I bought a 2005 m20r with g1000s, does anyone know where Mooney would have put the enablement cards for the g1000, I can't find them anywhere
Welcome aboard, buddy...
That sounds unique.
I hope somebody can get back to you with an answer soon...
have you called Garmin for those?
best regards,
Edited by carusoam
I found mine in the (Mooney) bag with the logbooks.
Sure hope you find them as I understand Garmin doesn't make it easy to get replacement cards.
If you don't see them right away you may want to contact the previous owner and ask him/her where they were kept.
Good luck!
Look in the POH, maintenance records, ask the former owner. If you can't find them, you can get replacements from your Garmin dealer for right around $200. But you have to prove that the enablements were purchased either aftermarket or with the new aircraft. Proof of purchase can be in the form of an invoice or logbook entry. Something that ties the enablement feature to the aircraft. But you can only get them at the reduced rate only once. Garmin dealer here in San Jose.
