tapatalk Chill Honeybunny...Chill. I wasn't wondering at all. I was questioning... Bob- to quote you "It might provide better performance". Thus my reply... Chilax...Like anybody needs to justify anything to me ever... Quote
aaronk25 Posted November 27, 2016 Report Posted November 27, 2016 So you wanna go to kLNR for breakfast tomorrow is that what your saying?Sent from my iPhone using Tapatalk Quote
MyNameIsNobody Posted November 27, 2016 Report Posted November 27, 2016 My three blade prop looks better. There, something to ridicule me about and feel all warm and fuzzy inside with your super duper fast two blades... Quote
