Casey Posted July 28, 2016 Report Share Posted July 28, 2016 Ok so I'm getting ready to to the first oil change on my new to me Bravo and am looking for some advice. First I am trying to locate a digital version of the maintenance manual so if anyone knows a good place to get that I would appreciate it. Second is I need to order everything for the oil change since I'm currently located right in the middle of nowhere (O'Neill Nebraska) and don't know of a good brick and mortar store to buy from. So what site do you guys recommend for ordering parts from? Also since I don't have the manual I don't have a list of parts or part numbers that I will need so if anyone has that list it would be very helpful. I've done owner maintenance on previous aircraft I've owned but this will be the first on my Mooney so if you have any helpful tips and tricks I would love to hear those as well. Oh and if by chance there is anyone close by that wants to lend a helping hand I'll gladly supply the cold beverages and maybe some pizza. Thanks Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 28, 2016 Report Share Posted July 28, 2016 Find the thread regarding removing the Bravo's cowl. Somebody did a really nice job of showing their technique. it may give you some additional ideas... while you are in there look for things like exhaust anomalies and safety wiring methods. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
carqwik Posted July 28, 2016 Report Share Posted July 28, 2016 Getting the bottom half of the cowl off and on is the biggest hassle of the operation...besides the inevitable oil spillage from removing the oil filter itself. I get stuff mostly from Aircraft Spruce (case of oil, Camguard, oil filter). Remember the Bravo is 25 hour oil change engine...I replace filter every oil change and add requisite Camguard. 1 Quote Link to comment Share on other sites More sharing options...
Casey Posted July 28, 2016 Author Report Share Posted July 28, 2016 Thanks for the help. Turns out the small town Airport here had everything I needed and the manager even offered to give me a hand. The cowling was easier than I thought it would be. I'm going to order a bottle of cam guard tonight so I should have it in before I go flying again. Hardest part of the day was washing the plane after the oil change. Plane washing is a lot like work Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 29, 2016 Report Share Posted July 29, 2016 There is an amazing amount of surface area to be cleaned with any LB... If you try to wax it, there will be muscles that won't stop talking to you. And other muscles you might not hear from for a while... Best regards, -a- Quote Link to comment Share on other sites More sharing options...
carqwik Posted July 29, 2016 Report Share Posted July 29, 2016 Took me three days to wash, clay bar, and then wax the plane...about three hours each day invested. Btw, clay bar is very good for restoring luster to your paint. Here's a pic... 5 Quote Link to comment Share on other sites More sharing options...
FlyDave Posted July 29, 2016 Report Share Posted July 29, 2016 One way to keep the oil spilliage to a minimum is to run the engine to heat the oil and start it draining on one day, then come back the next day to replace the oil filter and finish up. The cooler oil will not run out of the filter as quickly as warm oil so you'll have less mess. Quote Link to comment Share on other sites More sharing options...
Bravoman Posted July 29, 2016 Report Share Posted July 29, 2016 5 hours ago, carqwik said: Took me three days to wash, clay bar, and then wax the plane...about three hours each day invested. Btw, clay bar is very good for restoring luster to your paint. Here's a pic... No professional detailer would spend the time and do as good a job as you did on your plane. If you find one that did it would probably be cost prohibitive! Looks great! Quote Link to comment Share on other sites More sharing options...
Casey Posted July 29, 2016 Author Report Share Posted July 29, 2016 Well I was lucky enough to buy my plane with a fresh paint job so no need for the clay bar yet. I may do the wax job soon though. 3 Quote Link to comment Share on other sites More sharing options...
madjano Posted July 29, 2016 Report Share Posted July 29, 2016 12 hours ago, carqwik said: Took me three days to wash, clay bar, and then wax the plane...about three hours each day invested. Btw, clay bar is very good for restoring luster to your paint. Here's a pic... I like that paint scheme, a lot. 1 Quote Link to comment Share on other sites More sharing options...
carusoam Posted July 30, 2016 Report Share Posted July 30, 2016 I had a similar thought..! i'm going to have to learn the skills of the clay bar, I think... best regards, -a- Quote Link to comment Share on other sites More sharing options...
carqwik Posted July 30, 2016 Report Share Posted July 30, 2016 For clay bar, just go to Walmart or any auto store and get the kit to start or buy each of the components separately. The "kit" will do about 3/4 of a long body Mooney as I recall....I think I ran out of the "Quick Detailer" first so had to buy a separate bottle. Clay bar is very labor intensive...has to be done by hand. Easy but time consuming. Just know that if for any reason you drop the clay on the floor, it must be discarded and you have to get a new piece. (You use a small portion of the bar at a time.) The test if you need to clay bar is to run your fingers lightly over the paint on your wings. If it feels "rough," then it's time to clay bar. When you finish with the clay bar, the paint surface will feel smooth...then go wax it. 1 Quote Link to comment Share on other sites More sharing options...
Tony Armour Posted September 13, 2016 Report Share Posted September 13, 2016 The real test is to put your hand in a Walmart or Lowes plastic bag or similar and rub the paint. Try it on your car paint with hand only...if smooth try the bag :-) No I don't clay bar my plane....or the cars :-) I do wash the plane sometimes when the weather cooperates (rain) haha Quote Link to comment Share on other sites More sharing options...
Tony Armour Posted September 13, 2016 Report Share Posted September 13, 2016 Oh yea, for the op. I order my oil from the oil store.com Quote Link to comment Share on other sites More sharing options...
