Godfather Posted August 6, 2016 Report Share Posted August 6, 2016 Looking to replace all the hoses on the ovation. The vent hoses that run close to the exhaust are insulated and I'm having a hard time locating a good replacement. I need 2.5 and 3 inch hoses. The hoses look like a scat hose coated in fabric. Thanks for the help! Quote Link to comment Share on other sites More sharing options...
Yetti Posted August 7, 2016 Report Share Posted August 7, 2016 CAT Ducting? http://www.aircraftspruce.com/catalog/appages/cat.php 1 Quote Link to comment Share on other sites More sharing options...
Godfather Posted August 8, 2016 Author Report Share Posted August 8, 2016 Thanks for the link. The hose I have is thicker with a tan fabric cover bonded onto scat tubing. I guess the question I should be asking is what hose does the current Ovation have on the intake and heater air in/out hose? Quote Link to comment Share on other sites More sharing options...
hypertech Posted July 1, 2018 Report Share Posted July 1, 2018 Old post but same question. I’m looking to replace these hoses when the engine comes back from overhaul and I’m trying to figure out what they are. Anyone know what the ones with the covering on them are? Is this a type of sceet ducting? Or something special that needs to come from the factory? Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 1, 2018 Report Share Posted July 1, 2018 Sceet, scat, and other tubing... Depending on the details you are looking for... Aircraft Spruce has a lot of details on the hoses themselves... Silicone, Fire Proof, springs supports, double walls, finished ends, that kind of detail... For size and length the Mooney parts manual may be helpful? Lots of room for improvement over the old fabric and rusty (missing/broken) spring supported, crushed tubing from the 60s... (my 65C experience) PP thoughts only, not a mechanic... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
hypertech Posted July 1, 2018 Report Share Posted July 1, 2018 That's the thing. None of them describe this fabric covering. These came off a 2000 ovation. Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 1, 2018 Report Share Posted July 1, 2018 Now, i’m Really interested in what you find... Add that detail to your avatar... (if you can) This is probably a good tech question for a mechanically brilliant person like @M20Doc Best regards, -a- Quote Link to comment Share on other sites More sharing options...
Guest Posted July 1, 2018 Report Share Posted July 1, 2018 From the Ovation manual. Quote Link to comment Share on other sites More sharing options...
