M20S Driver Posted September 3, 2015 Report Share Posted September 3, 2015 Does anyone know how to download data from JPI units with a newer computer running in 64 bit mode? JPI told me to buy an older computer that runs on 32bit!!!! JPI does not seem to have a plan to move into the new millennium Quote Link to comment Share on other sites More sharing options...
N601RX Posted September 3, 2015 Report Share Posted September 3, 2015 64 bit machines have an option to run programs as 32 bits Quote Link to comment Share on other sites More sharing options...
carusoam Posted September 3, 2015 Report Share Posted September 3, 2015 Similar challenge for BK GPS data uploads... Mid 90s KLN90B comes to mind. Best regards, -a- Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted September 3, 2015 Author Report Share Posted September 3, 2015 64 bit machines have an option to run programs as 32 bits It is not a simple option. You need to run a shell program, re-configure another XP or windows 7 environment, and modify the win.ini. Do you know of a better way of running 32 bit on a 64 bit computer? Quote Link to comment Share on other sites More sharing options...
cnoe Posted September 3, 2015 Report Share Posted September 3, 2015 Load your data into saavy's free web-based program. Works great and had better interface IMO. Visit https://www.savvyanalysis.com Sent from my iPad using Tapatalk 3 Quote Link to comment Share on other sites More sharing options...
N601RX Posted September 3, 2015 Report Share Posted September 3, 2015 Google running programs in compatibility mode. I've had good luck with it. Quote Link to comment Share on other sites More sharing options...
wishboneash Posted September 3, 2015 Report Share Posted September 3, 2015 Load your data into saavy's free web-based program. Works great and had better interface IMO. Visit https://www.savvyanalysis.com One would still need to get the JPI program running for downloading the data? I had a hell of a time trying to make this work on a non-Windows machine without a serial port. Finally, I found an older laptop running Windows XP and a serial port. Quote Link to comment Share on other sites More sharing options...
Cruiser Posted September 3, 2015 Report Share Posted September 3, 2015 Does anyone know how to download data from JPI units with a newer computer running in 64 bit mode? JPI told me to buy an older computer that runs on 32bit!!!! JPI does not seem to have a plan to move into the new millennium I have a Dell D800 laptop with a serial port that works and will do what you need without any problems. Comes with carrying case, AC power supply and the internal battery ------ $100 PM me if you are interested in it. Quote Link to comment Share on other sites More sharing options...
cnoe Posted September 4, 2015 Report Share Posted September 4, 2015 One would still need to get the JPI program running for downloading the data? I had a hell of a time trying to make this work on a non-Windows machine without a serial port. Finally, I found an older laptop running Windows XP and a serial port. On my JPI (an EDM830) you just plug a USB stick into the display and dump the data into memory with no program or PC necessary. Then stick the USB stick into your 64-bit PC and upload to Savvy. Easy peasy. Sent from my iPad using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted September 4, 2015 Author Report Share Posted September 4, 2015 On my JPI (an EDM830) you just plug a USB stick into the display and dump the data into memory with no program or PC necessary. Then stick the USB stick into your 64-bit PC and upload to Savvy. Easy peasy. I like the Savvy interface and that's what I use to look at the data. As Wishboneash mentioned, I still need to down-load and my JPI700 only has an old serial port on it. This is perhaps JPI's way of forcing us to upgrade to the USB version.... I just installed a virtual PC with windows XP on my 64 bit computer which is running Windows 7. I will test it tomorrow to see if I can download the data. Quote Link to comment Share on other sites More sharing options...
ArtVandelay Posted September 4, 2015 Report Share Posted September 4, 2015 One would still need to get the JPI program running for downloading the data? I had a hell of a time trying to make this work on a non-Windows machine without a serial port. Finally, I found an older laptop running Windows XP and a serial port. They have serial to USB cables if your PC doesn't have a serial port. Quote Link to comment Share on other sites More sharing options...
mikerocosm Posted September 4, 2015 Report Share Posted September 4, 2015 The issue is not likely 64-bit, it's the serial interface. I'm on my second 64-bit laptop retrieving data from my EDM-700, and I just plug in the JPI-provided cable to the provided EDM-700 port, then plug the serial-port end of that cable into a Keyspan by Tripp Lite USA-19HS USB-to-serial adapter, then plug the USB end into my laptop, and it all works great. (I tried a couple of other adapters, and for reasons beyond my willingness to figure out, they didn't work, but this one did.) You can find one of these adapters on Amazon or probably lots of other places. They cost $32 or so. Not CB-conforming, but it works. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
kortopates Posted September 4, 2015 Report Share Posted September 4, 2015 I have EZtrends operational on my Windows 10 64 bit system - just had to setup the compatibility options to do so. The newer the version of Windows the easier it is it seems they make setting the compatibility options. But as mentioned, except for the LeanFind function in EzTrends which I really liked, I otherwise find the Savvy Analysis app on the web superior - but I use it daily and have become pretty adept at using it. It allows me to view multiple graphs at a time and the Gami spread button is nearly as good at Eztrends LeanFind function and it provides additional niceties such as the Delta function and Rate function. And perhaps the best feature of all is you can share your data with anyone plus you get a professional help with analysis as many people do. There are lots of Mooney pro subscribers! 1 Quote Link to comment Share on other sites More sharing options...
