aviatoreb Posted April 21, 2017 Report Share Posted April 21, 2017 Never mind that the picture shows the airplane in a dive. Quote Link to comment Share on other sites More sharing options...
Marauder Posted April 22, 2017 Report Share Posted April 22, 2017 Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted April 22, 2017 Report Share Posted April 22, 2017 7 minutes ago, Marauder said: Sent from my iPhone using Tapatalk Pro That was after the dive and just before we entered the loop. I was going to take a picture during the snap roll but I dropped the camera under the extreme g forces. Quote Link to comment Share on other sites More sharing options...
Marauder Posted April 22, 2017 Report Share Posted April 22, 2017 Sent from my iPhone using Tapatalk Pro 2 Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted April 22, 2017 Report Share Posted April 22, 2017 44 minutes ago, Marauder said: Sent from my iPhone using Tapatalk Pro Was that sitting behind me on the flight? I'm glad you didn't loose your camera. Did you get any of the snap rolls? Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted April 22, 2017 Report Share Posted April 22, 2017 The G500 announces "minimum, minimum" over the intercom when the DA or MDA is reached. The pilot does have to set that figure into the flight plan page. I set it for every instrument approach. Generally one breaks out well above DA, and the audible warning serves only as a reminder how low you really are at an ILS or LPV minimum. It makes me realize if l am still in the clouds when I hear that annunciation it is time to go missed NOW. 1 Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted April 22, 2017 Report Share Posted April 22, 2017 15 hours ago, aviatoreb said: I bet it had air conditioning too. But it was a cool day so I wasn't missing it either way. Still...on a hot day. Speaking of air conditioning - anyone seen this portable unit mentioned on the beech talk weekly feed? https://www.indiegogo.com/projects/zero-breeze-the-world-s-coolest-portable-ac-unit#/ Very cool unit - portable and battery powered - which is perfect for start up and taxi use. To use in a small airplane it would need a way to vent the hose (which it can use) to outside the cabin. Two of those in the hat rack would probably do the job. The vent hose could go out the hole on the bottom rear that my old gill battery vent hose went. Quote Link to comment Share on other sites More sharing options...
StevenL757 Posted April 22, 2017 Report Share Posted April 22, 2017 16 hours ago, Marauder said: Probably a radar altimeter. Sent from my iPhone using Tapatalk Pro On the older Pilates aircraft such as that, the KGP-860 EGPWS, or the KMH-920 Traffic/EGPWS (more common) gave those callouts. I have a bit of time in them, and these are typically the two choices I've experienced. The later Pilatus airframes kicked this up to the KMH-980 TAWS-B/TCAS-I system. Steve Quote Link to comment Share on other sites More sharing options...
Jerry 5TJ Posted April 22, 2017 Report Share Posted April 22, 2017 28 minutes ago, LANCECASPER said: Two of those in the hat rack would probably do the job. The vent hose could go out the hole on the bottom rear that my old gill battery vent hose went. https://www.indiegogo.com/projects/zero-breeze-the-world-s-coolest-portable-ac-unit#/ Two units weigh more than the 10 pound hat shelf limit. Each AC rated at 1100 BTU/hour. Two are not going to chill a heat-soaked Mooney. (Factory AC is 25,000 BTU/hr). But they're going to help and in shade could pre-cool the cabin. Interesting units. Now, thinks, how best to wire two in series for our 28V aircraft? Note that the 10,000 BTU/hr ArcticAir box weighs 50 pounds and draws 28V / 37 amps. Costs ~ 5 AMU. http://www.arcticaircooler.com/mobile/Product.aspx?ProductCode=RAC-400-2-24D Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted April 22, 2017 Report Share Posted April 22, 2017 Just now, Jerry 5TJ said: https://www.indiegogo.com/projects/zero-breeze-the-world-s-coolest-portable-ac-unit#/ Two units weigh more than the 10 pound hat shelf limit. Each AC rated at 1100 BTU/hour. Two are not going to chill a heat-soaked Mooney. (Factory AC is 25,000 BTU/hr). But they're going to help and in shade could pre-cool the cabin. Interesting units. Now, thinks, how best to wire two in series for our 28V aircraft? Note that the 10,000 BTU/hr ArcticAir box weighs 50 pounds and draws 28V / 37 amps. Costs ~ 5 AMU. http://www.arcticaircooler.com/mobile/Product.aspx?ProductCode=RAC-400-2-24D Good point on the hat rack - wasn't completely awake when I wrote that. The batteries allow for 5 hours use so I don't see any need to wire them. Once up at altitude no need - would probably help with taxi, take-off and landing. I bought a cooler (Arctic Air 24V) over the winter so we'll see how that works in the hot Texas summer this year. Sorry the thread got hijacked. Should probably open up a new thread on the small A/C unit/ Quote Link to comment Share on other sites More sharing options...
aviatoreb Posted April 22, 2017 Report Share Posted April 22, 2017 11 minutes ago, LANCECASPER said: Good point on the hat rack - wasn't completely awake when I wrote that. The batteries allow for 5 hours use so I don't see any need to wire them. Once up at altitude no need - would probably help with taxi, take-off and landing. I bought a cooler (Arctic Air 24V) over the winter so we'll see how that works in the hot Texas summer this year. Sorry the thread got hijacked. Should probably open up a new thread on the small A/C unit/ A dedicated cooling thread would be a great lead in for summer. I hadn't done the arithmetic-engineering to consider how many BTU's are required for a mooney cabin. I was simply guessing that since the mooney cabin is a small space, that even with the windows, that the small battery powered unit would do. Oh well. A battery powered something or other, would be pretty ideal I think for a mooney since you only need it for a few minutes on the ground. So leave the unit in the airplane and bring the battery back and forth to charge. Without having to tax your airplane's electrical. Quote Link to comment Share on other sites More sharing options...
jetdriven Posted April 22, 2017 Report Share Posted April 22, 2017 On 3/17/2017 at 2:28 PM, Bunti said: I have the 750 without TAWS activated, but connected to my audio panel. I even get no "500" call or so. The only call, the 750 will give you, is something like "traffic 12 a clock low 1 mile", if it is connected to an appropriate traffic receiver. (in my case GTX 345). TAWS on the GTN750 is very expensive, so I opted for the Aera 660. We connected the Aera 660 to the audio panel and it gives me all the audio calls for obstacles, terrain and even a 500 feet call during the approach. Stefan We're going to have thbsame setup. 750/660 Quote Link to comment Share on other sites More sharing options...
