N5MD Posted August 3, 2010 Report Share Posted August 3, 2010 Is there a replacement for the old Six Instrument Gauge found in older Mooney's? How about a rebuild of those old gauges? Quote Link to comment Share on other sites More sharing options...
DaV8or Posted August 3, 2010 Report Share Posted August 3, 2010 Don't know about the rebuild. I'm kind of curious too only because I would like mine to look better. Mine seem to work OK now. You can replace them, as well as your tach and MP gauge, with the JPI EMD-930 and get unbelievable accuracy and information only afforded by a digital system, but of course at a hefty price. I think those are the best options. Rebuild the originals or go glass. Quote Link to comment Share on other sites More sharing options...
Lood Posted August 3, 2010 Report Share Posted August 3, 2010 I'm also interested. Mine really sucks. The fuel quantity gauges are even worse those I had in my C172 and the oil temp often needs reminding, by means of a finger tap or two, two wake up and work. CHT seems to be fine and I don't have anything to say about the poor effort put into the ammeter. Ooooh, I love my JPI. Quote Link to comment Share on other sites More sharing options...
danb35 Posted August 3, 2010 Report Share Posted August 3, 2010 It's my understanding that Air Parts of Lock Haven (http://www.airpartsoflockhaven.com/) can repair/overhaul any of them. For the fuel gauges, though, make sure it's the guage, rather than the sender or wiring, that's the problem. Or you can buy an EI MVP-50 and replace pretty much all the engine instruments with that, for around $5k + installation. Quote Link to comment Share on other sites More sharing options...
jax88 Posted August 3, 2010 Report Share Posted August 3, 2010 I suppose someone makes certified digital replacements for some or all of these guages? Quote Link to comment Share on other sites More sharing options...
danb35 Posted August 3, 2010 Report Share Posted August 3, 2010 Both Dave and I have posted about digital replacements. I'm not aware of any certified digital replacement that will fit the same size hole, though. Quote Link to comment Share on other sites More sharing options...
flight2000 Posted August 3, 2010 Report Share Posted August 3, 2010 Sigma-Tek holds the patents from the old Garwin company that made the originals and will manufacture new gauges for all of the cluster insturments. I had them build two new fuel gauges to Mooney's specs about three months ago. They are pricy though ($350 each), so if you can find a place to rebuild them, I'd go that route. I couldn't and went with OEM specs. http://www.sigmatek.com/cluster_gauges.html Brian Quote Link to comment Share on other sites More sharing options...
flight2000 Posted August 3, 2010 Report Share Posted August 3, 2010 Quote: danb35 Or you can buy an EI MVP-50 and replace pretty much all the engine instruments with that, for around $5k + installation. Quote Link to comment Share on other sites More sharing options...
Ned Gravel Posted August 3, 2010 Report Share Posted August 3, 2010 And here is another data point. When I was at Osh, in one of the big hangers with all the suppliers, I ran across Mitchell Aircraft Products and the fella behind the counter showed me a replacement for my 6-pack cluster gauges that looked really good. One thing they do is put some sort of transducer at the end of wire to replace the way your oil pressure gauge gets its information. No more oil in the cockpit. Anyway, the whole assembly costs about $550 USD and, until I am ready to find a cheaper (less than $1500) TSO'd primary replacement for these six and the MP, Fuel Press, Tach, it is an option too. I told the guy that my fuel gauges are so bad that one reads 1/4 at empty and the other reads 3/4 at full. Never trust them and always measure with the stick and do fuel burn calcs in flight. I also told him that some folks believe this is probably because of the senders. He said that might not be so - the old gauges themselves might actually be out of tolerance. So....differing opinions and one more option to choose from. YMMV. They are at http://www.mitchellproducts.com. Quote Link to comment Share on other sites More sharing options...
DaV8or Posted August 3, 2010 Report Share Posted August 3, 2010 Quote: edgargravel And here is another data point. When I was at Osh, in one of the big hangers with all the suppliers, I ran across Mitchell Aircraft Products and the fella behind the counter showed me a replacement for my 6-pack cluster gauges that looked really good. Quote Link to comment Share on other sites More sharing options...
N5MD Posted August 3, 2010 Author Report Share Posted August 3, 2010 WWW.mitchelproducts.com sells a number of 1.5" square instruments that can be selected and arranged in the six-pack configuration. They look great and are available only through distributors. See their website for specs, pictures and distributors. See attached picture of a 6-pack configuration using these gauges. They seem like a good option. Thanks for the information! Quote Link to comment Share on other sites More sharing options...
danb35 Posted August 3, 2010 Report Share Posted August 3, 2010 Unfortunately, it doesn't appear that the Mitchell guages are approved for Mooneys. Quote Link to comment Share on other sites More sharing options...
