Steve65E-NC Posted September 28, 2016 Report Share Posted September 28, 2016 A number of years ago I purchased front and rear seats with good upholstery from a later J at a salvage yard. The front seats went right into my 65E with a log entry. I retrieved every bracket and bit of the fold down rear seats from the J and have its serial number and a parts blow up. Has anyone else done this? If so I would like to see a copy of the associated 337, if that was needed. Also, a report on any problems. I have made a trial fit and see no obvious problems. I am starting to weigh stuff to determine effect on weight and balance. These are the rear seats where the back upholstery assembly slips right off a frame and leads to a perfectly flat floor behind the pilot seats. The backs are adjustable in angle and I have all that hardware. Since the base cushions and seat backs can stay home, I am thinking that I need two weight and balance sheets. The upholstery on my old seats is worn out and this seems like a good and useful way to refresh the rear upholstery to match the front. Quote Link to comment Share on other sites More sharing options...
smwash02 Posted September 28, 2016 Report Share Posted September 28, 2016 It's considered a minor alteration and doesn't require one. Click Here Quote Link to comment Share on other sites More sharing options...
KSMooniac Posted September 28, 2016 Report Share Posted September 28, 2016 It will be up to your IA to determine if it is a minor or major mod, and thus the amount of documentation required. Since you're transplanting into a non-J model, I could see requiring a 337, but on the other hand, since they're all Mooney factory parts and the installation/interface is identical, it could easily be argued that no further approvals are needed since they were certified in the J and thus a logbook entry is sufficient.I do agree that developing two W&B documents for each config is the proper way to go after you sort out major/minor. Or at least note the weight and station for the rear seats so they can be added or subtracted as appropriate.Sent from my VS985 4G using Tapatalk Quote Link to comment Share on other sites More sharing options...
