Tony Armour Posted November 11, 2016 Report Share Posted November 11, 2016 On September 18, 2016 at 10:31 PM, NotarPilot said: Please tell us what happened. G5 experimental should be here next week. Regarding my ah "incident" probably for another thread 1 Quote Link to comment Share on other sites More sharing options...
M016576 Posted November 11, 2016 Report Share Posted November 11, 2016 11 hours ago, donkaye said: It can't. It cannot drive any autopilot. That's too bad... seems like that would be a simple software addition- and would be a very desirable feature. Quote Link to comment Share on other sites More sharing options...
AaronDC8402 Posted November 11, 2016 Report Share Posted November 11, 2016 I checked out a friend's airplane today with a recently installed G5. When you push the cursor button and scroll all the way to the right, there is a HSI button. Selecting that brings up an HSI. I know that Garmin has not (and reportedly plans not to) certified the G5 to be used as a HSI. For those that have the G5 installed, do you have this page also? I would guess that it's "not for navigation" if it really is in there on the STC'd G5. Quote Link to comment Share on other sites More sharing options...
flyboy0681 Posted November 11, 2016 Report Share Posted November 11, 2016 Just now, AaronDC8402 said: I checked out a friend's airplane today with a recently installed G5. When you push the cursor button and scroll all the way to the right, there is a HSI button. Selecting that brings up an HSI. I know that Garmin has not (and reportedly plans not to) certified the G5 to be used as a HSI. For those that have the G5 installed, do you have this page also? I would guess that it's "not for navigation" if it really is in there on the STC'd G5. From what I have read on Aviation Consumer, the HSI can be used if it's wired in. Quote Link to comment Share on other sites More sharing options...
drclive Posted November 12, 2016 Report Share Posted November 12, 2016 I called Garmin support and they confirmed that NO, the G5 can't drive my autopilot and that I have to keep my old attitude indicator in order to continue function properly. I think the G5 can only be wired to the Garmin autopilot. best, Clive Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted November 12, 2016 Report Share Posted November 12, 2016 I thought back when the STC was announced that this was discussed. The STC for certified aircraft doesn't include the autopilot functionality. If you install the G5 in an experimental, it will drive an autopilot just fine. Am I misunderstanding this? Quote Link to comment Share on other sites More sharing options...
jetdriven Posted November 12, 2016 Report Share Posted November 12, 2016 The STC'd version of the G5 is a different part number, and has no HSI, autopilot, or nav functions. It is simply an attitude indicator wth airspeed, altitude and altitude reminder bug. That's it. There's no installing the experimental version in the pilot station of the panel either. The STC is keyed to the part number of the unit. 1 Quote Link to comment Share on other sites More sharing options...
bradp Posted November 12, 2016 Report Share Posted November 12, 2016 Here's another question - anyone installing the experimental version of the G5 in a Mooney? From what I know it can be done and tied into the primary pitot static but cannot replace any of the primary instruments (i.e. Six pack must remain). I'd be interested in a G5 certified top center and an experimental G5 in my current CDI#1 slot right of the altimeter. Move nav#1 CDI down one and push the never used nav #2 to the right of the panel. Wouldn't allow for removal of the vacuum instruments however. At that point an Aspen would be might appealing and probably less complex. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
gsxrpilot Posted November 13, 2016 Report Share Posted November 13, 2016 I'm thinking of an Aspen with the STC'd G5 as a backup electric AI allowing me to remove the vacuum system. 1 Quote Link to comment Share on other sites More sharing options...
GeorgePerry Posted November 13, 2016 Report Share Posted November 13, 2016 Just picked up my plane from Lancaster Avionics post G5 install. In two words LOVE IT!!! Before After Install was pretty straight forward, although they did have to expand the Vacuum AI hole so the raised bezel of the G5 would fit under the Mortiz gauge pack. What inpressed me was the level of precision that the G5 gives compared to a standard vacuum AI. You can actually see the pitch changes on the G5 vice the vacuum AI where a very small amount of movement on the artificial horizon resulted in significant VSI change. The G5 allows you to see very small pitch changes much more clearly. Also it auto levels in flight so if you slow down or speed up, it automatically readjusts the pitch so level flight = level indication. Nice! The best part of the mod is that The vacuum system no longer powers anything. So the dreaded vacuum pump failure is no longer an issue. The G5's battery back up is good for up to 4 HOURS!. Overall cost for the G5 with options was $2400, and install was about $3000. So for just over $5k I've been able to eliminate my vacuum system, and get an integrated EFIS. 4 Quote Link to comment Share on other sites More sharing options...
carusoam Posted November 13, 2016 Report Share Posted November 13, 2016 The G5 display shows a small descent attitude with a matching request for left rudder input from the ball... VSI says-100fpm... does the G5 have a vertical speed display? Nice video, George! Thanks for sharing. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
GeorgePerry Posted November 13, 2016 Report Share Posted November 13, 2016 It does have VSI, as magenta scale next to the altitude tape. I'll try to get a more detailed video up in the next day or so. 1 Quote Link to comment Share on other sites More sharing options...
