Someone help what starter?
Cwalsh7997
I have a Skytec starter.  My original went out and I shipped it to them and they overnighted it back.  I did all of the removal which was a total pain in the butt.  I had my mechanic do the install.  He charged me 2.8 hours labor to install and put the cowling back on.
Link to comment
Share on other sites
149NL Skytec starter. This is the high torque starter. I have the 149LS on my m20e. It works great too. If I was buying a new one it would be the 149nl.
Assuming you have a flywheel has the correct amount of teeth. Early-early "Cs" did have different flywheels...
-Matt
Link to comment
Hey guys my plane is once again down at FXE with a bad starter so I want to know what starter it uses and if I should ask premier for anything specific and what's the cost and how long should I expect it to take?
When you say "bad starter", what is wrong with it? If it is the Bendix not moving forward, I would try lubricating it before replacing it.
Link to comment
+4 on SkyTec
My buddy got the wrong one for his Commander and when he talked to them at Sun-n-Fun, they told him to send it to them (not the original vendor) and they would swap him out at no charge. Customer service counts.
John
Link to comment
My Skytec 149NL stopped working. I removed it and trouble shot it. It was out of warrantee so I called them up and told them what I found and asked what I needed to do to get it fixed. They sent me a new one right away and charged me for it. They said to return mine in the box the new one came in. I did that and two days later they called and said it was a manufacturing defect and refunded the whole cost of the new starter.
How can you not love that...
Link to comment
Here's my SkyTec story-
When I bought my Mooney, it already had a SkyTec in it, but it was the 149-LS light weigh starter. It worked just fine, then one day... dead. So I boxed it up and set it back to Sky-Tec for the $200 rebuild. Then I got the bad news. It was so messed up they wouldn't rebuild it and they were going to scrap it. They offered me a rebuilt one, or an alternate, a rebuilt 149-NL. My choice.
The light weight is just that. Light weight. It also spins faster and so can start the plane faster. The downside is, it's not as robust and as I would find out, it isn't as well sealed against oil intrusion.
So it turns out my original starter was completely saturated inside by engine oil. My number 2 cylinder has a base gasket leak and oil seeps out of there consistently. I found out that oil saturation like that absolutely ruins motors.
They told me that the NL was better sealed against oil and is a lot tougher, so I decided to go for the 149-NL. They didn't actually have any rebuilt 149-NLs in stock, so they sent me a brand new on for the $200 rebuild price. All this inside of a work week from me dropping off a dead starter at the UPS store to getting a new one back.
I'm really impressed with their service.
Link to comment
