RobertE Posted January 31, 2016 Report Posted January 31, 2016 Can anyone help? The cables that deploy the brakes seem to have a lot of slop in them but, then again, I don't know if that's the way it's supposed to be. Precise Flight has the manual for the current electric model on it's website but not the old vacuum-powered one. Thanks everyone. Quote
jclemens Posted February 2, 2016 Report Posted February 2, 2016 Call Precise Flight. They still had some parts laying around for those old systems last time i needed some. The cables that are run through the wheel wells in the nylon tubing are not under tension when the speed brakes are not deployed. Even when they are deployed the cables not real tight. If they are working other wise I wouldn't be concerned. Quote
kortopates Posted February 2, 2016 Report Posted February 2, 2016 There is no manual for vacuum speed brakes. Check the conduits to see if they have become so brittle that they are falling apart; eventually they fall apart and the cable hangs up during retraction although they still tend to deploy fine. Check the resistance by pulling the cable by hand at the vacuum bellows to see where any resistance might be. These are very simple - just like bicycle cables pulling the speedbrake open while a spring on the brakes pulls it back closed. Sent from my iPhone using Tapatalk Quote
RobertE Posted February 4, 2016 Author Report Posted February 4, 2016 For anyone interested I now have the installation manual for the vacuum powered speed brakes from Precise Flight. I offered to pay but they wouldn't accept. If interested just send me a message with your email. It's a nearly 3 meg file. 3 Quote
jrwilson Posted February 4, 2016 Report Posted February 4, 2016 can you put it in documents on this site? Quote
RobertE Posted February 5, 2016 Author Report Posted February 5, 2016 Here is the pdf. Precise Flight speed brake install manual.pdf Quote
carusoam Posted February 5, 2016 Report Posted February 5, 2016 I sent a message to Craig to see if he can copy it to the saved documents / 'downloads' area... Best regards, -a- Quote
mooniac58 Posted February 5, 2016 Report Posted February 5, 2016 Are members not able to upload files? Quote