APTUS Pilot Posted November 13, 2016 Report Share Posted November 13, 2016 On 11/11/2016 at 5:46 PM, AaronDC8402 said: I checked out a friend's airplane today with a recently installed G5. When you push the cursor button and scroll all the way to the right, there is a HSI button. Selecting that brings up an HSI. I know that Garmin has not (and reportedly plans not to) certified the G5 to be used as a HSI. For those that have the G5 installed, do you have this page also? I would guess that it's "not for navigation" if it really is in there on the STC'd G5. So, George- Can you shed any light on this? We are trying to determine if the HSI functionality is available at all in the STC'd version. Thanks, Ben Quote Link to comment Share on other sites More sharing options...
donkaye Posted November 13, 2016 Report Share Posted November 13, 2016 1 hour ago, APTUS Pilot said: So, George- Can you shed any light on this? We are trying to determine if the HSI functionality is available at all in the STC'd version. Thanks, Ben From the Beechtalk list and other sources the answer is No. 1 Quote Link to comment Share on other sites More sharing options...
NotarPilot Posted November 14, 2016 Report Share Posted November 14, 2016 Holy crap! $3000 for installation? I was under the impression it would only take a few hours to install. I was thinking maybe 5 or 6 hours tops. I hope that $3000 was due to the movement of the Moritz gauges. I have a G5 ready to go in a box just need to schedule a day to get it installed. 1 Quote Link to comment Share on other sites More sharing options...
PMcClure Posted November 14, 2016 Report Share Posted November 14, 2016 10 hours ago, GeorgePerry said: Just picked up my plane from Lancaster Avionics post G5 install. In two words LOVE IT!!! Before After Install was pretty straight forward, although they did have to expand the Vacuum AI hole so the raised bezel of the G5 would fit under the Mortiz gauge pack. What inpressed me was the level of precision that the G5 gives compared to a standard vacuum AI. You can actually see the pitch changes on the G5 vice the vacuum AI where a very small amount of movement on the artificial horizon resulted in significant VSI change. The G5 allows you to see very small pitch changes much more clearly. Also it auto levels in flight so if you slow down or speed up, it automatically readjusts the pitch so level flight = level indication. Nice! The best part of the mod is that The vacuum system no longer powers anything. So the dreaded vacuum pump failure is no longer an issue. The G5's battery back up is good for up to 4 HOURS!. Overall cost for the G5 with options was $2400, and install was about $3000. So for just over $5k I've been able to eliminate my vacuum system, and get an integrated EFIS. So what is driving your auto pilot? 1 Quote Link to comment Share on other sites More sharing options...
OR75 Posted November 14, 2016 Report Share Posted November 14, 2016 2 hours ago, NotarPilot said: Holy crap! $3000 for installation? I was under the impression it would only take a few hours to install. I was thinking maybe 5 or 6 hours tops. I hope that $3000 was due to the movement of the Moritz gauges. I have a G5 ready to go in a box just need to schedule a day to get it installed. Was wondering the same thing . Quote Link to comment Share on other sites More sharing options...
GeorgePerry Posted November 14, 2016 Report Share Posted November 14, 2016 10 hours ago, PMcClure said: So what is driving your auto pilot? STEC 30 that runs off the standby AI Quote Link to comment Share on other sites More sharing options...
GeorgePerry Posted November 14, 2016 Report Share Posted November 14, 2016 7 hours ago, OR75 said: Was wondering the same thing . It was alot of custom fitting b/c of the clearance issues. Also I had a stand alone WAAS GPS antenna installed to support the G5 since all of my ports in the GNS430 were full. So my install wasn't typical Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted November 14, 2016 Report Share Posted November 14, 2016 33 minutes ago, GeorgePerry said: STEC 30 that runs off the standby AI I thought the STEC 30 ran off of the turn coordinator. http://genesys-aerosystems.com/sites/default/files/files/GenesysAerosystems_System20-30_DataSheet.pdf 1 Quote Link to comment Share on other sites More sharing options...
OR75 Posted November 14, 2016 Report Share Posted November 14, 2016 2 hours ago, GeorgePerry said: It was alot of custom fitting b/c of the clearance issues. Also I had a stand alone WAAS GPS antenna installed to support the G5 since all of my ports in the GNS430 were full. So my install wasn't typical The GNS has 4 RS-232 out connections ... Curious as to where they are going Quote Link to comment Share on other sites More sharing options...
1964-M20E Posted November 14, 2016 Report Share Posted November 14, 2016 On 11/12/2016 at 8:59 AM, jetdriven said: The STC'd version of the G5 is a different part number, and has no HSI, autopilot, or nav functions. It is simply an attitude indicator wth airspeed, altitude and altitude reminder bug. That's it. There's no installing the experimental version in the pilot station of the panel either. The STC is keyed to the part number of the unit. Typical STC cert process with the FAA. We pay more and get less. Quote Link to comment Share on other sites More sharing options...
NotarPilot Posted November 14, 2016 Report Share Posted November 14, 2016 57 minutes ago, 1964-M20E said: Typical STC cert process with the FAA. We pay more and get less. Agreed but I'll take something over nothing. 1 Quote Link to comment Share on other sites More sharing options...
Marauder Posted November 14, 2016 Report Share Posted November 14, 2016 I thought the STEC 30 ran off of the turn coordinator.http://genesys-aerosystems.com/sites/default/files/files/GenesysAerosystems_System20-30_DataSheet.pdf Your right. It does run off of the turn coordinator.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Marauder Posted November 14, 2016 Report Share Posted November 14, 2016 Holy crap! $3000 for installation? I was under the impression it would only take a few hours to install. I was thinking maybe 5 or 6 hours tops. I hope that $3000 was due to the movement of the Moritz gauges. I have a G5 ready to go in a box just need to schedule a day to get it installed. He went to a shop that is not known for economical pricing. I will be getting a few quotes in the next couple of weeks. Other than the pitot static and electrical connections, he may have been charged for a IFR cert on top of it.Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