DaV8or Posted August 3, 2010 Report Share Posted August 3, 2010 Quote: N5MD WWW.mitchelproducts.com sells a number of 1.5" square instruments that can be selected and arranged in the six-pack configuration. They look great and are available only through distributors. See their website for specs, pictures and distributors. See attached picture of a 6-pack configuration using these gauges. They seem like a good option. Thanks for the information! Quote Link to comment Share on other sites More sharing options...
mjc Posted August 3, 2010 Report Share Posted August 3, 2010 I had to have only my oil pressure gauge fixed and sent it to a fellow named Paul Malkasian in Sequim, WA. He described the repair in great detail over the phone and charged something like $60 or 80. Maybe he can help. A web search turned up his site: www.fuelsenders.com. Quote Link to comment Share on other sites More sharing options...
tablor Posted August 3, 2010 Report Share Posted August 3, 2010 I'm sure there's a place in Tx, I think it's in Austin, that Dugosh, SWTA, MAC send these gauges to for overhaul. I've been told it's inexpensive ($60?) and the turnaround is quick. I didn't post sooner cause I figured someone knew the place by name. I tried to search and find it, but was unsuccessful. It exists though, I'm sure of it. Some Texas person will know the name, sorry I don't! Quote Link to comment Share on other sites More sharing options...
tablor Posted August 11, 2010 Report Share Posted August 11, 2010 Ok, I found it. It's Aircraft Instrument Support Services (AISS) in Georgetown, TX. His name is Ralph Posey and if you call him he can give you an idea of the cost based on the instrument that needs to be repaired. Quote Link to comment Share on other sites More sharing options...
Gilt Posted August 11, 2010 Report Share Posted August 11, 2010 My 63 m20c fuel gauges were bouncing and not reading correct, changed the fuel sending units in the wing with the new style. There spot on now...(the rheostat goes bad...you can test it with a ohms meter) Quote Link to comment Share on other sites More sharing options...
acrotex Posted September 26, 2010 Report Share Posted September 26, 2010 Gilt, where did you get the fuel sending units? What was cost and PN? What size are your tanks? My M20C (1963) has the 24 gal tanks. Later ones are larger, not sure if the sending units are the same or not. I have one unit that I think is going bad. Quote Link to comment Share on other sites More sharing options...
Gilt Posted September 28, 2010 Report Share Posted September 28, 2010 Hey acrotex, one came from Maximun Cruise Aviation...(320)235-4844 i have 24 gal tanks also. PN 610242-001 $289.33..I changed one then I seen how bad the other one was, got lucky a local MEC had a used one from a 92 J model they are the exact same. now there spot on and don't bump around...very easy to change also, five screws one wire...good luck... Quote Link to comment Share on other sites More sharing options...
Alan Fox Posted October 3, 2010 Report Share Posted October 3, 2010 I looked at the mitchells about 4 years ago , they do make a certified version that fits , but it was a modular setup and the total cost was over three K , so definitely cost efficient considering the cost of glass.. Quote Link to comment Share on other sites More sharing options...
rc454 Posted July 8, 2011 Report Share Posted July 8, 2011 Mitchell Products claims that there have been several Field Approvals given for the 6 gauge cluster for Mooneys. However they have been unable to supply a copy of a field approval or even give me an aircraft N number. Has anyone on this forum obtained a field approval or know of someone who has? If so, what is the N number of the airplane with the approval? Note: The FAA will only recognize field approvals which have been recorded in the National Aircraft Registry - so the paperwork has to be complete for it to be any good. Quote Link to comment Share on other sites More sharing options...
tony Posted July 8, 2011 Report Share Posted July 8, 2011 http://cgi.ebay.com/MOONEY-M20E-AIRCRAFT-CLUSTER-GAUGE-/120747404798?pt=LH_DefaultDomain_0&hash=item1c1d1b2dfe Quote Link to comment Share on other sites More sharing options...
N5MD Posted July 9, 2011 Author Report Share Posted July 9, 2011 Quote: tony http://cgi.ebay.com/MOONEY-M20E-AIRCRAFT-CLUSTER-GAUGE-/120747404798?pt=LH_DefaultDomain_0&hash=item1c1d1b2dfe Quote Link to comment Share on other sites More sharing options...
Nstarbf Posted July 16, 2020 Report Share Posted July 16, 2020 It's been a while since anyone posted to this thread. Has anyone had any updates? I'm keenly interested in replacing my gauges as well Quote Link to comment Share on other sites More sharing options...
Sabremech Posted July 16, 2020 Report Share Posted July 16, 2020 37 minutes ago, Nstarbf said: It's been a while since anyone posted to this thread. Has anyone had any updates? I'm keenly interested in replacing my gauges as well I’ve installed a Mitchell Cluster a number of years ago via a 337 field approval. The Mitchell gauges are FAA/PMA. Thanks, David 1 Quote Link to comment Share on other sites More sharing options...
