N400YS Posted May 6, 2016 Report Posted May 6, 2016 Hi I have a jumpy RPM Gauge and after I have checked the wire from the tachometer, I would like to check my plug behind the right panel. Is there a possibility to unscrew the extrem right part of the panel in order to see if the rpm wire is loosen? Perhaps just remove the radio out of its rack? Some advise to achieve this work? Thanks Quote
carusoam Posted May 6, 2016 Report Posted May 6, 2016 Do you know if it is a mechanical spinning cable type rpm gauge? (Speedometer cable from your bicycle type) If yes, that is an easy part to purchase and replace. They are known to wear out after a few decades. Bouncing needle is the typical sign of wear or lack of lubrication... If it is electronic... wait for the next MS post. Best regards, -a- Quote
N400YS Posted May 6, 2016 Author Report Posted May 6, 2016 (edited) 8 minutes ago, carusoam said: Do you know if it is a mechanical spinning cable type rpm gauge? (Speedometer cable from your bicycle type) If yes, that is an easy part to purchase and replace. They are known to wear out after a few decades. Bouncing needle is the typical sign of wear or lack of lubrication... If it is electronic... wait for the next MS post. Best regards, -a- Thank you for your quick answer ;-) No, it is an eletronical gauge on the MSE (1995). There is no speedometer cable. Just a wire from the Magneto. Oliver Edited May 6, 2016 by N400YS 1 Quote
Marauder Posted May 6, 2016 Report Posted May 6, 2016 27 minutes ago, N400YS said: Thank you for your quick answer ;-) No, it is an eletronical gauge on the MSE (1995). There is no speedometer cable. Just a wire from the Magneto. Oliver Oliver -- the breaker panel that the gauge resides in can be accessed by removing the screws that hold it in place, My advice -- if you can avoid it, try not to get access that way. The number of wires and the breakers make for a tight environment. I can access my electronic gauges by removing my co-pilot seat and laying on my back and working underneath the panel. 1 Quote
N400YS Posted May 6, 2016 Author Report Posted May 6, 2016 Just now, Marauder said: Oliver -- the breaker panel that the gauge resides in can be accessed by removing the screws that hold it in place, My advice -- if you can avoid it, try not to get access that way. The number of wires and the breakers make for a tight environment. I can access my electronic gauges by removing my co-pilot seat and laying on my back and working underneath the panel. Thank you Marauder! You're definitely right! I will access by the down side after removing the SCAT ventilation duct! Thanks Quote
carusoam Posted May 6, 2016 Report Posted May 6, 2016 Hopefully the J has a different rpm sensor than the Long Body's.... There have been some discussions on that expensive device over the years. If you need some back ground on that... It can probably be found searching for Hall effect rpm transducer? Best regards, -a- Quote
Guest Posted May 7, 2016 Report Posted May 7, 2016 The tachometer can be removed without difficulty, you may have to remove the MAP gauge below frost, then the tachometer. Clarence Quote
N400YS Posted May 7, 2016 Author Report Posted May 7, 2016 Thanks all! actually it is quite easy to access to the rpm gauge underneath the panel. the plug was not tightened enough so I think that the little plug play could generate the problem. test flight is pending to confirm that the problem is solved ! I'll keep you informed ! Oliver 2 Quote
N400YS Posted May 10, 2016 Author Report Posted May 10, 2016 (edited) Hi Guys Tested the Rpm Indicator in flight yesterday: still jumpy above 2000rpm. I think that the indicator is the culprit...so as I will get a EDM 730 we will check all the line next annual ! Thanks for help Oliver Edited May 10, 2016 by N400YS Quote
Piloto Posted May 10, 2016 Report Posted May 10, 2016 Check the engine side connection. Engine vibration above 2,000 rpm could induce erratic connection. José Quote
Guest Posted May 11, 2016 Report Posted May 11, 2016 7 hours ago, Piloto said: Check the engine side connection. Engine vibration above 2,000 rpm could induce erratic connection. José Don't the tachometer wires connect to the magneto switch? Clarence Quote
N400YS Posted May 11, 2016 Author Report Posted May 11, 2016 13 hours ago, Piloto said: Check the engine side connection. Engine vibration above 2,000 rpm could induce erratic connection. José Thanks José. I already have checked the engine side and nothing was found loose.... So, now, I consider that it is a mechanics job :-) I'm just a pilot :-) Quote
N400YS Posted June 27, 2016 Author Report Posted June 27, 2016 Hi Just to say that if you would like to control your rpm gauge efficiency, or if you have like me a rpm gauge issue, you could use a very usefull Iphone app: ENGINE RPM https://itunes.apple.com/fr/app/engine-rpm/id340401811?mt=8 Tested yesterday in flight: very accurate and easy to use.!! Quote
ArtVandelay Posted June 27, 2016 Report Posted June 27, 2016 $9!!! That's a lot for the CBs among us. Quote
Andy95W Posted June 27, 2016 Report Posted June 27, 2016 Just now, teejayevans said: $9!!! That's a lot for the CBs among us. And I wonder just how accurate it can be since it only analyzes sound. If it were a true optical rpm detector, I might consider the $9. Quote
N400YS Posted June 27, 2016 Author Report Posted June 27, 2016 (edited) 36 minutes ago, N1395W said: And I wonder just how accurate it can be since it only analyzes sound. If it were a true optical rpm detector, I might consider the $9. Hi N1395W It is accurate enough for the worth. Sincerely, there is no raison that the sound measuring be less accurate than the optical one. I would concur if it was used for a prop balancing setting. But in this case (random rpm gauge failure), an optical measuring is very heavy to install. An accoustic measuring technic is very light and easy to start compared to an optical one.(Wires outside de cockpit, sticker on the prop) I checked the rpm during the 30 minutes of my last flight and the rpm variations, read on the device were very low: maximum 5%. It was enough to set my rpm on 2500 instead 2600 or more. So, to help temporaly, a 9$ investment is a bargain! Edited June 27, 2016 by N400YS 1 Quote
Andy95W Posted June 27, 2016 Report Posted June 27, 2016 I'm glad to hear it works well. Back in the 1970's I built a small, handheld Heathkit RPM gauge for model airplanes that used an optical sensor that "saw" the prop blades as they passed by. I sure wish I still had that today. I think my mom tossed it when I was in college! 1 Quote
Yetti Posted June 28, 2016 Report Posted June 28, 2016 You can get a dedicated one for $10.00 http://www.hobbyking.com/hobbyking/store/__10783__Turnigy_Multi_Blade_Micro_Tachometer.html 1 Quote
N400YS Posted September 25, 2016 Author Report Posted September 25, 2016 (edited) On 10/05/2016 at 7:50 PM, Piloto said: Check the engine side connection. Engine vibration above 2,000 rpm could induce erratic connection. José Hi Folks Here is the end of the story.. The culprits were two wires from the magnetos that were tighten too much. Once I loose the wires (that were attached on the engine mount) the rpm meter reading became nominal and steady. Thanks for your help! Olivier Edited September 25, 2016 by N400YS Quote
carusoam Posted September 25, 2016 Report Posted September 25, 2016 Great follow-up, Olivier. Best regards, -a- Quote