marky_24 Posted September 6, 2015 Report Share Posted September 6, 2015 It's a little spendy, but then again it's aviation. https://www.jpinstruments.com/shop/jpi-usb-download-box/ Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted September 6, 2015 Author Report Share Posted September 6, 2015 The issue is not likely 64-bit, it's the serial interface. I'm on my second 64-bit laptop retrieving data from my EDM-700, and I just plug in the JPI-provided cable to the provided EDM-700 port, then plug the serial-port end of that cable into a Keyspan by Tripp Lite USA-19HS USB-to-serial adapter, then plug the USB end into my laptop, and it all works great. (I tried a couple of other adapters, and for reasons beyond my willingness to figure out, they didn't work, but this one did.) You can find one of these adapters on Amazon or probably lots of other places. They cost $32 or so. Not CB-conforming, but it works. Good luck! You are correct. The problem was caused by the Keyspan driver on my new laptop. A combination of updated driver and running the laptop in windows XP compatability mode solved my problem for both EZ Trends and EZ Save. 1 Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted September 6, 2015 Author Report Share Posted September 6, 2015 I have EZtrends operational on my Windows 10 64 bit system - just had to setup the compatibility options to do so. The newer the version of Windows the easier it is it seems they make setting the compatibility options. But as mentioned, except for the LeanFind function in EzTrends which I really liked, I otherwise find the Savvy Analysis app on the web superior - but I use it daily and have become pretty adept at using it. It allows me to view multiple graphs at a time and the Gami spread button is nearly as good at Eztrends LeanFind function and it provides additional niceties such as the Delta function and Rate function. And perhaps the best feature of all is you can share your data with anyone plus you get a professional help with analysis as many people do. There are lots of Mooney pro subscribers! Thanks for the info. The compatibility mode and updated driver for my serial converter solved the problem. Quote Link to comment Share on other sites More sharing options...
HRM Posted September 6, 2015 Report Share Posted September 6, 2015 Thanks for the info. The compatibility mode and updated driver for my serial converter solved the problem. You should still check out Savvy. EZtrends has a sucky interface and I don't believe it does any more than Savvy. Also, the reason Mike Busch made it free is that he uses the data everyone uploads to look at engine behavior trends (nothing is truly free) and it is a massive database. 1 Quote Link to comment Share on other sites More sharing options...
M20S Driver Posted September 7, 2015 Author Report Share Posted September 7, 2015 All of my flights are uploaded to Savvy. I rarely use EZTrends for analysis but use it for data transfer. Quote Link to comment Share on other sites More sharing options...
wishboneash Posted September 7, 2015 Report Share Posted September 7, 2015 They have serial to USB cables if your PC doesn't have a serial port. Forgot to mention, I do have the USB cable which I tried to use with a Mac running Parallels but couldn't get the COM ports set up properly. Gave that up! That was the hell of time I had been having. Sent from my Nexus 7 using Tapatalk Quote Link to comment Share on other sites More sharing options...
Browncbr1 Posted September 7, 2015 Report Share Posted September 7, 2015 I have a 64but windows7 system and had no problem installing and running. However, the interface is rather doo doo. So I use the savvy analysis website. Quote Link to comment Share on other sites More sharing options...
Oscar Avalle Posted September 17, 2015 Report Share Posted September 17, 2015 I have a 64but windows7 system and had no problem installing and running. However, the interface is rather doo doo. So I use the savvy analysis website. Same for me. it runs well on my Windows 10 machine but the interface is horrible. So I use the savvy site Quote Link to comment Share on other sites More sharing options...
Bob_Belville Posted September 17, 2015 Report Share Posted September 17, 2015 I like some features of Savvy but I don't think it allows loading multiple flights like EZTrends does. It is often useful to have 2 or more flights graphed side by side to see changes. (It is possible Savvy does that as well, I've looked around as little and have not found it.) Quote Link to comment Share on other sites More sharing options...
